Tv picture problem right side,tatung v37gcgi - Televison & Video
My Tatung plasma TV model no. P42hsmt when powered on shows green static no picture when changing channel screen turns to a strip of lines and returns to green spot static
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 07, 2015 | Tatung Televison & Video
Connect satellite to tatung P42BSKH
hi what sort of satellite box are you using if you have no hdmi use scart lead to av 1 or ext1 hope it helps
regards
shaun
Jan 17, 2014 | Tatung P42BSKH Television
TV TATUNG VC32GCG1- No picture or sound. Have checked all power sources to tv.
You already check the fuse inside near the power supply?Check also the power supply if they have power output.If power supply is good the problem is in the board.Need for repair and troubleshoot of authorized repair technician.
Jul 09, 2011 | Tatung Televison & Video
TATUNG P42HSMT
Also have a TATUNG P42SMT. Problem is the screen starts to turn green shortly after turning it on, then the screen goes black.
Sep 01, 2008 | Tatung P42HSMT 42 in. HDTV-Ready Plasma...
Tatung TV Video Combi won't play
You need to replace the motor belt charge maybe is on bad conditions.
Jul 24, 2008 | Televison & Video
TATUNG P42HSMR PLASMA TV
mine has a slight whistling sound coming out of it when the cable is on.
Feb 04, 2008 | Televison & Video
Is the iLO v23dlwx the same as the Tatung V23dlwx
www.polaroidsupport.com/polaroid/docs/FLM-3001ServiceManual.pdf
Nov 16, 2007 | Tatung V23DLWX Television
I have suddenly lost the picture on T.V. but still hear audio of program...
sounds like your input board went out. I had the same problem on the ILO version of this panel. Got a replacement part off of Ebay. Search for Ilo plasma on ebay and it will come up
Sep 08, 2007 | Tatung P42BSKT 42 in. HD-Ready Plasma...
TV has sound with no picture display
Is it possible the pip and the main picture have been swapp and the main picture is showing as the Pip?Is a possibility,check it out and let me know.
Sep 29, 2006 | Tatung V30DMTT 29.6 in. LCD Television
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
