Question about Nokia 6350 Honey Hard Case/Cover/Faceplate/Snap On/Housing/Protector
Nokia 6350 IS NOT HOLDING A CHARGE. VERY MINIMAL USAGE , SELDOM MAKE CALLS (ABT 3 MAX CALLS A DAY, UNDER 5 MIN.) dont do MMS, INTERNET ACCESS, GAMES BLUETOOTH. SMS MAX 20 A DAY. HV TO PRACTICALLY CHARGE EVRYDAY. PHONE UNDER 1 YR. I HAD PHONE REPLACED, UNDER WARRANTY, starting w/ battery Athen charger as advised by rep. ISSUE AS WELL WITH RINGER AND VOLUME, CAN BARELY HEAR, VOLUME SET TO MAX. WE DID MASTER RESET ALREADY. I DONT WANT TO EXCHNAGE THE DEVICE AGAIN. PLS HELP ME. is there a new update to this phone or is this as far as the phone can do. tnx
SOURCE: CK-7w mutes stereo
Disconnect the battery for a few seconds...I had the same problem and removing fuses didn't work.
Posted on Jun 12, 2009
SOURCE: 2300 nokia ringer problem
sir my mobile nokia 2300 not ringing
Posted on Aug 22, 2009
dancandoit
  • 436 Answers
SOURCE: Nokia CK-7W, nobody can hear me!!
It sound like a faulty microphone, try and follow the wire to see if it is trapped somewhere, mabe down the side trims.
Posted on Nov 24, 2009
SOURCE: Sir the mobile nokia 5800 is getting warmed up in
If your nokia phone is having a problem or it seems to have lost everything just insert this code at the idle screen to reset the phone to it original state on purchase. Use *#7780# for mild reset while *#7370# is for harsh reset.Pls ensure that you use a sim card that you do not value its contact.If possible,use a new sim card.Also ensure that you remove the memory card/stick before you use the second on because it automatically removes every installed programs and returns the phone to its original state.I would advice you use the second one for maximum results.Thanks and do not hesitate to inform me on any progress.
Posted on Apr 24, 2010
SOURCE: I have a Nokia CK-7W hands free kit in my car. I
sometimes my radio doesnt work with the ck-7w is this a common problem
Posted on May 06, 2010
Settings for apn are blank. what is my apn code
Hi Edward,
Here are the steps..
Internet Setup
Step 1: Enter Settings
Step 2: Select Wireless & Networks
Step 3: Select More...
Step 4: Select Mobile Networks
Step 5: Ensure Data Enabled is checked (enabled).
Step 6: Select Access Point Names
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND Data as the name for the new APN. Under the headings APN enter internet.windmobile.ca (leave all other fields blank).
Step 8: Save the APN settings by selecting menu and then save.
Picture Messaging (MMS)
Step 7: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • APN: mms.windmobile.ca
  • MMSC:http://mms.windmobile.ca
  • MMS Proxy: 74.115.197.70
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
  • Leave all other fields blank.
Android 2.1 to 2.3
Internet setup
Step 3: Select Mobile Networks
Step 4: Ensure Data Enabled is checked (enabled).
Step 5: Select Access Point Names
Step 6: Create a new APN (Access Point). Enter any name you would like to call your internet connection and the access point as internet.windmobile.ca (leave all other fields blank).
Picture Messaging (MMS) setup
Step 6: Create a new APN (Select Menu, followed by New APN). Enter WIND MMS as the name for the new APN. Under the following information in the listed headings:
  • MMSC: http://mms.windmobile.ca
  • MMS Port: 8080
  • MCC: 302
  • MNC: 490
  • APN Type: mms
May 10, 2016 | HTC 7 Surround T8788 Windows 7 Wm 3.8"...
I want gprs setting for nokia 2626
Basic Setting Parameters for GPRS & MMS
Proxy Server :- 192.80.7.133, Port :- 8000
For accessing internet/WAP through your mobile handset :-
GPRS APN :- ntwap
GPRS Home Page :- http://wap.ntc.net.np (You can use your favorite site link also)more...
For accessing internet through computer by using GPRS service in your mobile phone :-
APN :- ntnet
Leave Username, Password and any other fields blank.more... For sending and receiving MMS :-
MMS APN :- ntmms
MMS Home Page/Server Address :- 192.80.11.180
Setting I for Nokia (2626,2600,2760, 3110, 3120,3600, Xpress Music 5200, 5220, 5300, 5610,5310, 6030, 6070, 6080,6085, 6151, 6233, 6280, 6300,6500 Slide,6600,6220,7210, 7360, ...)
1. Enter the main menu.
2. Select Settings, configuration, personal config. setting
3. Add new (From options)
4. Select Web and provide details
a. Account name: Ntc
b. Homepage: http://wap.ntc.net.np
c. Leave User name and Password field blank.
d. Preferred access point: No
5. Then define access point settings
a. Proxy: Enable
b. Proxy Address:192.80.7.133
c. Proxy port: 8000
d. Data bearer: Packet data.
6. Select Bearer settings.
a. Packet data access point: ntwap
b. Authentication type as Normal.
c. Leave other fields as it is.
7. Finally, activate the above created web
8. Restart your set and you are now ready to surf internet with NT Mobile GPRS service.
Note: In case if if third applications(like operamini,ebuddy,mig33) don't work, follow these steps:
1. Repeat the above steps upto 3
2. Select Access point and provide details
1. Account Name: Ntc
2. Go to Access point settings;
3. Data bearer: Packet data
4. Go to Bearer settings:
5. Packet data access point: ntnet
6. Network type: IPv4
7. Authentication type: Normal
8. Leave other fields as blank
3. Save the settings and activate it
4. Restart your set and you are now ready to surf internet.
Apr 22, 2016 | Nokia Cell Phones
I have just bought replacement battery for my samsung c3050 which is not keeping its charge very long. The battery supplier advises to put phone in standby mode. What is this please?
the 3050 dosn't have a standby mode only an idle witch is the mode when you turn it on but dont access any af the features or web/calls you will probably find if you completly charge and discharge the phone a few times the battery will hold a better charge if not i'd send it back and ask for a refund as the battery is likely faulty
Sep 14, 2014 | Samsung C3050 Cell Phone
How could I open my mms/gprs using my android phone!?samsung galaxy ace dous to be specific.
Hello Eireen,
  1. On your Samsung Galaxy Ace Duos go to Settings, select More under data usage then select Mobile networks then select Access Point Names.
  2. Press menu, after select new APN, type your network settings(from your operator), press menu after you are done and then Save.
  3. Enable your mobile internet and enjoy.
Alternative way.
Download an application from Google Play Store like
Tweakker APN INTERNET MMS
After that
1. Select your operator or provider
2. Select your subscription or plan
3. Tweakker sets up Internet & MMS APN on its own
and you are done!
Enjoy your mobile Internet!
Nov 06, 2013 | Cell Phones
How to change nokia c7 mms settings
Press the Menu key.
2. Tap Messaging.
3. Tap Options.
4. Tap Settings.
5. Tap Multimedia message.
6. Tap Access point in use.
7. Tap PAYG MMS
OR1.From the Front Screen press the Menu button.
2.Tap on Settings.
3.Select Applications sett.
4.Select Messaging.
5.Select Multimedia message.
6.Select Access point in use.
7.Select 3MMS.
Jan 21, 2013 | Nokia C7 (8 GB) Smartphone
Setting for bsnl gprs as a modem in pc suite
The following are the BSNL GPRS activation settings in South India
To activate GPRS
Post Paid Customers should send the following SMS to 53733
1. GPRS199 - Rs 199/month; unlimited usage
2. GPRS49 - Rs 49/month; After 5 MB usage, each 10 KB costs 3 paise
3. GPRSF - No monthly fee; each 10 KB costs 5 paise
Pre Paid customers should send the following SMS to 53733
GPRSPRE - each KB costs 2 paise
To deactivate GPRS facility:
Send the following SMS to 53733
GPRSD
Activate the automatic GPRS settings:
Visit http://218.248.72.246/msp/html
OR
SMS the following to 58355
MODEL MAKE
e.g. NOKIA 6070
BSNL INTERNET Settings: (This is what enabled internet access for my mobile applications)
1. Select Settings from Menu > Settings >Configuration>Personal configuration settings>Options>Add new>Access point
2. Connection name: BSNL GPRS
3. Data bearer: GPRS
4. Access point name: gprssouth.cellone.in
5. User name:
6. Prompt password: No
7. Password:
8. Authentication: Normal
9. Press Back to save the settings.
10. Press "Activate default in all applications"
PC configuration (With Nokia PC Suite)
Install software (PC suite & original cable driver).
Click on Internet settings in PC suite
1. Click on settings in one touch Access in Nokia PC Suite
2. Select Modem of Mobile Modem (eg: Nokia N72 USB Modem) and press Next
3. Click on Configure Manually and press Next
4. fill the blanks like
Access point: gprssouth.cellone.in OR bsnlsouth
UserName: Mobileno (9194xxxxxxxx)
Password: Mobile no (9194xxxxxxxx)
and press finish
Hope this help
Feb 03, 2011 | Samsung Cell Phones
Loudspeaker and/or musical player activates unexpectedly while making or receiving a call. Also calls cut down after one or two minutes. This happens occasionally.I have downloaded F-secure mobile security...
update its software with usb cable and internet connection.
go to nokia official web site and download software updater and then connect ur phone with pc or laptop and do as directed in it
it will update your software of your phone ,it may take 15 min
make first that
1:phone is full charged.
2:dont take calls during the process.
3:see that connection of pc to internet & pc to phone cant be disturbed.
Jan 19, 2010 | Nokia N70 Cellular Phone
Trouble with internet and mms messages on sciphone i68
Centennial Wireless Internet And MMS Settings For The Iphone!!!!!!!
ALL SETTINGS WORK AND BEEN TESTED ENJOY...........
$$$$$ HACKED BY QWAZY $$$$$
INTERNET
APN = private.centennialwireless.com
USER = privuser
PASSWORD = priv
MMS
APN = mmspublicwap.centennialwireless.com
USERNAME = "LEAVE BLANK"
PASSWORD = "LEAVE BLANK"
MMSC = http://mms.myblue.com/servlets/mms
MMS PROXY = 063.099.231.135:8080
MMS MAX MESSAGE SIZE = "LEAVE BLANK"
MMS UA PROF URL = "LEAVE BLANK"
Apr 05, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Receiving MMS on Treo 650
That soulution dont seem possible with Palm treo 650 running Palm OS
Dec 13, 2007 | Palm Treo 650 Handheld
Nokia 6350 Honey Hard Case/Cover/Faceplate/Snap On/Housing/Protector Logo
74 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
