Question about Sony Playstation 3 (PS3) Console
My ps3 has a weird problem. it turns on and boots ok, but after startup when i press ps on the controller,it starts scanning the menu automatically until it stops on "turn system off". pushing ok shuts the system down. this also happens on the game menus. it scrolls through the menu automatically and won't let me start the game. anyone have an idea as to the cause ? scanning stops if the controller is unplugged. thanks.
    Sergeant:
  • 296 Answers
Your controller's left analog stick is broken.
Posted on Mar 25, 2011
What shall i do in "scanner error 13" in HP Laserjet Pro MFP M225dn ?
do a power reset to see if that will resolve the issue. With the printer still turned on, disconnect the power cable from the back of the printer. Then disconnect the power cable from the wall outlet. Wait 10 seconds and reconnect the power cable back to the wall outlet first, then the back of the printer and power it on again.
Make sure the printer is connected directly to wall outlet. (don't use a power hub or a surge protector)
Try and print a hardware self test. Disconnect any cables on the back of the printer except the power cable. Follow these steps:
  1. On the printer control panel, press the Setup button.
  2. Use the arrow buttons to select the Reports menu, and then press the OK button.
  3. Use the arrow buttons to select the Config report option, and then press the OK button.
Did the hardware self test print?
Now try and make a copy. Did it copy successfully?
Reconnect any other cables again to the back of the printer.
Now try and do a scan through the software.
Did it scan successfully?
If you are still having issues then please follow the steps below:
  • Go to the Start menu and select run.
  • Type services.msc and click OK.
  • Locate the 'Shell Hardware Detection' in the list. If it is not enabled/started, Make sure to enable/start the service. Also make sure the Startup Type set as Automatically from its properties.
  • Locate the 'Windows Image Acquisition (WIA)' in the list. If it is not enabled/started, Make sure to enable/start the service. Also make sure the Startup Type set as Automatically as well.
  • Locate the 'Remote Procedure Call (RPC)' in the list. If it is not enabled/started. Make sure to enable/start the service. Also make sure the Startup Type set to Automatically.
Dec 05, 2016 | HP LASERJET PRO MFP M225DN
Menu/option screen will not show
Jay, this is a weird message to get, but not uncommon. This only pops up for 2 reasons. First, if you did a reset to your system or added/replaced the hard drive(HDD) Second, if the system is having trouble recognizing the controller. Remember, the controllers for the PS3 are "Bluetooth" and has to sync with the system like all other "Bluetooth" devices, but can be wired and act like the old school controllers. It commonly asks you to connect the controller if you do a startup in "safe mode". If you did a reset, or installed a new HDD, then it may put you automatically in the "Safe mode" menu, where you HAVE to wire the controller. Good luck! Hope this helps. ^^
Sep 08, 2015 | Sony Playstation 3 (PS3) Console
My ps3 turns on and shows the wavy background for the home menu screen but no menu icons show up. Nothing on the controller changes anything and icons never come up. The wavy colored background is there...
This problem is because your PS3 software has become corrupt. The following steps will cure the problem but you will lose saved games and all other data. Your trophies will not be affected as these are stored by the Playstation Network.
Step 1. Turn your PS3 onto standby (Red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, beep 5 seconds later then beep once more 5 seconds later and then turn back to standby. Release the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and then beep twice quickly. Let go of the power button as soon as you hear these two beeps.
Step 4. The PS3 will start up asking you to plug in a controller with a USB cable and press the PS button. Do this and it will boot into the recovery menu.
Step 5. Choose option 5 (Restore PS3 system). This will re-install the PS3 software and restart the console.
Step 6. When the PS3 restarts you will be asked to enter the time and date and other information. When the setup is complete your PS3 will boot into the home menu normally.
Hope this helps
Aug 11, 2010 | Sony Playstation 3 (PS3) Console
My ps3 controller does not want to sync to the console. the lights blink when i press the ps button and doesnt connect; only with the usb. but when i disconnect the usb, it loses the connection again. i...
This is an issue since 3.10 update...MANY MANY people are having this problem. Try turning off console then turning console on by hand and waiting till its booted to turn on controller. eventually it will work, but its only a temporary fix, hopefully sony will respond to this problem soon
Dec 04, 2009 | Sony Playstation 3 (PS3) Console
Ps3 dead after firmware upgrade
You are going to have to upgrade the firmware manually..download it with your computer to a external hard drive.from the playstation website...then plug it in to your ps3.. it should upgrade automatically..
then if you say nothing happens you mean like black out??
if so then try doing this recovery boot.
Access the PS3 recovery menu
1. Turn off Playstation2.gif®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
..I did this and i got my ps3 Back !! :)
be patient and wait for those beeps.. they are important
Please let me know if i helped you at all please vote.. thank you
Jul 15, 2009 | Sony Playstation 3 (PS3) Console
Wont play when i insert disks only the games on there
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu.
I did not have problems with the normal movie DVDs or movie Blu Rays. Those were working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
5. You will be prompted to plug in your controller via USB and then hit the PS button
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 18, 2009 | Sony Playstation 3 (PS3) Console
Will not load games
I had a similar problem. My PS3 did not load the disk based games. Those disk based games were not visible in the game menu.
Jun 14, 2009 | Sony Playstation 3 (PS3) Console
Will not load games
I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
MY PS3 DOSENT READ MY GAMES
Dec 24, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont load games up
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
Nov 18, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
83 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
