Question about HP Photosmart C6180 All-In-One InkJet Printer
My C8180 All-in-one has the error message 0xc18a001 i have tried the removal and replacement with new printer cartridges and unplugging the power without success on searching the net there is a suggestion of removing & replacing the CMOS battery after 30 mins but dont know where to look - could this help or do you have a better solution what are the fees referred to in the terms of use
  • 3 more comments
  • jandafraser Mar 25, 2011
    thanks but already had that suggestion - the question was where to find the cmos battery in my c8180 printer
    hope you can give me specific detail instruction - otherwise i will have to continue to un-screw everything
    as you seem to agree that removing the cmos battery, can you advise me of its location in my c8180 printer please as per my original request - or is it something to do with the age of the printer - 2/3 years
    Thanks, Allister
  • jandafraser Mar 26, 2011
    sorting through the internet self help information, there appears to be an awful lot of frustrated people having the same problem (error 0xc18a001)
    the Fix Ya solution overcame the problem after I connected the printer via cable - the wireless connection would not re-connect after re-installing the soft-ware. (It had worked for the last 2 years without a problem.)
    Cant help but wonder why these error codes and fixes are not in the operating manual.
    Many thanks
  • Jo Radcliffe May 09, 2013
    Looking at the machine from the front the cmos is in the right hand side of the base.Remove screws and the yellow protection plug from the sockets at the rear if it is there and then fold down the panel so that it is only connected by the wires to the on/off switch. The cmos is on the other side of the revealed circuit board. I unscrewed the board and without removing any connectors swung it back a bit, stuffed a plastic widgit in to keep it back and removed/replaced the cmos and reassembled.
    Oops, should have said there is a small L shaped panel at the front RHS that should be removed first and of course disconnect the lead that goes to the top part of the machine at the back.
  • 2,574 Answers
Here's what the battery should look like inside your printer.
"0xC18? errors may also mean that the printer's temperature is below 40F/5C.. Try warming up the printer.
Posted on Mar 25, 2011
  • Reparatii PC - Service IT
    RESET IDS HARDWARE FAILURE Method:
    1.Get the unit into the "Support Menu" by following the steps below :
    Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say "Enter Special Key Combo"
    -OR-
    Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal" (Display should say "Support" and display the FW rev (something like R0616R).
    2.Press and release the right arrow button until the display says "System Configuration Menu" (use touchscreen).
    3.Press and release the "OK" button.
    4.Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
    5.Press and release the "OK" button.
    6.Display should say "Hardware failure status: Clear. Press OK to clear".
    7.Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    8.Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    9.Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    10.Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    11.Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
    12.If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
    13.To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
    14.If the error is still there, or reoccurs replace the unit.
  • sbbb Sep 04, 2012
    wow Jack DjY - you're AWESOME. This reset hardware failure worked great!!! thx
How do I fix ink system failure error message on a hp photosmart c8180 even though I have replaced all cartridges. Need to rest the system any ideas?
i love google.... usually:
http://h30434.www3.hp.com/t5/Other-Printing-Questions/Photosmart-C8180-Ink-System-Failure-Error-0xc-18a0005/td-p/331285
Jun 24, 2014 | United Stationers HP Photosmart C8180...
Error0xc18a001 i cant print because of this message what do i need to do ? please help
ello thanks for using Fixya
To solve the error code
0xc18a001. There is following solution.
Follow it step by step
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
By this error will automatically remove. But if u face still this error then printer service required
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Feb 14, 2011 | HP Photosmart C5180 All-In-One InkJet...
Receiving error message: 0xc18a0001 error message on hp c8180 all-in-one printer. what can I do?
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If I've helped you, please vote! Thanks!
Dec 09, 2010 | HP Photosmart C8180 All-in-One InkJet...
Error code oxc18a01
The "Oxc18" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
May 28, 2010 | HP Photosmart C8180 All-in-One InkJet...
0xc18a0406
Hi there
Try the following steps to remove HP Printer Error Code 0xc18a0001.
I have put 3 ways for you to try.
1. Without turning off the printer, unplug the USB cable.
2. Remove the cartridges.
3. Wait until the message "Insert cartridge" appears.
4. Unplug the power cord.
5. Wait 60 seconds.
6. Reconnect the power cable. If the printer does not turn on automatically, press "On button".
7. Reinsert the cartridges and close the lid.
8. If the printer has a page of calibration accept.
9. Reconnect the USB cable and remake an impression.
10. If the problem persists, the machine must be repaired.
Or try 2
Turn the printer and wait until you receive the error message.
* Simultaneously press the keys "9" and "#" printer.
* While holding the button down, unplug the power cord from the unit.
* Wait a few seconds.
* Still holding the button down, reconnect the cable and turn on the printer.
* Release the buttons.
Or try 3
* Turn the printer and wait until you receive the error message.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 26, 2010 | HP Photosmart 3210 Printer
Error 0xc18a001 ink system failed when I put new cartridges in
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Dec 02, 2009 | HP Photosmart C5180 All-In-One InkJet...
On startup, printer displayed Ink System has failed. Error )xc18a0001. Have tried the cartridge-out/power off recommendation, fault is still there on power-up.
I searched internet forums and found out how to reset the internal processor, thereby deleting the error message and allowing the printer to operate normally.
Process was:- Press on/off to turn off power. Unplug power cable. Wait 1 minute. Press and hold 'Red Eye Removal' and 'Print Photos' buttons. Insert power cable and printer automatically powers up. Keep holding the two buttons until the display screen goes blank. Press on/off to turn power off. Wait 1 minute. Press on/off to turn power on. Press 'Setup' on touchscreen and go through the procedure, including wireless setup (if used). "Bingo".
Oct 19, 2009 | HP Photosmart C8180 All-in-One InkJet...
C8180 Error Oxc18a0001
Hi there
Solution 1:
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Solution 2:
Oct 15, 2009 | HP Photosmart C8180 InkJet Printer
HP Photosmart C8180 - Ink System Failure - Oxc18a0101
i had exactly this error message. Rang HP. They said it was a hardware failure, they couldn't fix over phone, would cost 2x cost of new printer to fix, but they offered me 20% discount on new printer if ordered over the phone.
But with some fiddling, problem now resolved. Here's what I did:
- press Red Eye Removal and Print Photos button together
- goes to Mfg Commands -> Enter Special Keys Combo. Press OK
- uaiux Support page (some code) -> click right arrow key until you get to System Configuration Menu - click oK
- should say hardware failure status - click OK
- says hardware failure status: Clear. Press OK to clear
- I clicked OK on this and system reset itself and problem was solved
Jun 24, 2009 | HP Photosmart C8180 InkJet Printer
Ink system has failed. unable to print. error 0xc18a0206
I find a solution 6180
unplug power cable
press 9 and # on keyboard
replug power cable with buttons pressed
the error must disapear
change the print cartridge indicated they became bad ( why ?)
reset is done you must reput language and network ip adress
Philippe GERARD
Jul 03, 2008 | Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
666 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
