Question about kawasaki Garden
Removal of drive pulley from camshaft on kawasaki fd590v engine in JD tractor
5 Suggested Answers
crayzeetrayn
  • 837 Answers
SOURCE: replace motion drive belt garden tractor craftman 917273080
On what make and model riding mower ..
Posted on Jan 19, 2009
  • 71 Answers
SOURCE: I have a JD 320 hydrowith a Kawasaki FD590V
check all wiring and make sure there are no shorts especialy at key switch also blade and seat safety switchs it could be grounding (question does it backfire at all?) if so is it from carb or out of the exhaust. one more tip the flywheel keyway also servs as a timing pin if it is worn replace it with a new one.. they can cause a multitude of problems if they are worn even the slightest wear can cause it to start hard and other wise run sometimes very well .
point is for under a dollar you can rule it out and possibly eliminate the problem at the same time good luck hope this was helpfull and you can get it going good if i can be of further help e mail me mrdmburns@cableone.net
Posted on May 02, 2009
  • 61 Answers
SOURCE: No spark in JD lawn tractor engine
it could just stuck, loosen see if moves reset points.
Posted on Sep 07, 2009
  • 6 Answers
SOURCE: drive belt is too loose, already replaced belt and
I had the same problem with my Craftsman Lawn Tractor. The Drive Belt (which is not adjustable) is only engaged when the Brake Pedal is released (the Brake Pedal is located on the left side of the tractor, near the foot rest on my Tractor).
The Symptoms: My Tractor lacked driving power, and would not go up an incline, but the mower deck was powerful and working fine, even though the Tractor seemed to lack power and moved slower than usual, and would not travel up an incline.
I too, changed the Drive Belt, which initially seemed to help somewhat for a very short period of time, and then the same, lack of power problem, re-appeared again. The belt was not the problem, but only seemed to work somewhat due to the rougher texture of the belt's surface against the pulleys.
I also changed the Plastic Clutch Pulleys that engage the Drive Belt, thinking that they may have been worn down to a point that the Drive Belt could not fully engage with these Pulleys. No Luck.
NO ONE, NOT EVEN SEARS ON-LINE REPAIR ADVICE CENTER HAD A SOLUTION. THIS WAS VERY FRUSTRATING INDEED.
There had to be a solution: After much investigation, I eventually discovered the problem, which actually was easy to solve, and I would like to share this simple solution with others facing this same Frustrating Problem.
The Brake Pedal, when released, causes the Drive Belt Clutch Pulleys to move, and thus Tighten the Drive Belt. When you look under the Tractor, there is a Protective Metal Plate mounted to the Bottom of the Main Tractor Frame which covers the Brake Pedal Shaft and attached Mechanisms. Over time, Grass Builds up in between the Protective Metal Plate and the Tractor's Main Frame Deck, creating a very narrow space between these two pieces of metal.
This area is very difficult to get at, and almost impossible to clean out. Over time, Grass Clippings accumulate in this hidden area, and harden to an almost rock hard clump.
These Hardened Clippings accumulated between the Brake Pedal Mechanism and its fully released metal stop position. Thus, preventing the Brake Pedal Mechanism from moving to its fully engaged position.
I used a long screw driver to break up the compacted grass clippings, and an Air Compressor Blow Gun to break up the packed grass and blow the area clear. It takes awhile to do this cleanup, and is a bit messy, so do it outside, but be patient, and be sure to clean out all the grass that is lodged in this hidden area.
What was happening was that the Packed Grass was so dense that the Brake Pedal could not Fully Release, thus only Partially Engaging the Clutch Pulleys and the Drive Belt, hence the appearance of a loose Drive Belt even when the Brake Pedal was released.
Once the Packed Grass Debris was cleaned out, you will immediately notice the Drive Belt being tighter than it was previously when the Brake Pedal is released, and when you test drive the Tractor you'll find that everything works perfectly, like it was brand new.
Good Luck...
Rayko
Posted on Nov 15, 2010
No valve movement on 320 John Deere lawn tractor.
the jd 320 lawn tractor is fitted with a 2 cylinder water cooled vertical shaft Kawasaki engine
parts numbered -j59051 and , I 59051 show it as a gear driven cam shaft
I would be looking for the rocker arm bolts loose /stripped, bent push rods or the key or the key that drives the crank gear has sheared
May 02, 2017 | Cars & Trucks
Wiring harness
look underneath did drive belt snap in two , rear has white plastic fan on top of it that should be rotating with engine running if not yep you broke a belt , don't know about wire could it be from front PTO they are electric so it will need a wire ,one possibility is that drive belt broke slapped front PTO and broke off wire , that musta been some snow your pushin ooh and a reminder never push a hydrostatic drive tractor without pump turning it will dammage it
Feb 08, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
Need to know the amount torque for the rods in the fd590v
Oh, I see. It is a Kawasaki engine, probably used on one of those Zero Turn mowers, right? OK. Well after researching that particular engine I have come up with this:
http://outdoorpowerinfo.com/engine_specs/kawasaki_rod_torques.asp
It is 180/inch lbs. or if you prefer....15 Ft/Lbs. of Human assisted torque....for the rods.
Jul 04, 2011 | Garden
1977 ford pinto timming marks
Hope this helps. Please don't forget to rate....thanks!
Crankshaft, camshaft, and distributor timing marks-2300 cc engine (© Ford Motor Co.)
On 2000 cc engines, turn the crankshaft until the two round locating holes in the camshaft pulley are visible from the rear side of the pulley, looking forward from the left-side of the car. When these two holes are parallel to the ground, the timing pointer on the crankshaft pulley should point to TDC. If the drive belt is dislocated, the crankshaft damper will be retarded or advanced 19° per cog on the belt.
If the engine you are working on does not have the two locating holes on the rear side of the camshaft pulley, then you will have to remove the drive belt cover and observe that when the crankshaft timing marks are aligned to TDC of the compression stroke of the No. 1 cylinder, the distributor rotor is pointing to the index mark on the upper lip of the distributor housing which coincides with No. 1 spark plug tower, and the pointer on the camshaft pulley is aligned with the index mark on the cylinder head.
On 2300 cc engines, there is an access plug provided in the cam drive belt cover so that the camshaft timing can be checked without removing the drive belt cover. Remove the access plug, turn the crankshaft until the timing mark on the crankshaft damper indicates TDC, and observe that the timing mark on the camshaft drive sprocket is aligned with the pointer on the inner belt cover. Also, the rotor of the distributor must align with the No. 1 cylinder firing position.
CAUTION:
After any procedure requiring removal of the rocker arms on the 2300, each lash adjuster must be fully collapsed after assembly, then released. This must be done before the camshaft is turned.
Checking 2000 cc overhead camshaft timing (© Ford Motor Co)
May 08, 2011 | Ford Mustang Cars & Trucks
Aligning the valve timing mareks except twincam engine
Timing Chain, Sprockets, Front Cover and Seal REMOVAL AND INSTALLATION Crankshaft Damper and Front Oil Seal
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Accessory drive belt
    • Cooling fans
    • Crankshaft pulley and damper, using a holding fixture as shown
    • Front crankshaft seal Fig. 1: Crankshaft pulley removal tool - V8 9301jg12.gif
    To install:
  3. Install oil seal replacer tool JD-235 to the oil seal. Use the nut and bolt provided with the tool to fully seat the seal to the timing cover.
  4. For dampers which DO NOT utilize a spit locking ring:
    1. Apply a thin, even coating of Loctite® 648 to the damper bore. Do not apply it to the end faces or to the crankshaft.
    2. Install the crankshaft damper onto the crankshaft. Wipe off any Loctite that has squeezed out from the front of the damper.
    3. Install the locking tool to the damper. Tighten the bolt to 59 ft. lbs. (80 Nm), plus an 80 degree turn.
  5. For dampers which utilize a spit locking ring:
    1. Install a new O-ring seal to the damper.
    2. Install the crankshaft damper.
    3. Apply petroleum jelly to the damper bore and O-ring seal.
    4. Install the damper onto the crankshaft.
    5. Install the split locking ring onto the crankshaft, inside the center bore of the damper.
    6. Install the locking tool to the damper.
    7. Tighten the damper bolt to 266-285 ft. lbs. (364-386 Nm).
    8. Remove the locking tool from the damper.
  6. Install or connect the following:
    • Cooling fans
  7. Start the engine and check for leaks.
Timing Cover
  2. Drain the cooling system.
  3. Remove or disconnect the following:
    • Upper radiator hose
    • Water pump pulley
    • Accessory drive belt tensioner
    • Idler pulley
    • Crankshaft damper
    • Engine appearance covers
    • Mass Air Flow (MAF) meter
    • Air intake assembly
    • Ignition coils
    • Canister purge valve
    • Valve covers
    • Variable Valve Timing (VVT) solenoids
    • Engine harness retaining clips
    • Timing cover
    To install: Fig. 2: Sealant application points - V8 9301jg23.gif
    Fig. 3: Timing cover torque sequence-V8 9307jg01.gif
  4. Apply sealant to the 8 joints on the engine face as shown.
  5. Install or connect the following:
    • Timing cover with new seals. Tighten the bolts in sequence to 96-120 inch lbs. (11-13 Nm).
    • VVT solenoids
    • Valve covers
    • Ignition coils
    • MAF meter
    • Crankshaft damper
    • Idler pulley
    • Water pump pulley
  6. Fill the cooling system.
Timing Chain 6 CYLINDER
    • Valve cover
    • Timing chain cover
    • Variable Valve Timing (VVT) sensor
    • Crankshaft Position (CKP) sensor
  3. Rotate the crankshaft until the triangular arrow indent on the driveplate is visible through the access hole.
  4. Install the Crankshaft Setting Peg JD 216 into the CKP sensor location.
  5. Install the Camshaft Locking tool JD 215 on the camshafts.
  6. Remove or disconnect the following:
    • Camshaft sprocket mounting bolt by loosening it
    • VVT mounting bolt by loosening it
    • Camshaft Locking tool JD 215
    • Primary timing chain tensioner and backing plate
    • Primary timing chain guide
    • VVT unit and exhaust camshaft sprocket
    • Secondary timing chain tensioner and guide
    NOTE: Keep all valvetrain components in order for assembly. To install:
  7. Prepare the timing chain tensioners for installation by using a paperclip or other wire to unseat the check valves and compressing the pistons into their bores.
  8. Install or connect the following:
    • Secondary timing chain guide. Tighten the bolt to 89-124 inch lbs. (10-14 Nm).
    • Secondary timing chain tensioner. Tighten the bolt to 89-124 inch lbs. (10-14 Nm).
    • VVT, secondary timing chain and exhaust cam sprocket
    • Primary timing chain guide. Tighten the bolt to 10-12 ft. lbs. (13-16 Nm).
    • Primary timing chain tensioner and backing plate. Tighten the bolts to 89-124 inch lbs. (10-14 Nm).
    • Primary timing chain slack, eliminate it by placing a wedge between the primary timing chain tensioner and the guide shoe
    • Secondary timing chain by applying counterclockwise force to the exhaust camshaft sprocket. Fig. 4: Apply force in a counterclockwise direction when tightening the sprocket mounting bolts - 6 cylinder 9301jg03.gif
    • Exhaust and intake VVT sprocket bolts. Tighten them to 85-92 ft. lbs. (115-125 Nm).
  9. Remove the tools and wedges.
  10. Install or connect the following:
    • CKP sensor
    • VVT sensor
    • Coolant outlet pipe
    • ECT sensor connector
    • Radiator and heater hoses
    • Valve cover
  11. Fill the cooling system.
  12. Start the engine and check for leaks.
Jan 28, 2011 | 1999 Jaguar XK8
Replaced Mower Deck Drive Belt. Belt runs from Engine pulley to Mower deck Pulley. Purchased new belt rom JD dealer. Belt is slack, Is there suppodes to be a tensioner for this belt.
Yes, there is an idler arm with a pulley that presses either inward or outward against the belt to tension it. In some JD mowers, the arm is tensioned by pulling on a long metal rod that latches near the edge of the mower deck, but without the model number I can't be more precise about that. Just look for that extra pulley and arm it's mounted on -- you'll see a tension spring, and you should also see a way to pull the arm away from the spring to place it under tension. Good luck!
Aug 15, 2010 | Garden
09 JD X 340 27hp Kawasaki eng\ surges
Hi
That is a fuel problem caused by stale gas you will need to remove and clean the carb with carb cleaner.
Sam
Jan 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
JD mower L110, hydro drive. Reverse power is low.
i have the same thing a tractor shop told me thats ok they are slowed dowm for saftey
Nov 01, 2009 | Garden
Valve tapping in Kaw FD590V
I found a maual online at:
www.scribd.com/doc/8567778/Kawasaki-Gas-Engines
Jun 15, 2009 | kawasaki Full Suspension Mountain Bike Men
I have a JD 320 hydrowith a Kawasaki FD590V engine. I checked the coils,replaced the fuel pump and cleaned the carb,and you have to choke it t get it started and it will only run for a min. or so.
May 02, 2009 | Garden
Garden Logo
275 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
