I have an American Standard Humidifier model #AHUMD300A, installed this fall. The amount of water that it drains seems excessive. Every few minutes it releases what sounds like a lot -- how do I know if it is wasting water?
    Brigadier General:
  • 4,736 Answers
The amount of water released into the heating system, depends on what percentage of humidity the Humistat (looks like a thermostat) is set on. Generally 40% is about average. If it's set to a higher percentage, the more water it will use. What you're probably hearing is the holding take filling with water. I doubt that you would hear the water vapor being released into the heating system. If you hiear the tank filling that often, turn the humidifier OFF. Turn the water supply line to the tank OFF, open the humidifier's tank top and check to see in the float valve inside is stuck or not rising completely. That could be the reason you hear the tank filling so often.
Hope this help you Troubleshoot and solve the problem. If it did, please be kind enough to rate my response to you. Thanks!
Posted on Mar 25, 2011
My aprilaire mod. 300 seems to release an excess amount of water through the drain tube. it waste a lot of water.is there a fix?
This is typical especially if there is not much air flow across the humidifier. Make sure the fan is running in the humidiifier and the core does not need to be replaced. Sometimes I have had to turn the water valve back a little to cause less water to go through to conserve that wasted water.
Apr 09, 2011 | Aprilaire 700 Humidifier
I have an American Standard cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl is nearly gone. The flapper appears to be...
As long as the water in the bowl dosent go below the bottom rim your ok there is a trap that the water has to seal that all it needs look at the side of your toilet you will see the trap water saver
Feb 26, 2011 | American Standard Cadet 3 Right Height...
I hooked up my humidifier, and everything seems to be working fine, but I was surprised to see how much water accumulates from the drain...what is a normal amount of drainage over ther first 24 hour...
There is no "standard" amount of water that will be used.
This is a flow-thru type humidifier, which means water runs through an evaporative pad and air blows over it to evaporate the water and humidify the house.
The amount of water the unit uses will depend on the house water pressure, humidistat setting, outdoor conditions, the condition of the humidifier pad, the temperature of the air flowing over the pad, the size of the house, the number of people in the house, the amount of of moisture-absorbing material in the home like textiles, carpeting, drapes, furniture etc., and temperature in the house. There are other factors as well.
The humidistat should be set to the lowest point possible and still provide some humidification (so you don't get zapped by touching metal objects or light switches). Some stats are calibrated in percent, while others simply have numbers on the dial. If you have the stat set too high, you may see frost forming on windows or around doors, in which case the setting should be lowered.
Feb 17, 2010 | Honeywell HE220A1019 Whole House...
When furnace cycles on the humidifier overflow spout has a tremendous flow of water that pours all over basement floor. Is there a valve problem ? I can connect a drain tube from this overflow spout to the...
If the water stops when the heater is not running then the humidifier is working fine. I know it seems like alot of water but that's how it's designed.
Jan 02, 2010 | Aprilaire 550 Humidifier
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
American Standard Sink Drain
I would recommend getting and installing a better quality basket strainer that has a thicker "lip". Also, you need a good amount of plumbers putty underneath the lip of the basket strainer as well. Try not to use silicone to seal under it, it doesn't stand up to use. I would purchase a solid brass strainer rather than the thin stainless ones. They are more expensive, but are worth the money.
Mar 30, 2009 | American Standard Home
Honeywell True Steam heats but continuosly drains / vibrates
I had the same problem.
I replaced the solenoid which resulted with the same problem.
I then blocked the drain using a ball valve, that resulted in the humidifier overflowing.
I do have a fault code (3 blinks) indicating failure to fill tank.
However, if this were true, blocking the drain would have solved this problem.
I have replaced the unit with a new one, and it is now working perfectly.
If you have covered all these bases then I suggest replacing your unit. Hopefully it's under warranty.
Cheers, Rich
Feb 22, 2009 | Honeywell Power Humidifier: Furnace...
Honeywell furnace humidifier thermostat & other
sounds like to me you have a condensation pump attached to your hvac system. this can be used to pump water produced during the cooling of your house when in the a/c mode. if you have a typical bypass humidifier, you will have excess water running past the water panel and it must be sent to a drain of some kind. I would imagine the pump is being used to get your bypass water to the drain. another scenario may be that you have a 90% condensing furnace. if your exhaust pipe for the furnace is made out of pcv pipe, it is a condensing gas furnace. it will produce water when it is running. the water if from the combustion gases being condensed in the secondary heat exchanger. this is normal. some condensing gas furnaces will draw combustion air from inside the house and some will have a second pvc pipe that is used to pulll combustion air from the outside of the house. either way, it is not dehumidifying your house. the humidifier should be able to keep up if it is runnng properly. you should have water running out the bottom drain of the humidifier any time the fan on your furnace is running and the humidistat is calling for humidity. if this is not happening, it is not wired properly.
Jan 16, 2009 | Honeywell Power Humidifier: Furnace...
Humidifier is very hot
doubt if there is a fault. if something gets cold ie freezing section then something else gets hot
Mar 18, 2007 | Fedders RDG40 Dehumidifier
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
