Question about Dewalt 18v Battery Hammer Drill Dcd950 Dc925
The reverse button is stuck . how do I release it.
  • 31 Answers
Check this site.http://philippines.rs-online.com it might help you..
Posted on Mar 25, 2011
Singer sewing machine model 2639 will only run in reverse -- button doesn't seem to have any effect
Sounds like your reverse switch is stuck. I would work it up and down or front to back and see if it releases.
Oct 21, 2017 | Singer Sewing Machines
Singer Quantum CXL: After I use the reverse button and release it, the machine does not go back to stitching forward. It stays "stuck" in reverse until I turn it off and back on again. :-( ?
the reverse mechanism is not releasing to go back to its normal forward position. if you do not have pressure on the reverse button and it feels like there is some slack with no tension on the button, the mechanism has not returned to the forward position. there may be a spring that has the end broken off to keep tension on the reverse mechanism,, it would be a good idea to have the machine checked to see what the problem is.
Jun 02, 2015 | Sewing Machines
My riccar 707 is stuck in reverse. stitching,what is the. problem.?
Most machines have a button that is on the front of the machine. It is located on the front with machine with the stitch selections. The button is pushed in. Push the center button again and if that doesn't work, push the outer edge of the button and it will release.
Mar 02, 2015 | Riccar Sewing Machines
2010 dodge grand caravan stuck in park with engine on
Check your brake lights, if the system doesn't get a brake lights on signal it will not release park, it is called the park lock system.
Nov 01, 2012 | 2010 Dodge Grand Caravan
2006 ford focus automatic transmission doesn't engage its stuck in reverse and is not able to start
look on side of shifter see if there is an emergency release button on it some where
Sep 25, 2012 | 2006 Ford Focus
Husqvarna Model 6360 reverse button stuck
This problem comes about due to lack of useage usually. If the machine has been sitting for some time the grease inside hardens. The stitch length regulator, the pattern selector and the buttonhole mechanism could all be contributing to your problem. To fix it properly all three dials should be remove from the machine, disassembled cleaned, assembled and oiled lightly with a teflon lubricant. Since so much is removed from the machine doing this job, every setting in the machine is checked and or reset. It's a major overhaul and costs about $350 and only a handful of Viking Techs in the country can do it.
Sep 19, 2009 | Husqvarna Sewing Machines
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Husqvarna Viking Sweden Model 6030
On all sewing machines there is a button or lever which makes the machine go backward. The button could be stuck, if so put a drop of oil on it and try to release it. If there is a lever that has been raised which puts the machine in reverse, simply lower it to the lowest position. This should solve the problem.
Zelma
Nov 29, 2007 | Husqvarna Viking 1
Reverse only?
I too just aquired a husqvarna viking 6030 that was stuck in straight-stitch reverse. No forward, no zig zag, no button hole, no cam stitches. I also suspected a broken spring, since the reverse button was slack and had no resistance. But after inspecting every moving part, I realized it was just stuck from many years of non-use. I finally got it free today! I had used some Tri-Flow oil and applied it sparingly to all moving points (but not belts or motor). I exercised all the buttons and like another poster (either here or elsewhere, not sure) I used my hair dryer to apply heat to the inside of the machine through the cam slot. After you remove the white cover on back of machine that holds the two spool spindles, you will see a formed aluminum part just behind the reverse dial that has a rounded-pointed protrusion which sort of looks like a fat flat head screwdriver. It is supposed to travel in an up-down motion when reverse button is pressed. I used a flat head driver to coax its movement, and once it began moving, I continued with heat and drops of oil. Good luck.
Nov 11, 2007 | Husqvarna Viking 1
Stuck in reverse
The reverse button is attached to link that moves a lever to make the machine sew in reverse. The lever is spring loaded so it returns to forward sewing when the button is released. Either the spring has come off or there is a bind in the lever(oil it). In order to solve the problem, the covers must be removed.
Oct 26, 2007 | Kenmore 15208 Mechanical Sewing Machine
Dewalt 18v Battery Hammer Drill Dcd950 Dc925 Logo
67 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
