Question about Kenmore 67632 Electric Dryer
Where would the # be located @ to c the brand dryer i have? i looked n the back i think i c the # 0252 on the top back left side directly behind the push to start button its an older dryer white with just the start button n the cycle button is all i have on this dryer
  • 96 Answers
Look on the door jamb
Posted on Mar 26, 2011
Where is the thermal fuse located on this dryer? please
Hello Leslie
I don't know what is the brand of you dryer. I will make you a preference this brand.
In GE dryers, the thermal fuse--sometimes called a safety thermostat--is located behind the drum on the inside of the dryer. To access the thermal fuse you will need to open the dryer from the top. Though it may sound a bit daunting, opening the top of the dryer to reveal its inner workings is surprisingly simple. To open the dryer top you will need a flat-head screwdriver, putty knife or similar tool. Insert the screwdriver or putty knife underneath the dryer's top panel. Slide the putty knife along the bottom of the panel until you locate the two clips that hold it in place. These clips are usually located about four inches in from either side of the top dryer panel. Apply pressure to the clips to release them. Once the clips have been released, lift up the top panel and use the supports to keep it upright. Look inside the dryer, behind the drum, to find what looks like a round metal pan. This metal pan is actually the dryer's heating element housing. The thermal fuse will be located next to the heating element housing. Look for a white strip with two wires connected to it and you've located the thermal fuse in your GE dryer.
Best Regards
Neciforo Llanto
Oct 01, 2013 | GE Profile DPSB620GCWW Gas Dryer
Tip
How to get help so you can fix you own appliance
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your model number is needed in order for someone to help with the diagnosis or your appliance. There are lots of different parts and each model is different. Post this number in the description of your problem and you'll be much more likely to receive the help you need .
It's usually stamped on a small tag in a visible location on your appliance.
On your refrigerator look
Behind the lower toe kick-plate, Behind the lower crisper drawer, On the face frame of the refrigerator body, Inside the refrigerator of freezer on the left or right side wall.
On your oven look Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} on the back side of the door at the bottom or edge. On the vent trim behind the center of the door.
Washer-Dryer
behind or on top of the control panel. Behind the door. On the lower front or side of the cabinet.
Dishwasher-
Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Microwave-
on the face frame behind the door or on the back.
on Jan 31, 2010 | Dishwashers
700 dryer maintenance
What information are you looking for exactly? Maintenance is basically cleaning the lint trap and making sure you have proper air flow out the back and through the ducting outside of the house. Are you wanting to take the machine apart and verify something. I'll post something for that but remember, if its not broke, don't fix it.
There are 4 different designs that used on these dryers and each one has its own specific way to access the element, blower, fuses. etc In this FAQ I will describe each design and method to access for each one. ---------------Design 1: This design for this dryer has the heating components located in the front of the machine, which means to gain access you'll have to lift the top and remove the front. You can visually verify this specific type because the lint screen is located inside the dryer requiring you to open the door to gain access to it. As with any do itself repair, always unplug the machine before you start. Here's the method of access listed in numerical order. 1) Remove the lower kick plate by pressing in the two clips, one on each side located in between the upper and lower portion of the front In doing this you'll gain access to the element, located on the right hand side facing, the high limit and thermostat fuse located on the element, the cycling thermostat, located on the blower housing, and thermal fuse, located next to the cycling thermostat. In gas models the gas coils and ignitor may be located on the left hand side facing. If changing the belt, rollers or motor, continue to step two. 2) Lift the top by placing a flat head screwdriver in between the front and the top of the dryer and pry it upwards. In some cases there are two metal clips, one on the left and one on the right, that need to be pushed forward to lift the top up. 3) With the top up and the kickplate removed take the door springs off, one on each side, and remove the door by taking out the 4 screws one upper left and right, one lower left and right, off and don't forget to disconnect your door switch-----------------Design 2 : In this design the heating components are located in the rear of the machine. All you have to do is get behind the dryer, remove the 9 1/4" screws and remove the panel. The element eill on the right had side with the two fuses located on it, the cycle and thermal fuse will be on the lower left on the blower housing. To access the belt, rollers etc, remove the lint trap on top, take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off.--------------Design 3 : In this design the components are located in the front of the machine, but to access them you'll follow the method used in design 2 for accessing the belt, rollers, etc.take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off. The set up will be like design one.--------------- Note: The best way to determine if your dryer is desgin 2 or 3, remove lint trap and pop the top. When you've got this done, you'll be able to look in between the inside rear wall and the rear panel and see if the element, fuses atc are there. If not it will be design 3---------Design 4 : HE, HE2, Duet, etc the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed. From there you'll remove the kickplate in come cases by taking the 3 or 4 screws off located at the bottom of the kickplate. With that removed you will be able to remove the front, but only after you remmove the control panel. The In some cases the components will be located in the rear like the second design.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 01, 2012 | Kenmore 73952 Gas Dryer
Disassemble kenmore 970c8810600 dryer
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else. If the dryer is a DUET or HE2 or HE3 style, (dryers that match the front loader) then the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed
May 10, 2012 | Kenmore Dryers
Where is the heating element located on the kenmore plus pdryer. I purchased it in 1982
on that vintage dryer the heat element was behind the rear panel. When looking at it from the rear with the back panel off it is inside of the housing on the right side. The way to remove it is to raise the main dryer top by removing the 2 phillips headed screws on the top where the lint filter fits and pop up and raise the top and from the front you can look behind the back wall the holds the drum up, from the front on the top of the housing the element fits(left side when looking at it from the front) will be a bracket that holds that heater housing to that rear drum support plate. Remove that screw(5/16th inch hexhead) and go to the back and pull housing out from top of housing then lift off from bottom.When reinstalling be sure the housing fits into bracket and the bottom of where it goes. To remove the element there will be one 5/16th inch hex headed screw at the bottom by where its opened. The part # for that style heat element is 4391960 it is available from your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
apwagner.com
midwestapplianceparts.com
Thanks for bring me back to the old days i started my appliance repair career a year before you bought that dryer (1981)
I hope this has helped you with your dryer,
Gene
Aug 13, 2011 | Dryers
YOU GUYS ARE THE BEST SERIOUSLY
UNPLUG DRYER B4 YOU START ANYTHING !you need a puttknife locate two clip on both side of the dry botton access panel push the blade in over the top of clip while pull on the left side dryer some time the clip are hard to let go,an if you got a old model you have to take the lint screen out of top of dryer take two screw out on front top of the front panel there two clip you use your flat head screwdrive are puttknife locate the two clip on left an right side of dry pop the top lift up an look down on the left an right inside dry there two 5/16 srew you got to remove an lift panel up an off. the gas coil should be locate on the left are right side of dryer depend on model
Apr 23, 2010 | Dryers
Where is the heating element on a amana dle dryer
Depends on the model. Usually on the back lower left side under tub or right behind the tub in the top center. The frist location you remove the front panel to get to element and the second location the lid has to be raised up
Mar 02, 2010 | Amana DLE330RAW Electric Dryer
Pop the top miele t9820 dryer gas
Open the door, at the top of the recessed door opening you will see two round plastic caps. Remove these and you will see screw behind that you have to remove. Some models the caps are on the right and left hand sides. Slide the top towards the back after removing screws and the top will lift off. Good Luck, Appliance Specialists
Jan 06, 2010 | Miele T9820 Gas Dryer
No heat
check your heating coils they are located behind the back cover
right hand side (if you are faceing it)
on my kitchenaid (behind the back cover) their is a long silver looking box with a small hole in the top look in the hole and you should see the coils (just remove the cover to get to them)
Jan 24, 2009 | Kenmore 62602 Electric Dryer
My dryer is no heating but everything else is working...
your in the wrong places,,since you have the top off thats good,,now from front look down inside dryer to the right and left sides you see to 2 screws remove ,,always unplug..remove the lid switch connection,,remove front panel get flash lite..and look in back rite corner..
Dec 06, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore 67632 Electric Dryer Logo
93 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
