Question about Intimus 385 se Shredder
Paper did not want to pull for in shredder - Intimus 385 se Shredder
Ativa shredder X1800 - shredder does not respond. green light present. Reverse works fine. I killed it with too much shredded paper.
Unplug it. Lift the shredder unit off the catch-bucket. Remove any paper caught in the blades. You may need needle-nose pliers to pull jammed paper out from between the cutters.
Aug 22, 2016 | Office Depot Ativa X1800 Shredder
Does not shredder middle of paper
First, make sure you turn your power to the shredder off. Take off the top of the shredder and turn it over. Is there paper stuck between the shredding wheels? I had to carefully pull this paper out with a set of tweezers. Be careful, as the shredding wheels are very very sharp!
Good luck,
Paul
Apr 11, 2015 | Shredder Office Equipment & Supplies
Shredder bin full
Most models: 1) unplug, 2) put something down to collect paper bits, 3) lift up the shredder top unit off the bin, 4) empty the bin, 5) try and pull out any paper from the shredder top using tweezers - first remove paper that has not fed through by pulling it back out.
Often if the bin is overfull the shredder gets clogged and won't work or beeps. When unplugged, you have to carefully remove all the bits of paper from the teeth to unjam the two rows of teeth. Remedy is to frequently empty the bin.
Jul 29, 2014 | Office Equipment & Supplies
Paper has wrapped around the cutting blades and is packed in tight. How do I clean this?
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
    • 3 Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Office Equipment & Supplies
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here: http://hubpages.com/hub/Paper-Shredder-Oil
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
Shredder jammed
For any jammed shredder..try the following.. pull backwards on the paper while you switch the machine into reverse. Try not to tear the paper as if there is nothing to hold onto then you can't help the motor.
If this dosn't work then you will have to take the top cover off(after unplugging of course.) and the try to force the paper backwards out of the machine by turnings the cutting blades or gears in the reverse direction.
Jun 04, 2010 | Royal 150MX Cross-Cut Shredder
Turns on when paper in slot, but won't pull it through to shred.
must disassemble feeder unit. you will find many bits of shredded paper to pull (push) out with a long narrow tool like a crochet needle.
Jun 19, 2007 | Royal AG10X Shredder
Intimus 385 se Shredder Logo
59 people viewed this question
Top Intimus Office Equipment & Supplies Experts
Lonnie Arks
Lawrence Oravetz
ray gallant
Are you an Intimus Office Equipment and Supply Expert? Answer questions, earn points and help others
