What type of fuse does the vector research vr-5000 receiver use in the ball joint antenna on the rear of the receiver?
  • 11 Answers
SOURCE: Remove Upper/Lower Ball Joints
The only way is to press them out with a press, and press the new ones in. I have seen people try to press them out with a vise and a socket against the balljoint and it did not work, a local machine shop or repair shop should have a press.
Posted on Oct 13, 2008
  • 63 Answers
SOURCE: Six hours to replace '05 Dakota lower ball joints?
well when you get a estimate they go by a general book time that it should take they are usally over by an hour or so but not very far off. you could try your self and see how long it takes
Posted on Mar 20, 2009
SOURCE: How do I fix the rear the ball joint on a 2004
yes you can fix it and it is easy. i just finished doing the job and it took me under 3 hours. rent the tool from (ball joint presser) from a local auto parts place. make sure you get the kit with a lot of accessories. you dont have to take off the control arm. once you initially unseat it it moves out easily. you might have to readjust the tool if it bottoms out.
Posted on Jul 20, 2009
SOURCE: what is the process to replace the ball joints in
The upper ball joint is an integral part of the upper control arm and the lower ball joint is an integral part of the spindle.
Posted on Oct 15, 2009
  • 140 Answers
SOURCE: how to replace upper ball joints
I suggest you take this to an auto mechanic for your brand of car. Don't attempt to do it yourself. If your car is rare, they will have to get a best fit for it.
Kind Regards
Posted on Oct 19, 2009
How do I get an antenna for the FM connection?
You can use an old rabbit ears style antenna or go to a radio shack and get a flat ribbon style. If you're close to the radio stations a single section of wire about 2 feet long connected to one of the antenna screws will work too.
Jan 03, 2016 | Kenwood Av Surround Receiver Vr-307
Vectors in two dimension,how do i approach them?
Just add the three vectors together. The first vector is 0.0i + 4.0j . The second vector is about 1.4i - 1.4j . The third is about -0.7i - 0.7j .
Adding the three vectors together gives about 0.7i + 1.9j .The exact answer is sqrt(0.5)i + (4.0-3sqrt(0.5))j .
Mar 15, 2013 | Camping, Backpacking & Hiking
How do I find ball joint for 2001 lincon conntintal
according to rock auto you use a strut and upper ball joint for the rear suspension.
look this up in their online catalog k500208 shows for the rear upper joint, 40015 passive rear strut, 40014 semi active rear strut.
i am not completely sure, please re check my lookup.
best of luck.
Sep 04, 2012 | Ball Joint, Tie Rod, Pitman Arm Seperator...
How to remove upper and lower ball joins on a 4x4 bronco full size 1986
For Lower & Upper Ball Joint Step by Step :
For That you use a C-clamp style ball joint press to remove the ball joint from the suspension arm-note the location of the receiver cup ! For installation of the ball-joint, use the same tool when pressing the ball joint into the suspension arm-again, note the location of the receiver cup.
Step by Step :
  1. Raise and support the vehicle safely, with jackstands.
  2. Remove the spindle and the ball joint assembly from the vehicle.
  3. Remove the snapring from the ball joint. Using a ball joint removal tool, remove the ball joint from the spindle. Do not heat the ball joint or the axle to aid in removal.
  4. Installation is the reverse of the removal procedure. Torque the ball joint stud nut to 85-110 ft. lbs. for 1983-89 Ranger and Bronco II.
    Please Rate, Thank you !
Aug 13, 2010 | 1994 Ford Bronco
2001 Sebring Sedan LX, 2.7l V-6, VIN Code U Lower balljoints: Can the front left and right lower ball joints be pressed into or out of the lower control arms on this vehicle? I'm being told by my mechanic...
Sounds odd... Rikkalan,
(but it appears AMAZON agrees with your mechanic)
Just go to ROCKAUTO and look up your parts...
If the entire arm needs to be replaced the separate ball-joint will not be listed...
Hope this helps!!
RockAuto Parts Catalog
2001 CHRYSLER SEBRING 2 4L L4 DOHC Ball Joint RockAuto
Mar 03, 2017 | 2001 Chrysler Sebring
How to remove wiper arms from a 2002 Saab 95
The way that I do it is to purchase a ball joint removal tool (looks like a big tuning fork) (about $10) and then put this under the wiper arm with card board underneath. Be careful of the wind screen. Hit with rubber mallet after taking nut off. Should work.
Dec 30, 2009 | 2008 Saab 9-5
Antenna
You can use any indoor TV antenna for the FM section. I've been able to pick up local stations with two pieces of wire (about 30" long) attached to the antenna terminals (other end not connected to anything) and arranged so they angle away from each other. If you want a more sensitive antenna, you can make it using twin-lead cable. See the link below. I've done the math for you: the half-wavelength figure to use is 5 feet; this is for the middle of the FM band in North America.
The AM section usually operates with an antenna coil, either permanently attached to the back of the receiver, or mounted inside.
simple efficient TV antenna
Nov 22, 2017 | Kenwood VR-7070 Receiver
Vector Research VRX-9200R
Several sites I found all put the thing around mid to late 1980's manufacture, but I couldn't find a manual either.
As to the original problem: If the previous owner was having shutdown issues and you aren't, the trouble might not be in the receiver at all. Most receivers have protection circuits to shut them down before they are damaged by speaker problems. (I say most because I have seen some cheap ones that didn't bother, and when things went wrong they really smoked!) He might have had bad speakers or wiring, so that at higher power levels the receiver would shut off. If you're not having any problems, you might just have gotten very lucky in your find. Just keep using it.
Nov 13, 2008 | Audio Players & Recorders
131 people viewed this question
 Grubhead
Grubhead
