Question about Vacuums
Hello, I am looking for a wiring diagram to install a touch/dimmer switch by "Comfort" mdl # RH-934B - Darjung Ind Ltd. It has a standard lampcord (two wires) coming from it as well as one white, one black and one yellow wire. The original touch/dimmer switch (no identification on it) had one white, one black, one red and one yellow - no lampcord. Thank you very much for your help!
The black and the white will go to the lamp ,eg,output.The yellow is the sensor wire which should be firmly attached to the metal base of the lamp
Posted on Dec 27, 2012
  • 97 Answers
SOURCE: Replacing Power Cord Kenmore Progressive Upright
That actually sounds correct, if it's the model I'm thinking of. As long as you're talking about connecting to the wires that are held in by the wire nuts you should be good to go.
-R
Posted on Mar 03, 2009
  • 140 Answers
SOURCE: Electrolux Model E switch wiring diagram
The black wire coming from the power cord connects to one side of the switch and the other black and the red wire go to the other side of the switch. If it turns on with the switch in the off position reverse the sides. Good luck. If you need anymore help just ask. Please rate me so I know if I helped. Thanks.
Posted on Dec 31, 2008
b0sslady2001
  • 357 Answers
SOURCE: G4 Footswitch wiring
I have published an online guide...it may be of help to you. Just click on the link to view it.
Marci
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Posted on Oct 16, 2007
SOURCE: wiring diagram s3755 hoover
Today I shortened my hose by 4" to get around a tear problem. You can use an Ohm meter to find the right 4 wires. When looking from the top of the canister with the hose heading to your left, the wires should be:
White (furthest connector away from you)
Black - to the switch
Red
Blue
With the Red and Blue going to the speed con trol curcuit board.
Posted on Sep 20, 2009
  • 8404 Answers
SOURCE: explain how to re-wire 16gal craftsman shopvac,
Im not looking at a diagram of your machine.
Typically, in a switch circuit ... the green goes through; the white goes through; the black is broken by the switch.
The two orange wires you speak of ... those come from where? Are they from the motor? If yes, one connects to the white and one connects to the switch.
I hope this helps you
If I have misunderstood your question, please ask again.
a
Posted on Oct 05, 2009
How to get to the rainbow SE vacuum off/on switch.
Hi, here is a walkthrough on how to get to that part here. Steps 1 - 14 on how to access it, you will need to take apart the housing to get at it. If you need a new switch you can find that here. Rainbow did redesign this switch, so you will need to look at the wiring diagram if you are installing a new switch.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 18, 2014 | Rainbow Vacuum Cleaner Power Switch D3,...
My Bissel Spotbot will only let me use the Manual Mode, when I try to push "Set in Stain" or "Surface" stain the light won't turn on. My children were playing with it, but I...
There is a small magnet in the end of the hose. Under the phillips screw and plastic cover. Mine rusted to bits and stopped tripping the switch. A bit of a super strong hard drive magnet siliconed back in the end of the hose and all was fine.
May 26, 2011 | Bissell SpotBot Robotic Wet/Dry Vacuum
I am tiring to install a GE touch auto shut-off timer, I have 2 wires in the wall 1 black & 1 white, the switch has 4 wires (1 green[ground?], 1 blue, 1 black & 1 white) when I try to follow the...
You might not be able to use that switch in your configuration. It appears that the power was run to the light and only two wires were run back to the switch. The old switch only closes to connect those two wires completing the circuit at the lighting fixture, but you need a hot and a neutral to operate the electronic switch that you have.
Gary
Apr 18, 2011 | Vacuums
Need replacement switch for zing ear ze-256 switch. Used in a lamp, has off, lo and high positions
I have the same issue. I bought a ZING EAR dimmer but it won't fit in the space allowed by the pole the lamp is made from.
The switch is simple, the positions are: Off/On/Half.
The switch uses a diode to provide half voltage to the lamp. I have two solutions and I'm not sure which I'll use yet. First, I can use the dimmer but I'll have to get a 500K pot with a switch to fit in the hole. I'll attach wires to connect to the PCB of the dimmer. In essence, I'll remote mount the 500K pot.
The second solution is to get a rotary switch like this:
http://cgi.ebay.com/Lamp-parts-3-way-2-circuit-rotary-switch-5-8-TR-302-/380282854100?pt=LH_DefaultDomain_0&hash=item588a9fdad4
and use the diode salvaged from the original lamp switch. In my switch the diode is still good.
I know this sounds awfully complicated, but it's really not.
Randy.
Email me and I can give better details if you like.
westerville5595-now@yahoo.com
Mar 05, 2011 | Vacuums
Need wiring diagram for Rainbow D4C vacuum to install rocker switch
You can get a wiring diagram at http://www.rainvac.com/schematic.html
You can get all of the manuals, and the full breakdown schematics, of every model there.
If you need me to tell you which wires go where, exactly on the switch, let me know. I am a Rainbow vacuum expert and know everything about almost every model ever made.
If you have any more questions, let me know.
Thank you,
Feb 20, 2010 | Rainbow Technologies D4 Bagless Vacuum
Handle got hot, circuit breaker was activated, now switch does not start vacuum
Hello. The cause of your hot handle must be investigated as you have a bare wire or connector which is shorting out. If you are handy, disassemble the handle assembly and look for melted rubber, a bare wire touching metal, etc. The fix is to replace the bad wire. Regards. Joe
Please rate my answer. Thank you.
Jan 04, 2010 | Vacuums
We just installed a Hoover central vacuum system. As soon as we plug it in the system starts even if the switch is off. If we disconnect the wire the system goes off. What did we do wrong?
You have either left the manual switch at the vac in the on position, or you have a low voltage short at one of your inlets in the house, or at the vac itself or where a pair of wires are connected together at a pipe junction.
Carefully go back inlet to inlet, remove the plates and be sure your mounting screw is not shorting two wires together. Trim any excess bare wire away and look for nicks in the insulation as well unless you see an obvious short. If you are using telephone type multi colored wire it is easy to bare an inside piece of wire while stripping the outer insulation.
Also be sure sure wires are paired the same color pattern at each inlet.
It is common to see a stripped wire touching another inside the wall or if you have metal backing plates in the wall a wire may be touching the plate and triggering the vac to turn on. Post back to advise,
the other possibility is you have a nail or screw in a wall piercing the wire but this is seldom ...
take your time,its an easy fix but it might be hard to spot
Oct 04, 2009 | Vacuums
Nutone CV556 Vaccuum Cleaner -Continuously running
Start with this. Unplug the vac to shut off, then disconnect the low voltage wiring at the vac.Plug the vac back in. If the vac still runs you have an internal short on the relay or wiring inside the vac.
If the vac stops then the vac and final wiring is OK and the problem is in the wiring in the house.
Have you removed any inlets for painting or had any renos done or pictures hung. If so undo what you did last. If inlets were disturbed remove them and look for low voltage vac wires touching metal backing plates in the wall or touching the inlet mounting screws.
If you have done a reno or hung pictures you may have pierece the wire for the vac creating a low voltage short which will keep the vac running until removed. I have seen this happen with freshly installed 1/4 round molding along a baseboard
Sep 07, 2009 | Broan-NuTone CV556 Cyclonic Bagless...
Vacuums Logo
271 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
