Question about Whirlpool Refrigerators
My refrigerator keeps cutting off every hour. I have to hit on the switch in my Model ED20PKXWWOO Whirlpool Refrigerator.
    Sergeant:
    Champion:
  • 202 Answers
Hi... seen it lots... If you have to hit switch ... you have a bad cold control
Posted on Mar 25, 2011
My whirlpool refrigerator keep running too cold food freezer, how to fix it ?
Turn the thermostat counterclockwise to next lower setting and see what temp is like after about 24 hours. Keep adjusting till you get what you want. Allow a day for reading after making a change.
Mar 31, 2017 | Whirlpool Refrigerators
Fridge/freezer does not switch back on after defrost cycle.
My recommendation is to replace the thermostat. Since you do not provide model or manufacturer, I cannot provide you with detailed instructions on how to find it. The thermostat is probably quite common at your local appliance parts store and should cost about $15. For example, the same thermostat is used across the whole Whirlpool line and many others. First, pull the power from the refrigerator! Once located (usually behind a panel inside your refrigerator) you can simply cut the wires leading to the old one and install the new one with wire nuts and/or wire connectors. Once installed, plug the refrigerator back into the power. Wait about an hour and the cycle should resume normally.
Sep 14, 2014 | Televison & Video
Noisy Whirlpool refrigerator
See if the sound is coming from the fridge in the top where the controls are. This would be he electronic control. They will click when going bad. Part 6 on this diagram.
Could also be a fan blade hitting something like ice or a wire. One fan is in the freezer behind the rear cover and one is underneath next to the compressor. The one in the freezer may cut off when door is opened so hold the door switch down when checking.
Could be the starter/overload relay but you would also have a cooling problem if that's the case.
Jan 29, 2010 | Whirlpool ED2FHEXN Side by Side...
Whirlpool model HAXNQ : lights out on fridge side only
Hummm... I would suspect your DOOR SWITCH on the fridge side... $11.321 shipped... eBay!
Anthony
Whirlpool 1118894 Door Switch
Dec 02, 2017 | Whirlpool GS5SHAXN Side by Side...
Whirlpool
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Oct 03, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Blocked defroster drain causes water to accumulate in freezer and refrigerator tpotoole@earthlink.net
Just Switch off the Freezer and unplug the power cord, keep the freezer door opened for some hours. If you want the process faster you can use electric fan and blow into the freezer. Be care full of the drain tank become full of water.
Aug 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool side by side - freezer keeps shutting
Your thermostat is defective and require replacement to settle this problem.
Jul 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold GS6SHEXNL - Freezer works, Refrigerator cools but display and lights do not work.
From about an hour of searching your refrigerator I found that the problem is in the control board mounted on the back of refrigerator. Visit this link below and enter model number GS6SHEXNL into the search model and parts search feature. When you get to your refrigerator on left of screen is different prints, chose #11 and you will #18 in picture. Click on link below and following links to support this problem. Model GS6SHEXNL Part Number W10135090
http://servicepartstec.blogspot.com/
refrig-problem-5577/">http://www.diychatroom.com/f47/whirlpool-refrig-problem-5577/
If you need more help, just let me know, Thanks, Sea Breeze
Apr 22, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool Side by Side Fridge fan sounds hitting coming from rear
this is because of ice accumulation near fan assembly. ulplug fridge and keep it open for 48 hours until all ice melts.
Jan 25, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool sideby side
this is normal this is the mulliion heater , it is a loop of tubing from the high side of the condenser it is used to keep moisture from forming between the doors of the ref, cool it will not be
but is cool how the manufacture thought about doing this
May 16, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
57 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
