Question about Haier Freezers
Freezer 5.3cuf moved from one room to onther pluged back in power light and compressor still come on but wont freeze
    Problem Solver:
  • 12 Answers
Unplug it and manually defrost it. making sure that the inside of freezer has reached room temprature thenplug it back in and see if that helps.
Posted on Aug 05, 2008
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
My freezer does.not freeze and the hi temp light is on.
Had the same problem, I unplugged freezer for two days, pluged back up, has worked fine since.
Jul 11, 2012 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
17 cu fridgeidaire freezer wont freeze
More than likely the compressor is bad. A lot of times technicians will change the start device on the compressor and if it runs for a minute they are satisfied its fixed. The proper way would have been to monitor the amperage drawn by the compressor and then there would be no doubr if it was start device or compressor.
Mar 31, 2012 | Avanti Freezers
I have a deep freezer,the light is on but doesn't freeze. It's only 2 yrs old what could be the problem?I unpluged it and waited 10 mins pluged back in and nothing the red light stayed on but...
Well a freezer is easy to repair. The circuit goes from one side of the power cord to the cold control and down to the compressor then out to the other side of the power cord. Id the control or compressor relay is open then she won't freeze. All the parts to it are listed HERE.
From the list I see an overload for the compressor. If that one is open it won't freeze. Bypass the temp control wires to see if she runs.
Sep 13, 2011 | Magic Chef Chest Freezer MCCF5WBX
The freezer is running, and the light is all coming on but it is not freezing the contents in the freezer?
Hi and welcome to FixYa. I am Kelly
If your sure the compressor is running and it is not freezing then there has to be a system coolant leak.
Having said that there are a few things to check:
1. Is the compressor in fact running Y / N
a. Yes = coolant level problem or coolant system blockage
b. Not running = (Possibilites below)
1) PTC / Klixon Thermal overload failure
2) Run capacitor failure
3) Temp control failure
4) Automatic defrost thermostat or thermistor
5) Defrost timer or Adaptive defrost control failure (depending on model)
2. Is the compressor very hot to the touch or room temp?
a. VERY hot = unplug the unit for at least 30 minutes and then plug it back in.
b. ROOM temp = any of the above in 1b items 1) - 5)
3. Is the evaporator fan running?
a. Yes = Temp control is ok Defrost system is probably ok
b. No = same as 2b
With a model number I could pass on a few additional things to do. For the moment use the above.
Thanks for choosing FixYa,
Kelly
Oct 18, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Fridge freezer is not workink,light is on freezer but no sound,freezer is in a cold room is it possible the room is to cold and problem with thermostate?
It could be a compressor problem, or the cold control. If your room is above freezing, the freezer should still run.
Jan 07, 2010 | Freezers
My slush machine wont freeze
the first thing i would check depending on your make and model is ensure the compressor is running
if not check the overload and relay pluged in on the side for continuity
then make sure your cooling fans are working
this should be a good first step but let me know
if not let me know the make model and ill take a look at the scematic
Oct 24, 2009 | Grindmaster Freezers
Have a arctic air f22cwf freezer that will not freeze right
There is a starter relay on the compressor. It sounds like it needs replacing. If you listen for awhile when it trys to start the compressor there will be a clicking sound but then nothing will happen. That is the most likely cause.
May 05, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
New Commercial True Freezer suddenly quit freezing
Check for freon leak>> is compressor running?
or Iced over?
Jan 29, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Freezers Logo
161 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
