Question about Drive Medical Odyssey Full Size Scooter
I have a new Drive Medical Odyssey that will not charge. Several attempts but the yellow "charging light" will not turn green, even after 24 hours. Once I disconnect the charger and turn on the power key it shows no power bars. (with the charger still connected it will show full charge bars if I turn the key to the on position....just to see if the lights worked) Have followed the charging directions step by step. For what it's worth the scooter came with the batteries (2) already installed and connected. Any suggestions? Thanks
  • 692 Answers
Soo Have the provider install new batteries. No telling how long the "new" batteries sat on a shelf and in the showroom without being charged. The batteries are warrantied and should be replaced. While you're at have them check out the scooter after the new batteries are installed and remember to charge before use. Hope this helps
Posted on Mar 25, 2011
Phoenix 3 battery charge idicator
Hi, is it possible for a picture of this ??? the reason being they used two diif versions so I want to be sure...
By the way you say you changed the batteries but what about the charger, are you 100% sure that working okay as in charging the batteries to a ideal voltage level around 27.5 DC ,max voltage should no more than 28.2 volts DC, this will give you a 100% usage of the batteries in question...
Regards
Rob
www.gewizrepairs.co.uk
Feb 01, 2014 | Drive Medical Phoenix 3 Wheel Compact...
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
My hard drive has broken
Does the light flash red, or does it turn off completely?
If it flashes red, you've got an overheating problem. You either need to send it in to Sony, or a third party repair place.
If it turns off completely, you need a new power supply which you can attempt to repair yourself (they cost $30-$40 online) or again, send it in.
Sony charges about $150 USD plus shipping, third party repair places would most like charge $80-$100
With Sony though you usually don't get your system back, they send you a refurbished one (so all your data will be gone).
Usually these fixes don't last (from Sony either). Best bet is to just get someone backup the hard drive data and get your disc out, then buy a new system.
Jul 18, 2009 | Sony Playstation 3 (PS3) Console
Yellow / green light will not go off when charging
Its likely the batteries will take at least several hours to fully charge, if not more. NiCad batteries are slow charging and usually need 4-6 hours for a full charge. Keep them on longer or even overnight but make sure you remove them in the morning. You will probably find the light turns green after 4-6 hours of charging. If lights stay yellow and green after 12 hours of charging, it may indicate a fault in the battery itself where it will not accept a charge.
Jun 18, 2009 | Ryobi Multi-Volt Battery Charger
Kodak EasyShare C643 Digital Camera won't take picture
take your battery out for 5 mts then try it again
"Was this helpful?"
Apr 02, 2009 | Kodak EasyShare C643 Digital Camera
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
Drive Medical Odyssey Full Size Scooter Logo
123 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
