Question about Belkin (F5D7011) 802.11g/b Wireless Adapter
I can't figure out how to connect to the internet with my Belkin card.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 123 Answers
If you are near wifi but a connection doesn't show up in the list or you have issues connecting try disabling and enabling the wifi adapter on your laptop. To see how to do this click the link below for a quick video tutorial:
https://youtu.be/j2TqlA55KlM
If you need further help, I’m available over the phone at https://www.6ya.com/expert/josh_8e641fe76e154b02
Posted on Apr 06, 2016
    President:
  • 2,246 Answers
This is wireless (wifi) receiver
the first you need is wifi connection around your computer
if there any wifi connection aroud you, at your computer open and search the available wifi connection, then chose connect
and you can connect internet after you connect your belkin to wireless connection
Posted on Mar 25, 2011
Why doesnt my dell latitude d180 not let me get on the internet with a belkin internet card
You didn't give enough information - I have to assume you are using Windows XP.
For a wired connection:
Click "Start"
Click "Control Panel"
Click "Network and Internet Connections"
Click "set up or Change your Internet Connection"
Then use the "Internet Properties" dialog box with the "Connections" tab selected.
Close to the top click the "Setup" box.
this should open up a wizard and from there you will need to enter the information from your ISP.
For a wireless connection you can click on the "Wireless Network Setup Wizard " instead of the "Set up or Change your Internet Connection"
Nov 30, 2017 | Dell Latitude D810 PC Notebook
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
Belkin note bookcard isnt working
Probably need to install the software that came with the Belkin card first. Make sure the card is NOT plugged in when you install from the CD. After that, restart your computer and make sure the card is now plugged in. Also, you need to set the router and belkin card with the same settings.
Jul 03, 2009 | Belkin (F5D7011) 802.11g/b Wireless...
Belkin (F8E885) Enhanced Keyboard
That keyboard is not wireless, it is cabled to the computer. If you are looking h=to have your computer connect to the internet using wireless, you need to have a wireless access point connected to a cable modem or DSL, as well as a wireless network card in the computer.
May 17, 2009 | Belkin Enhanced Keyboard
Belkin wireless 'N' with Vonage router and cable ISP modem...
Hi, since your Internet source is the ISP modem, you have to connect the cable from it to the yellow connector of Belkin router, then you can connect the VoIP router and computer to any of the ports (connectors) labeled 1-4 , remember to restart clients (PC & VoIP router) to get the new IP from Belkin router.
Nov 07, 2017 | Belkin (F5D8231-4) Wireless Router...
Belkin mimo G network card
I think in your Pc Wireless lancard is disable,Pls enable the wireless lancard,
1. just check the lan card is enbled
example:my network place --right click---properties---wireless lan card,
2. check the R u getting ip address,
example: start---run---cmd----ipconfig
May 20, 2008 | Belkin Dual-Band Wireless A+G Desktop...
Belkin mimo network card
So are you saying that it's not showing any network on the view available network screen? What is the message on the screen?
What is the model and brand of your wireless router from talk talk?
Its possible that we may need to check the wireless settings inside the wireless router. Provide me with it's model no. and I will look for a solution for you.
May 20, 2008 | Belkin High-Speed Mode Wireless G Notebook...
Belkin (F5D7011) 802.11g/b Wireless Adapter Logo
448 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
