Question about Sony PlayStation Portable (PSP) Console
Psp disc problem
After inserting a umd the drive runs for a few seconds then stops. game never loads. have cleaned the laser. all other aspects of the psp work ok. ideas ????
  • 164 Answers
Take it to a shop
Feel free to Email me: Thomashedderwick@hotmail.com
Posted on Aug 22, 2008
Ello. My PSP won't read UMDs. The loading
Most likely the laser is weak. It has been awhile since I have changed a laser in a psp. But first off you should clean the laser with a q-tip and isopropyl alcohol and dry it with the other end of the q-tip. It doesn't take much for them to not be able to read a disc. If it still doesn't work you will need to replace the laser if you aren't that great at working on electronics or very small things you need to find someone to do it for you.
Nov 01, 2017 | Sony PlayStation Portable (PSP) Slim...
Can't read disc
the umd drive must be dying. You can replace the und drive.
One trick you can try is to put a little water on a cotton swab and clean the the laser.It just inside the psp where you put the umd drive. also try to move the laser all the way to the inside
Jun 08, 2010 | Sony PlayStation Portable (PSP) Console
Psp(1001)won't read umd games or movies
If your PSP isn't reading games and/or movies and the problem isn't that your trying to play dirty, bent, or damaged UMD discs there are a number of other reasons your PSP is not reading disks correctly =
- Your UMD motor may be malfunctioning.
- Your laser may have worn down from use over time.
- Your UMD drive tray may be bent.
- There may be a foreign object in your UMD drive
Common symptoms
* disks fail to load
* extremely slow loading
* strange whirring noise when trying to read disks
For whatever reason your PSP has stopped reading games and/or movies we will get your PSP back to you and playing like like new fast! Our price includes labor, parts, and return shipping via priority mail.
Visit PSP UMD Drive REPAIR if you are interested in an affordable and reliable PSP repair service. We have been serving the whole United States for more than 2 years!
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
Psp not reading umds
Your psp umd laser might be broke if you go to ebay.com and type in psp repair you will see people will fix them.
Nov 10, 2008 | Sony PlayStation Portable (PSP) Console
Psp error # 80010087 The game can not be started
Hi robbimic,
The first thing to check is the firmware of your PSP. You should make sure that your PSP has the latest firmware loaded. Because some games will not work or load up if the latest firmware is not installed or loaded up.
You usually get this error message 80010087 if the UMD drive has errors reading the UMD disc or otherwise the disc is not present or was ejected while in the middle of playing a game or loading a movie. I suggest that you try to testing to see if the problem happens with other UMD discs, if it doesn't then most likely the disc could be damaged or scratched.
Now if you are using a modded PSP then you will get this error if you load a game from the memory stick without having any UMD disc inserted in the drive. Or if the game that you are trying to load requires a higher firmware version installed into the PSP. You will be required to flash a higher modded firmware to fix this error if this is your case.
Hope this helps!
Peace! :)
Oct 21, 2008 | Video Game Consoles & Games
Help!
You might have PSP stop reading UMD discs, First you will do some trouble shooting with what might be wrong with your PSP unit.
first is the Disc Spinning motor. This will not let The disc in the UMD spin. On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
2nd is something stuck in the UMD gear, try to clean the gear of arm of dust, plastic, soda, and even hair.
and at the last is the actual laser itself. It will not focus the laser to read the UMD disc.
Hopefully this help, Pls post back should you need additional information...!
Jun 01, 2008 | Sony PlayStation Portable (PSP) Console
Psp and umd
Open the UMD door. You will see a large peg sticking up and behind it a small one. Press down on the small one, it is either Black or Gray. This is the senor switch that senses a UMD Disc is inserted. When you press this little peg down, look at the Laser to see if it lights up. If it does not light up. You need a New UMD drive. If it does light up. Press the peg down again, but this time look at the Spindle to see if it spins any at all. This is hard to see. If it does not spin in the slightest. You need a new UMD drive. If you do not have problem with lighting or spining, then get you a Q-tip and some Glass Cleaner./ Clean the lens on the laser.
Nov 29, 2007 | Sony PlayStation Portable (PSP) Console
PSP
Hi Voltagehog,
You need to look intothe UMD drive. Press the little Black probe sticking up in the UMD drive. It is about 3/4 inch from left and 3/4 inch from top of the UMD drive. When you press it, look for the Disc spindle to rotate, and the Laser to light up and the Laser movement to occur. This will tell you a lot in what is working or not in the UMD drive. If the laser does not move left and right, or light up, you have a problem with the laser. move it manually with a pen or something, Only click it a couple of times. Try the black button thing again. If the Disc spindle motor does not spin. You probably need a new UMD drive.
If you need a new UMD drive, click on "repair directory" at the bottom of this screen, Click on Video game Consoles. Pick out a good service out. I know one of them specializes in Playstations.You can get a new UMD drive replaced for under $60.
Nov 15, 2007 | Sony PlayStation Portable (PSP) Console
Psp
Hi Jleew,
You should check to see if another UMD will work first.  Also try them in another PSP.  If your sure your PSP is not reading Discs, then and only then, Clean the Laser lens carefully.  Using a strong flashlight and magnifying glass, look into the UMD drive with the UMD door open and look for debris like hair or lint, and also dirt and dust.  A black switch pokes up on the left inside the UMD drive.  Its a little black stick.  When you press down on this Black stick, your UMD disc motor should spin for  second or two.  The UMD laser lens should light up when your press this switch.  If any of this does not happen, you need to replace the UMD drive. If you need someone to do this which if you have never done it, you need some knowledge big time.
I can do this for you if you're in the USA for $55 including a New UMD drive, REturn Shipping, and 90 day warranty. Contact Repairtech@playstationclinic.com
Oct 23, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
