Question about RCA R52WM24 52" HDTV Projection Television
I'm wanting to drop my satellite service. Will my projection tv pick up stations with a digital antenna?
  • 591 Answers
Sorry but I've never heard of a DIGITAL ANTENNA, ALL antennas are ANALOG NOT DIGITAL, and yes you will be able to tune in some TV stations if you live close enough of TV stations that still transmit ANALOG signals, with a GOOD VHF/UHF antenna you can have good reception and viable TV time... (best of all it's FREE)
Good Luck!
Posted on Mar 25, 2011
The analog tv picks up a lot more stations and correct channels than the LED TV. Is it possible to set the Insignia LED NS-19E320A13 to analog? Is there a device available?
.YES IF ITS A DIGITAL TV U WILL GO TO MENU GO TO ANTENNA CHANGE FROM DIGITAL TO ANALOG OR AUTO ENTER THEN SEARCH ANOTHER WAY GET AN ANALOG TO DIGITAL SET TOP BOX FIX YA ANTENNA TO IT CONNECT TO TV BY HDMI.OR AV CABLES GET THE SET TOP. ON GO TO SCAN OR SEARCH AND YOU WILL HAVE ANALOG CHANNELS ON YOUR LED TV
Oct 08, 2015 | Insignia Televison & Video
Can't get the antenna to pick up the local channels
Hi Leslie, since you didn't disclose the brand or model name and number to the antenna you are using, I'll do my best to help you with your dilemma.
1.) double check your physical (wire) input connections
2.) make sure you have selected the proper input from you t.v.'s menu screen
HDTV aerial (outdoor mast) antennas are your best investment to receive free air wave digital transmissions...as opposed to the smaller indoor antennas...and the clarity is phenomenal; it cannot be matched by cable or satellite signals that compresses and decompresses the audio and video signal.
Why? Because, digital t.v signals are line-of-sight signals; meaning they need an unobstructed path between the sending source (t.v. station transmitter) tower and the receiving (home) antenna.
Hills, trees, walls, buildings, and any other obstruction- bends, deflects and weakens the signal as it is...placing an HDTV antenna in an attic weakens the signal by at least a 1/2...
So, if you are using an Indoor omnidirectional antenna at the set; the signal will be even weaker...it won't be good enough to pick up the digital signal that requires an accurate line-of-sight reception (just like satellite dishes.)
As a side note: I had an outdoor HDTV mast installed professionally; including signal filter and signal booster- [they'll know the proper type antenna to use for your area (see http://transition.fcc.gov/mb/engineering/dtvmaps/ for more details.)] And it was so worth it; whenever we have storms that knocks out cable power, we rely on the air-wave stations...and their sub-stations, lots of choices; and it's phenomenally clear...much clearer than cable or satellite signals can ever be.
As a matter-of-fact, we watch our local news and entertainment stations normally via our antenna rather than our cable service provider's system for that very reason of clarity and detail. Too bad we couldn't get the quality "pay for" stations that way, too - we'd drop our cable service and save a lot of money! :)
Mar 10, 2015 | Televison & Video
I have a VIZIO E552VL TV hooked up to an Over the Air Antenna and want to MANUALY put in channels NOT AUTO SCAN
Not sure if your TV is digital or analog, but I think an analog TV does not have the ability to perform auto scan, so you may be able to manually input the channels. As a kid, my dad installed a rotary antenna, and as it rotated and TV pictures displayed on the screen, dad noted the specific spot on the rotary unit; and every time we turned the set on, we just pointed the arrow on the dial on the unit to where dad noted what the channel number was on the unit, and the antenna turned toward that direction, and the pictured appeared on the screen.
Nov 16, 2014 | Vizio E552VL 55" 1080p 120Hz LCD HDTV
I HAVE A VS-60705 LIVE IN THE WOODS.WPB WHAT IS THE BEST ANTENNAE TO USE FOR FREE DIGITAL BROADCAST.
If you live far from any digital broadcasting stations, you may not be able to pick up signals using an antenna. In my area, it is impossible to receive digital signals from transmitters located just across the river!
Sep 22, 2014 | Televison & Video
We have a mitsubishi 1080 hd model ws-48311. We no longer have cable do we need a converter box for this tv to pick up free tv. Thank you
No. All you need is an inexpensive antenna to pick up local TV stations. If the stations are close, all you should need is something like this one: http://www.walmart.com/ip/RCA-Digital-Flat-Antenna-made-for-DTV/10542272
Sep 09, 2013 | Televison & Video
Do I need a TV digital to analog converter box to use my outdoor antenna to pick up local stations?
Hi
Possibly but that depends on your antenna. What you will need to do first is change your TV's input selection from cable to ant. Should be in your menu.
Mar 09, 2010 | Hitachi 43UWX10B 43" Rear Projection...
NO DIGITAL TV SINGAL, WITH ANTENNA
You will need to connect to a satellite or cable provider that will give you a signal box and remote to pick up digital signals and your favorite tv stations. Everything is turning digital.
Oct 02, 2009 | Akai PT4250A 42" HDTV
Does anyone know if this tv is analog
the tuner on this tv will pick up the analog and the digital broadcast stations.
so yes you can get the analog stations , but you also get the digital or hd broadcast stations that are available
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
Picking up tv station
Yes, lock out the frequency, or wait until digital broadcast comes int effect. DTV will be effective in 2009 where all television broadcasts must be done by cable or satellite. This means no antenna broadcasts.
Mar 17, 2008 | Uniden BC60XLT-1 Handheld Scanner
RCA R52WM24 52" HDTV Projection Television Logo
132 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
