NEED TO SOURCE NEW POWER BOARD DC-B87D1D-NB 9765458PA-D, FOR SANYO HV-DX300A DVD/VIDEO RECORDER/PLAYER
IF you still require this PCB the cost of postage is all I require
Posted on Oct 31, 2013
SOURCE: i need instructions to record
Connect the vcr to the dvd recorder via scart. Set TV to your usual dvd channel and power on dvd. Power on vcr and scroll through input channels (AV etc) on dvd recorder until you find the signal from vcr. Prepare the recorder ready to record, then play the vcr and start the dvd to record.
Posted on Sep 20, 2010
  • 102 Answers
SOURCE: Sanyo DP46849 composite video input malfunction
Sounds like a damaged port or related circuitry. You could take it to a repair shop if you really want to use that port, wouldn't cost too much
Posted on Feb 06, 2010
jdvillanueva
  • 2098 Answers
SOURCE: have sanyo vizon model #
Hi thomasdolle,
Sad to say that your Sanyo remote control is not compatible with Coby DVD player. Meaning it is not in the memory to operate the player. You may click this LINK to download the manual and see the compatible brand that will work to your remote control. This is written on page 13-15.
Thanks for using Fixya.
Jdvillanueva
Posted on May 05, 2011
electrotech1
  • 1126 Answers
SOURCE: I need a new remote
Go to this link for your remote: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=Vwm-290&uuid=13112154645910
Posted on Jul 21, 2011
  • 1684 Answers
SOURCE: My DVD player says "cannot
Check what type disk you are using that model only records to DVD-R disks not DVD+R
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Sep 08, 2011
I need a user manual for my sanyo HV-DX3E dvd/vcr combo player
there are only a couple ways you can hook it up and if you took the old tv off then you should have the cables you need
Feb 03, 2015 | Sanyo Televison & Video
DVD+R won't run on Sanyo DVW-6100
you need to burn the video on a memorex DVD-R disc and then it will play
Jan 20, 2013 | Sanyo DVW-6100 DVD Player/Video Cassette...
Need to download manual for sanyo dvdplayer& video recorder HV-DXY
Either contact Sanyo or Google the model number with "manual" to see if you can locate one.
Jun 16, 2012 | Televison & Video
LG RH2T80 HDD/DVD recorder dvd tray won't shut we have turned off the power and at the power point but it still won't shut. It sounds like something is locking or jaming. It goes a 1/3 of the way...
This is a common problem on this model LG RH2Txxx DVD Recorder unit.
Source and install a new DVD player/burner unit - cost approx $120.
Avail from :- http://spares.bigwarehouse.com.au/product_info.php?cPath=24759_24831_81108&products_id=1546447&s=lg%20rh2t250&n=1&pcid=2274323
Easy to self instal with basic repair knowledge (+ philips screwdriver).
Remove top cover screws and cover,
Unclip front plastic front cover, roll out of way,
Remove 4 mount screws of DVD player/burner unit,
Unplug ribbon cable and DC power connection to DVD unit.
Install new unit by reverse of above procedure.
Jun 04, 2011 | LG DR787T DVD Recorder
CD player idicates all disks "bad"
it's either the lense inside needs to be clean off or it really needs a repair.. it will not take much time if you bring it to repairshop..
Jul 29, 2017 | Sanyo HV-DX2E DVD Player/VCR
Someone made my video dvd combo black and white
It sounds like the video out put has been set to S video,go into the hv-dx300a menu and look for the video or picture out put settings and set to VIDEO or RGB, rgb is the best if it works for you.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | Sony DAV-SA30 System
Hi I need to unlock my Sanyo DVD player HV-DX350A
HI this works as i have unlocked my own Sanyo HV-DX350A player with it Hope it works for you
Unlock region code for Sanyo HV-DX350A DVD/Video player.
1. Turn on unit
2. Select DVD
3. Open tray
4. Press 0520 then in sequence press arrow up, down, left and right.
5. The region management screen is displayed on your monitor ( Code is displayed on the unit LCD display).
6. Note - Your current EEPROM region code setting is displayed on the screen.
7. Enter desired Region Code ( 0 for multi region).
8. Press PAUSE to exit.
9. Turn power off and turn on again.
If you repeat steps 1 to 4, you can view your new setting.
Feb 29, 2008 | Televison & Video
Televison & Video Logo
299 people viewed this question
Top Televison & Video Experts
