Question about Seiko Mantel Clock
I have a Seiko Westminster-Whittington Chiming Clock from 1982. It takes 2 batteries, C battery activates the rotating cylinder and the AA actiavtes the quartz clock. The clock chimes on the 15 min mark and the hour but I cannot get the hour chime to be the correct number. There is an AM and PM button but I'm not sure what function they serve. Thanks for your help. deerrabbit2@suddenlink.net
3 Suggested Answers
SOURCE: Seiko Westminster Chime Clock; Model No. QQF150G Caliber 12105
Does this help
http://www.theclockdepot.com/seiko_westminster_clock_instructions.html
Posted on Apr 22, 2009
  • 2501 Answers
SOURCE: Because we put our Seiko
I have seen a similar type of clock whos' owner wanted to silence the alarm and I found that there was a small switch (unmarked) which turend off the striking feature.
Perhaps yours is the same; look for a switch on the back or the bottom.
Posted on Mar 15, 2011
How can I completely silence the chimes of the Seiko Westminster Whittingham wall clock?
I looked this up, not sure if yours runs on batteries, but here's a step by step to the chimes.
http://blog.princetonwatches.com/how-to-setseiko-chiming-clocks/
Nov 14, 2015 | Home
My sterling and Noble westminster chime clock is not chiming. I have brand new batteries installed but still no chime
A handsome clock in solid red oak. The face is off white with a convex lens and a bright brass-toned bezel. The Westminster chime is pleasant sounding while counting the hours.
Runs on 4 AA batteries; two to manage the clock and two for the chime. The external speaker is located at the top of the clock for a clear, unimpeded sound. A button on the chiming unit allows you to control the striking of the hours.
You will see above that one set of batteries does the chime. Make sure they are good and inserted with correct polarity.
As mentioned, look for a button switch to turn the chimes off It is a feature so you can turn the chimes off when you go to bed.
Sep 14, 2015 | Home
Seiko westminster whittington
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Apr 05, 2014 | Home
Because we put our Seiko Quartz Westminster Whittington in our bedroom when we recently moved, we would like to know how to remove the chimes.
Mar 15, 2011 | Seiko Mantel Clock
I cannot figure out how to syncronize the time and chimes for a Seiko model AQF 153B with Westminster Whittington chimes.
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Feb 25, 2011 | Seiko Mantel Clock
How do i synchronize chimes with clock on westminister whittington clock .
The Westminster/ Whittington clock means that it has 2 or 3 settings.
1. Silent
2. Westminster Based on the music My redeemer liveth by Handel
3. Whittington
Set the clock onto the westminster setting, this is the easiest. At quarter past the hour it should sound 4 notes. The half past should be 8 notes. Quarter to the hour should be 12 notes and the hour should be 16 notes then the striking of the hour. For example on 8 'O clock you should hear 16 notes then the clock should chime 8 times. Sometimes if the hour is out just gently stop the pendulum, check what hour the clock is striking then without taking the hands off move only the hour hand to the hour. Do not do this with the minute hand.
I hope this helps you! If you are not sure please email me yvonne.finch@gmail.com I fix these clocks.
Apr 30, 2010 | Seiko Mantel Clock
Home Logo
186 people viewed this question
Top Seiko Home Experts
Jimmy Accardi
Jerry Greenberg
Jerry Greenberg
Are you a Seiko Home Expert? Answer questions, earn points and help others
