Purchased second hand 17/3/2011 (2007 model) plugged in power turned on power and plugged in antenna, box comes on screen saying"no sgnal" Antenna was already working another TV.
  • 718 Answers
Based on the information you gave you will have to check/verify several things.
> You have connected an antenna.
> Go into the menu and set the signal input source to antenna/air or whatever its called. The previous owner may have used cable.
> Scan in the channels the antenna will receive.
> Save the list of channels.
You should now be able to watch stations via the antenna !!
Posted on Mar 25, 2011
Hooking up antena & converter box
Good: Connect the antenna to the converter box where it says antenna/in. Connect the coax cable to where it says to tv/out on the converter box. Connect this cable to the coax/rf input on the television. Plug in and turn on the converter box and the television. Make sure the television is on channel 3 and follow the setup process that pops up on the screen.
Better: Connect RCA cables to the converter box where the yellow red and white holes are. Connect them to an RCA input on your television. If you don't have a red hole on the television that's ok, just connect yellow and white and leave the red plug dangling. Connect the antenna to the converter box where it says antenna/in. Plug in everything and turn everything on. Press the video/input/source button until you have located the setup screen for the converter box and follow the directions on the screen.
Dec 02, 2012 | GE 27GT271 TV
How can i setup my bluetooth
If your computer is buetooth capable just turn it on. There should be a switch or keystrokes that turns it on. RTM - Read The Manual
Get onlineand got to www.google.com In the google search box type: "HPSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals and documents. Search the manual for bluetooth.If the laptop is not bluetooth capable you can always purchase a USB Bluetooth Adapter that plugs into the usb port. They can be purchased for less than $20. Click the link below and when the site comes up just type: USB Bluetooth Adapter in the white search box at the top of the screen then hit GO.
http://www.tigerdirect.com
Apr 19, 2012 | HEWLETT-PACKARD Hewlett Packard HP 145...
Will not work; shows "no signal" when turned on.
Be sure you have your input corrected to the feed you are accepting. You may need input 1, per say, you may be on input 2. If you select to use antenna, be sure you are on the correct channel advised by your Direct TV Servicer. The only other possibility would be, you are not getting a signal into the TV box. Follow the lead that comes into the box and see if it does connect to the outdoor antenna. As you suggest, one or both boxes work on the other TV. Thanks for asking and show all hands of support!
Sep 15, 2011 | Vizio L32 32 in. LCD HDTV
Purchased model NS-LCD32 second hand with no
Since you are getting the signal from the satellite, leave the satellite receiver ON and press input on the TV buttons until you get the signal back, wait 2 seconds after pressing the input button. Make sure the TV is on channel 3 if you are using the antenna input.
Let me know if you need further assistance.
Jun 13, 2009 | Insignia IS-LCDTV32 32 in. Television
No antenna cables on toshiba satellite 1405 s151
Some models that come with a wifi card already in them have an antenna. Since you purchased your card after the laptop it does not have an internal antenna. You can purchase the internal antenna but this will require you to take apart your screen.
You could purchase a PCMCIA or USB wifi adapter and use an antenna with those devices without taking apart your laptop.
Hope this helps.
Jei
Dec 12, 2008 | Toshiba Satellite 1405-S151 Notebook
The unit is a Magellan Nav 5000. We understand they are no longer being serviced and we are not looking for repair work rather hopefully some simple explanation to our problem. We are currently in Adak...
Sorry to say have had the problem from November 2007 again with this unit and despite ontact with Mgellan, they were as helpful as ice on a skillet. I have two units,like you, one new and boxed bt stil no acquisition from either,,,,
May 31, 2008 | Magellan GPS
Hp monitor power cord
I purchased a HP Pavillion Slimline computer that was accompanied by and HP flat screen monitor: HPw1858. My problem is that the power cord is missing. Can you help me locate somewhere I can purchase this cord?
Oct 26, 2007 | HP Pavilion F1523 15" LCD Monitor
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
