Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
The timer on Gemini double gas oven is stuck on 12:00 hours. Can't reset.
fridgetech
  • 473 Answers
SOURCE: Cant cook in the oven! Gas Rangemaster double oven 110
Sounds like the oven ignitor is weak and not building up enough resistance to get gas flow.  I would replace the ignitor.
Posted on Oct 16, 2007
SOURCE: Maytag Gemini Gas Double Oven
turn off the circuit breaker for a minute or two -- or unplug the range.
Posted on Jan 18, 2008
huuum
  • 750 Answers
SOURCE: maytag electric gemini,model mer6755aaw
Hello bigboy1666,
Welcome to Fixya,
You said, Oven does not show any displace and does not work. When you try to turn on the top oven, the displace shows h3 132 and the clock shows 12:00 .
You try to turn the upper and lower oven, none of them work. The light in the oven comes on okay.
Lets try to reset the system.
trun off the range.
Now trhow the breaker in the electric box off for 5 minutes.
after waiting 5 minutes turn the power on and try the range!
Let me know how she works.
Huuum at your service.
Please remember to leave a rating!
Posted on Oct 06, 2008
mgprice
  • 744 Answers
SOURCE: Oven will not heat
Hello, your problem is going to be a bad igniter. you should replace it. Good luck! Mike
Posted on Nov 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: Maytag Gemini double oven flashes F1 and stops heating.
I am attaching a Gemini manual. The checking procedures are the same for your oven.
Two component suspects for your problem would be the door latch mechanisms and the oven temperature sensors.
http://www.servicematters.com/maytag_library/docs/16010161.pdf
Posted on Feb 03, 2010
Maytag gemini range
Don't keep resetting the breaker, you have a dead short and you could burn your house down, call an electrician.
Jul 22, 2016 | Maytag Gemini 30" Self-Cleaning...
My oven screen said stuck key.I cant use the oven what i should to fix it?
1st thing , unplug it wait a few minutes then reconnect it
2nd thing feel with your finger the tactile buttons on back for any of them that feel depressed or farther in than others , this is most likely your stuck key
Oct 20, 2015 | Maytag Gemini 30" Self-Cleaning...
I have a Maytag Gemini double oven and the right rear burner ignites but wont shut off?
Great move, you kept your domicile from exploding. It sounds like a bad valve but I am only guesing.
Nov 27, 2014 | Maytag Gemini 30" Self-Cleaning...
Maytag gemini electric ignition won't shut off
Your valve switches are defective. Sometime they will do that if you recently had a boil over and they have got wet. Try turning the breaker off for 24 hours to see if the fixes the problem.http://www.on-timeappliance.com/ovenrepair.html
Mar 27, 2012 | Maytag Gemini 30" Self-Cleaning...
My Maytag Gemini double oven gas...........the bottom oven won't heat up past 100 degrees. What can I do to troubleshoot?
Hi
This issue seems to be with the gas inlet valve or the igniter itself that is bad. Gas Valve has a bi-metal that open when a certain amount of current flows through it to heat it up. Make sure that the glow bar is not cracked. Faulty igniters can allow correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. Hope this helps... Please post back if you need more information.
Daniel
Jan 18, 2011 | Maytag Gemini 30" Self-Cleaning...
I have a Maytag Gemini double oven range and i can't find my manual - can you tell me how to use the timer for the oven?? Please help??
http://www.kitchenaid.ca/assets/pdfs/literature/8113P363-60.PDF
http://www.kitchenaid.ca/assets/pdfs/literature/8113p293.pdf
Nov 24, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Lost my manual. how do i clean my self cleaning Gemini double ovens
would need the model #, but generally, the top oven is manual clean. To clean larger oven, press clean, then up or down next to the timer to determine how long you want the self clean to run.
Nov 15, 2009 | Maytag Gemini 30" Self-Cleaning...
Jan 05, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
640 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
