Question about LG Dishwashers
The bottom spray arm on our LG dishwasher, Model LD-14AW3, will not spin. The diverter valve from top to bottom section does not operate, i cleaned it and the housing near the filter but still no go. any ideas? cheers, Dave
I have the same problem, well - similar. The diverter is moving for me, however it is moving to the wrong position. It seems to move between the upper arm and then blocking off, rather than upper arm and then lower arm.
Did you manage to find a solution?
Posted on Apr 11, 2011
  • Dave T Apr 12, 2011
    my prob turned out to be the motor that moves the valve from upper to lower arm. I had to call a repair man to replace the motor which was quite a big job. hope you get joy with your prob, maybe the stem that connects the motor to the valve is worn. pure theory
  • WanaGo Apr 12, 2011
    Thanks. We had a repair man come by today and he took the dishwasher away. He had a look at the motor and it looks like water was leaking as there was rusty water inside. Motor still works however may be faulty. He is investigating and getting back to us next week.
    Thanks
LG LDF6810ST dishwasher won't clean and spin arms properly
Check for a worn bushing washer on the lower arm. Also, make sure the arms are clean inside - they are propelled by reaction from the water jets spraying out, and clogs will prevent proper water flow through the jet orifices. Sometimes food debris will get through the pump and cause this problem. The diverter valve may also have trash inside clogging it and keeping from seating properly - this could account for both low pressure at the spray arm and water coming out of the lower rack when it should not.
Dec 02, 2013 | LG Dishwashers
Top Rack does not clean, Pump was just replaced. No Error codes. Heat is good, house water pressure is good, drain is good. I've cleaned the filter.
You do not say if the drain pump, the main motor, or the entire motor / sump assembly was replaced. If all the holes in the upper spray arms are clear, replace the VIRO motor. It is a small motor next to the main motor, and it switches a water valve to divert water to either the bottom spray arm or the top spray arm, intermittently. (normally about a 2 minute cycle, unless a "top rack only" setting is selected, etc.) The dishwasher has to be removed from the cabinets to replace it.
Jan 25, 2011 | LG Dishwashers
The top two water water arms do not spin
These spray arm will only get water several times in the wash and rinse cycle. They do not turn at the same time the lower (bottom large spray arm under the bottom rack).
There is a chamber that diverts water either to the bottom sprayer or to the top sprayers, not to both at the same time.
If your top spray arms never get water, then there must be an issue with that chamber motor to divert the water. A new sump assembly that has all the new parts.
Good luck.
Jul 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
LG modelLD-1403W dishwasher. The bottom spray arm
The wheels on the bottom rack could be broken or collapsing..or the rack is distorted or bent..or the spray arm is not attached correctly or is damaged.
Nov 08, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Bottom spray arm on our LG dishwasher LD-14AW3 won't spin.
sounds like no water going into the machine. you may need a water inlet valve.
Nov 07, 2009 | LG Dishwashers
Top arm in dishwasher will NOT spin!
When you say the top arm does not spin, remember that the LG model x811 family has the Vario feature that alternates between routing the pumped water to the bottom arm and then the top arms alternately. So anytime the dishwasher is washing and rinsing, either the lower or upper arms will be spinning.
If the problem is not above, then the motor that drives the check valve may have failed (or the check valve is obstructed inside.)
Hope that helps. Please post back here with what you find, OK?
Sep 04, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
E1 error, pump spinning but not pumping
Just replaced wash pump unit
Thanks anyway
Ernie
Jun 11, 2009 | LG LDF6810ST Stainless Steel Built-in...
Not cleaning on top rack. Pump, fill tube asm. & spray clean. Has any seen if this issue could be the deverter motor in the pump or the control board?
Just to review, the LG dishwasher family, including the LDS5811 has the Verio motor and the check valve that diverts water from the bottom rack to the top rack.
If the valve is blocked/jammed, this would cause the symptom you describe. The valve is visible from inside the DW after you open it up.
It is also possible that this motor has failed.
Apr 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LG LDF6920ST Bottom spray arm dose not work
The LG LDF6920 dishwasher has an innovative "Vario" motor/check valve. It switches between full power spray on the upper arms and the lower arm. So, if you are looking inside the dishwasher to see which arm is spinning, you just have not opened it when the lower arm is turning.
if the root problem is that your dishes are not getting clean with this water conserving DW, go out and buy a name brand detergent powder - like Electrosol or Cascade. And use less powder then you have been using.
Good Luck!
Feb 02, 2009 | LG LDF6920ST Stainless Steel 24 in....
LG Dishwasher LD12AW2
You've done every thing the way I would of done it but check the float switch it is located in the front of the tub near the door if this is open it wont allow power to go to the solenoid see if your getting power across this switch and let me know what you find out god luck
Jan 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
319 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
