Question about Sony Walkman NWZ-B103F MP3 Player
Sony Walkman NWZ-B103F it wont open.. - Sony Walkman NWZ-B103F MP3 Player
  • 2,574 Answers
Check the unit after completing each step:
Confirm that the portable player is connected to a working USB port and that it is charging. If necessary, connect it to a different port. When connected properly, the battery icon will be animated or it will indicate the charge status such as FULL when charging is completed. Make sure that you are pressing the POWER button to turn the player on. Previous Walkman® models that did not have a power button would turn on by pressing any button. This model must have the power button pressed to turn it on.
Ensure that the HOLD function is not activated.
NOTE: For some models, when you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, continue with this procedure to reset the unit.
If the portable player is still not responding, reset it by pressing the RESET button with a small pin or similar object.
NOTE: When the RESET button is pressed, although the unit will retain the music data and clock settings, all other stored data and settings may be deleted. If the unit starts up after the reset, access the Settings menu and initialize the unit using the Format (initialize) function.
If there was no change after the player was reset, connect it to the computer and reset it again, leaving it connected.
Check the Sony Support Web site to see if there are any available firmware updates for your model. Updates can be found on the Sony Support Web Site.
If possible, instead of connecting the USB cable to the computer, connect it to a USB AC adapter (if available) and try to charge it.
Posted on Mar 25, 2011
Sony Walkman NWZ-B162F MP3 Player won't turn off
I was also facing the same problem, and while going with some hit and trials, was able to find a solution for this as following: power can be switched off by holding the main key for long, the key which is used to select the folders, that is, the center of navigation key. Hope it helps.
Jun 13, 2012 | Sony Walkman NWZ-B103F MP3 Player
I had my sony walkman nwd-b103f. when i connect it to the pc it say's usb device not recognized. plz help?
Please try these steps:
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
Thanks.
gylacz
Aug 25, 2011 | Sony Walkman NWZ-B103F MP3 Player
My Sony Walkman NWZ B153F is freeze on fm radio. I cannot turn off, do enithing.So? Thanks!
Carlos Barrera Chaupis on Walkman NWZ-B153F:
I used to have the same problem. But the freezing can also happen when you try to turn it on. You may also eventually have problems while trying to copy files from your computer to the device. A little window appears saying the copy couldn't be accomplished because the devise just turn itself off. (?)
Feb 25, 2011 | Sony Walkman NWZ-B103F MP3 Player
My Sony Walkman ( NWZ-E435F) hanged. The screen shows "HOLD ON" . How do I solve this problem?
there is a slide switch on the right hand side you need to slide it up one click or 2 depending on what you want.
Dec 30, 2010 | Sony Walkman NWZ-B103F MP3 Player
My sony walkman shows boot error
hi ...... i have sony walkman nwd-b103f that problem is boot error plz solve the problem......
Sep 20, 2010 | Sony NWZ-B103FBLK MP3 Player
My sony walkman nwz b133f(b) wont start. when on, it says boot error... what should i do? do u have the firmware availble that i can download myself?
I had the same problem but i solved it.
Follow the folliwing steps.
1- Download firmware nwz-b133f (firmware nwz-b130 V-1.01)
2- Download firmware nwz-b103 (firmware nwz-b100 V-1.3)
3- First execute firmware nwz-b100 , connect your walkman when the programm
asks: please connect device. Then the program ask format your device
you will loose all the data , click accept.
4- Don´t disconnect your device , wait until format and dataload are finished.
This is necesary because firmware nwz-b130 doesn´t do the format.
5- Disconnect your walkman and you will see it doesn´t start (logical it ain´t his
firmware)
6- Now execute firmware nwz-b130 , connect your walkman when the programm
asks: please connect device. Don´t disconnect your walkman wait until program ends.
7- When finished disconnect your walkman the save way.
8- Ready like new.
Greetings Quicktronics here from Mexico.
Sep 11, 2010 | Sony NWZB133F MP3 Player
Error" Power off" walkman NWD-B103F
boot error power off walkman NWZ-B133F sony
Aug 30, 2010 | Sony Walkman Bean NW-E307 MP3 Player
I will lose all dirver of my walkman
i want some softwares or dirvers of the model number NWZ-B105F SERIAL NO.2153301
Apr 16, 2009 | Sony Walkman NWZ-B105F MP3 Player
Sony walkman doesnt turn on even if its not lowbat. what shall i do
Buggy firmware. Place a slim blunt object into the reset button on the back and turn on again. This happens regularly for me
Mar 20, 2009 | Sony Walkman NWZ-B103F MP3 Player
Broken walkman
well, my **** just fell off.
Jul 17, 2008 | Sony Walkman NWZ-B105F MP3 Player
Sony Walkman NWZ-B103F MP3 Player Logo
340 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
