Question about Galileo (G118DX) Telescope
I got a FS120 Refecting telescope. One of the counter weight rods has the threads broken off of it. Where can I get another counter weight rod?
  • 3,186 Answers
Contact Galileo telescopes, or have one MADE by a machine shop.
http://www.galileosplace.com/
Posted on Mar 25, 2011
Could the spinning barrel be off center,what has come off?
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
Mar 19, 2015 | Washing Machines
Machine goes out of balance & vibrates on spin cycle
How do I fix the last few seconds of spin that vibrates off balanced and aloud noise.
Sep 23, 2014 | Samsung WF419AAW 4.3 cu. ft. Front Load...
I have a Samsung washer model number wf338aab/xaa my tub is off balance
Sep 17, 2014 | Samsung WF328AAW Front Load Washer
Why is my basket leaning to the side on my easing machine
Sep 06, 2014 | GE Washing Machines
Attachment for balance weight is broken
What model is it? Where on the rod is the break? Most of these counterweight rods just screw in to the mount. If you can extract the broken bit, and have a metalworking shop cut a new thread on the end, you are good.
Mar 22, 2014 | Optics
Delta 10" bench saw
Just a point, counter-clockwise should lower the blade.
Look under the saw while turning the handwheel, if the threaded rod is turning you have an issue with where it threads into the motor block. If the threaded rod is not turning you have either a broken handwheel or the pin on the threaded rod is broke or fell out.
Mar 06, 2012 | Delta TS200LS Shopmaster 10 Inch Portable...
I have a tasco luminova 900x114 telescope and seem to have a problem balancing it. The counterweight seems too light and the scope falls away even with the weight right at the end of the rod? have you ever...
Possibly they included the wrong size counter weight? Normally you can balance the scope with the counterweight included with the scope.
There are TWO balance directions-
One uses the counterweight--
The other depends on the position of the TUBE in the scope rings front to back. BOTH directions should be in balance.
Mar 15, 2010 | Tasco Luminova 40114675 (675 x 114mm)...
How do i adjust rotisserie counter-weight?
Once I have the meat on the spit rod and in the forks, I will lay it on the brackets on the grill and turn it by hand. You can feel when the heavy side of the spit rod rolls down. Put the counter weight on the opposite side (up side) and adjust the weight up or down until it turns evenly.
Dec 26, 2009 | BBQ Guys BBQ400C/G42 Grill
I have a Meade ETX 60. The internal threaded rod that focuses the telescope is broken. Can I get a replacement ? I already have this taken apart and have removed the rod.
You can call Meade, they might sell you a rod??? Usually they want you to send the scope back to them for repair.
http://www.meade.com/support/index.html
Nov 08, 2009 | Meade ETX-60 AT Telescope
Galileo (G118DX) Telescope Logo
152 people viewed this question
Top Galileo Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Galileo Optic Expert? Answer questions, earn points and help others
