Question about Franke Kindred DP2233/90/1 Granite Double Bowl Sink Polar White
I installed a black granite sink, but the BASKET STRAINER is leaking. Do I need to buy a specific Basket Strainer for the Granite sink and take model # of the sink.Or can i just buy any basket strainer.??What is going wrong here? from pro plumber FRANK
  • Anonymous Mar 14, 2014
    Can"t find strainer baskets to fit Jacuzzi Sink
This is all wrong! You can't use plumbers putty on a granite sink! You're supposed to use a sink and tub caulk which unfortunately is a real pain to get seal. Read the directions on a granite sink... they say DO NOT USE PLUMBERS PUTTY!
Posted on May 12, 2012
  • 463 Answers
Hello.
You shouldn't need a special strainer.
Where the strainer meets the sink surface, ( the lip of the strainer ), should have plumber's putty.
Take a chunk of plumbers putty and roll it out like a snake and then stick it under the lip of the srainer all the way around. Set the strainer in the hole and then on the bottom side add the rubber seal, then the cardboard, or metal glide ring and then the nut.
As you tighten the nut it will squeeze out the excess putty and allow you to remove it.
1. Sometimes people try to use the rubber seal on the top side of the sink, but it goes on under the sink.
2. The cardboard/metal glide ring prevents the nut from tearing up the rubber seal so you can really tighten it.
I hope this helps you!
Thanks, Donnie
Posted on Mar 25, 2011
What is the order for putting together a basket strainer for a blanco sink
Disassemble strainer apply a bead of silicone sealer around underside of strainer lip. Set strainer in place. Install rubber ring from underside of sink then cardboard or plastic ring then spin on threaded assembly hand tighten and then tightent 1/4 to 1/2 turn more . Remove any excess sealer. Install ptrap and drain piping and check for leaks tighten as necessary.
Hope this helps.
Bob
Jul 02, 2014 | Kindred 1135 Standard 3-1/2'' Basket...
Is there a way to bypass the disposal to be able to use the sink w/o the water dripping from the bottom of the Badger 5 disposal?
If disposal is leaking, it has to be removed before it damages cabinet and causes mildew.
Then install a different strainer basket if you want to connect tubular drain.
Tubular sink basket
http://media.rd.com/rd/images/rdc/family-handyman/2001/11/Kitchen-Sink-Basket-Strainer-af.jpg
Disposal sink basket:
http://0.tqn.com/d/homerepair/1/0/m/0/-/-/sink_flange_noted.jpg
You can also buy same brand and size disposal and install without changing sink basket.
I wrote ez disposal replacement steps that show disposal removal and tips for connecting tubular drain.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 27, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Hi When I push down the Franke Strainer Basket in order to fill the sink basin, it appears to leak in the cabinets below. With out pushing down the strainer basket whilst tap is running there is no...
More than likely it's leaking from where the body meets the sink. U might need to pull it apart, clean it up, and re apply plumbers putty to the sink and re apply the body. If you are doing this I would recommend buying a new basket assembly from the hardwear store. Just makes more sence than re using the old one. That is enles it's new. Hope this helps
Mar 29, 2011 | Franke 900SN Strainer Basket: Satin Nickel
What strainer/disposal basket do I need to buy for Porcher Farm Sink? Sink did not come with strainer/disposer trim.
I believe this uses a standard 3 1/2 inch diameter basket strainer.That is also the right size for the disposal. Thank you
Feb 26, 2011 | Porcher 35020 London 30" Single Bowl Farm...
What is the difference between standard strainer and strainer for food erator? I bought a replacement sink wiht standard strainer, which does not seems to fit garbage disposal
If you need new sink strainer basket for disposal side of sink, you have to buy new disposal.
Each garbage disposal comes with its own strainer basket so that disposal can connect and seal.
First, the disposal strainer basket is installed, and then disposal lifts up and attaches from below.
A rubber gasket comes with new disposal.
Rubber gasket fits between disposal and strainer basket so that disposal seals correctly.
Photo below shows how disposal connects to strainer basket using steel connector ring under the sink.
I wrote tips for installing a disposal from days when I worked apartment maintenance.
Feb 16, 2011 | Franke 900 Black Basket Strainer 900
Leaking from the bottom after removing something that got stuck in the spinning peace
Check a couple things.
Use paper towel and see if top of disposal is damp or wet. The basket strainer might have come loose and water is leaking down.
Fill sink and then release water all at once and check strainer basket and dishwasher hose.
Check where tubular pipe connects to side of disposal. Sometimes this joint can leak, and then water appears at bottom of disposal.
If top of disposal is dry and tubular pipe is not leaking, then disposal is suspect.
Disposals rust out, and dislodging something from cutter plate can open final crack.
If basket strainer is leaking, and disposal is older than 5-8 years, you might consider new disposal since disposal has to be completely removed to reseal basket strainer. See link below for basket strainer steps.
If it comes to this, I wrote tips for installing new disposal
http://www.fixya.com/support/t6995519-badger_1_2_hp_in_sink
Nov 28, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Basket, silcone, sink, white gasket, black rubber, drain pipe? Is this correct?
basket
silicone (or plumbers putty)
sink
black rubber
white gasket
strainer nut
vinyl tailpiece washer
tailpiece (drain)
tailpiece nut
Nov 03, 2010 | Kindred 1135 Standard 3 1/2 inch Basket...
I have a kohler cast iron enamel sink. The
ALL BASKET STRAINERS ARE PRETTY MUCH THE SAME. PLUMBERS PUTTY WORKS FINE. I BELIEVE ITS THE ORDER OF INSTALL THAT IS CAUSING THE LEAKS. STRAINER AND RUBBER GASKET GOES IN FROM THE TOP. IF NO RUBBER GASKET IS PROVIDED, THEN PLUMBERS PUTTY WILL SUFFICE. UNDERNEATH, ANOTHER RUBBER GASKET AND/OR PAPER GASKET, THEN THREAD ON THE NUT. TIGHTEN IT SNUGLY.
Dec 25, 2009 | Plumbing
What to use plumbers putty or silicone on strainer basket rims installed on granite sinks
you always use plumbers putty on the strainer baskets. you can never use to much just remove the access when tightened. If you use silicone you will have leaks withen a year.
Mar 24, 2009 | Pegasus Technologies Pegasus 25 In. Black...
I need a new franke sink basket strainer for my franke sink model PRX11021 - stainless steel. What is the model number that will fit this sink and can I order it online or go to a local store?
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
Jan 28, 2009 | Plumbing
Franke Kindred DP2233/90/1 Granite Double Bowl Sink Polar White Logo
461 people viewed this question
Top Franke Home Experts
john h
Tom Chichester
Are you a Franke Home Expert? Answer questions, earn points and help others
