Question about Cuisinart TOB-175 1500 Watts Toaster Oven with Convection Cooking
Lower heating eliments don't heat or glow. Only top ones work
Are the elements replaceable and if so how ?
  • Anonymous Jan 31, 2009
    my heating elements on top stopped working too
  • 8,596 Answers
The elements are not orderable, but you can call Cuisinart with your serial number - the product has a 3-year warranty, and that is definitely a defect - will they glow if you put them on Toaster setting?
-Tha Mp3 Doctor
Posted on Jan 11, 2009
Top heating bars stopped working
Dear Tang_Tuong,
I would check all of the fuses, the internal fuses and wiring for any signs of damage and that particularly from heat. Also multimeter the connectors of the wiring to the element and see if you are getting a voltage reading, if you get a reading from the wiring and the element is not heating up, then you need to replace that element, do these checks for all of the internal components and you will find the one at fault.
I do hope this is the fixya for you and look forward to hearing how you get on.
Yours sincerely
Ouszen
Feb 07, 2012 | Euro-Pro Toaster Ovens
Elements not heating
Buy a new toaster. Very cheap appliance.
Feb 02, 2018 | Breville BOV650XL 1800 Watts Toaster Oven...
Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
it is several prosibilites for your problem:
1) the wire of the oven is damaged;
2) the thermostat is decalibrated or damaged;
3) one or more heating element is intrerupted or burned.
solution's:
1) check the wire an replace or repair where is posible whit similar heat resistant wire;
2) replace the thermostat whit similar one;
3) replace the heating element
Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
The heat element doesn't go on
FInd the break in the heater eliment and twish it bac together. It will then work again for a while.
Jun 29, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Slow to heat Haier Convection Oven
you are correct . it is the convection . the fan blows the air around and away from the elements ,when that is happening the elements can never get hot enough to glow , as the oven gets hotter and at some point the air is so hot even with it blowing the elements will start to get red ... this is good because todays elements are thin and cheep and melt easy so the fan keeps the heat away from them and the elements last longer ...... if this answer helped please rate it a 3 or 4 stars .this high rate will help keep me in the paid answer department ... thank you
Apr 04, 2009 | Haier RTC1700 1700 Watts Toaster Oven with...
Toaster Oven's top heating element is not working... repair?
Thrash it.
They are not meant to be repaired because the lawyers told them there is too much risk.
Mar 11, 2009 | Black & Decker Toaster Ovens
Top element broken
Oster 6233 toaster oven top heating elements don't work
Nov 11, 2008 | Toaster Ovens
Toaster does not work!!!
I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Heating elements
The upper element for AS690 is part# 512623
Thw lower element for AS690 is Part# 512624
Available at www.nelsonappliance.com/Toaster+Oven+Parts.html
or
http://abtecparts.com/delonghi_toaster_oven_elements.htm
Jan 03, 2008 | DeLonghi AS690 Airstream Stainless Steel...
Cuisinart TOB-175 1500 Watts Toaster Oven with Convection Cooking Logo
926 people viewed this question
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
