Question about Kenmore HE2 Plus Front Load Washer
I had an F01 code and ended up replacing the CCU Board (part # w10205849) successfully and had 1 perfect wash. But the 2nd wash didnt complete. I replaced the CCU Board a second time and it's basically the same problem - but now it wont start a wash whatsoever. No error codes this time. Just sits there with the door locked and add a garmet light blinking. Any ideas?
    Brigadier General:
  • 3,513 Answers
Hi
If you have already replaced your CCU you need to replace the door lock mechanism. Also you're still experiencing problems, you need to re-verify your electrical connections and check the CCU.
The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
The doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 25, 2011
Error f01, what means?
The "F01" error code is indicating a communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Generally in order to correct this failure the CCU board will need to be replaced
Jan 05, 2016 | Washing Machines
My machine is displaying code F01. It comes up at the end of the wash cycle. However, It doesn't seems to be actually washing the clothes anymore. The water runs in and out of it , but I don't...
I tired answering yuor post and there is a problem with the website. I have reported same to the website staff. You should see my post via email soon
Kelly
Sep 24, 2011 | Washing Machines
We have a F01 coming up on our machine. Any ideas.
Generally in order to correct this failure the CCU board will need to be replaced.
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
KENMORE HE2 F01 CODE
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 30, 2010 | Kenmore HE2 Plus Front Load Washer
Seems to be locked out of the wash cycle i get a f1 error code
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHAT DOES F01 ERROR CODE MEAN AND HOW DO YOU FIX
May 06, 2010 | Kenmore HE2 Plus Front Load Washer
I have a F01 code
The F01 fault code is indicating an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board.
Most likely the CCU board will need to be replaced.
Apr 13, 2010 | Kenmore HE2 Plus Front Load Washer
Will not spin under load
Oct 15, 2009 | Kenmore HE2 Plus Front Load Washer
My duet whirlpool washer keeps givin me an F01 code.
Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Not completing
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question##@@
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
96 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
