Question about Kenmore Washing Machines
Our washing machine, #110.28812790, only trickiles cold water when filling. I cleaned out the screen at the fill hose. What else could it be?
    President:
  • 3,113 Answers
A bad water inlet solenoid
Posted on Mar 25, 2011
Our gibson washing machine stops filling water from cold valve and when we turned the knob to warm, it fill normal for washing cycle, but it does not fill for spin cycle.. Is this because of defective...
check the cold fill hose screen for silt or dirt. also check at water valve for the same and clean. you must have at least 20psi of water pressure for the water to come in. also on most washers cold water is used for rinsing.
Feb 09, 2011 | Washing Machines
Hoover 700l Cold water is not fillingproperly. Only a verey small dribble comes into the machine. I have reversed the hot and cold hoses, making sure that the setting is on "hot". Problem...
Clogged screen in fill valve on cold side. Remove hose from cold side on valve. Pull screen out. Wash under hot water, and re-install.
Jan 23, 2011 | Washing Machines
Machine won't fill up with rinse water, it washes & spins but the water only trickles in the rinse cycle, i ahve been filling it up manually
Turn the water supply off.
Remove the COLD water hose from the rear of the washer.
Clean the silt out of the COLD water valve on the washer.
Re-attach the hose on turn on the water supply.
Jan 21, 2011 | GE WBSR3140DW Top Load Washer
When we use the cold water it is just trickling in. I cleaned the water inlet screen for the cold water on the back of the machine but it is still only a trickle. Is there another screen inside the back...
Often there is a screen at the inlet of the hose also...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Fills cold and warm but not hot
This is a common problem with hot water lines to washing machines. The hose connecting the washing machine to the hot water supply has a small screen in the inlet of the hose. These are used to keep grit, etc from getting into the washing machine and causing bigger problems.
Here's what to do:
Pull the washing machine away from the wall a little so you can access the shut-off's. Turn off the hot and the cold water valves.
Take the hot water hose off the valve and check the screen in the rubber washer of the inlet hose. Replacement screen/washers are available at local hardware stores for a couple bucks.
You can clean the old ones, just be careful not to damage the rubber washer because that's what keeps your hose from leaking when you reinstall it on your faucet.
While you're at it, clean the cold water screen as well.
REcheck your fill on a hot cycle... you've most likely solved your issue!
May 09, 2010 | Washing Machines
My kenmore 27 wide laundry center will not fill on rinse cycle! the water runs, but does not fill??????
If water is entering the tub on rinse and running out, the drain line is too low or siphoning the water out.
If it is not entering the machine the cold water inlet valve has trash in the screen and must be cleaned.
A test is choose COLD FILL and turn the machine on for regular wash. If no water enters,turn off the water supply and remove the hoses from the machine. Look inside the cold fill connection and clean the screen.
Dec 26, 2009 | Kenmore Washing Machines
Very slow cold water fill, why?
First make sure that you have adequate water flow from the hose bib coming from the wall. You can do this by turning off your cold water connection at the wall, then disconnect the cold water hose. Then turn the faucet on and make sure the water flows freely. The most common reason for your problem is a clogged screen where the cold water hose connects to the back of the washer. To check this, disconnect the cold hose from the back of the washer and clean the small screen inside the cold water inlet on the washer.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not fill when you select cold water
Q - My washer will not fill with cold water
A - More often than not, this is a bad fill valve. Please see the filling section.
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
May 03, 2009 | Washing Machines
Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Feb 22, 2009 | GE WJRR4170E Top Load Washer
Washing machine wont fill
hmmm...wool requires cold water...I'm guessing that first the hot water and now the cold water solenoid valves have become clogged with sediment. test by turning off water. then loosen the hose connection to each inlet in back of washer. then slowly open water valves and let water pour into wash tub if hose will reach, otherwise pour into a bucket. if water comes out of hose, then look for metal screens at hose connections to washer and clean those. if still no water through solenoids (after re-connecting water hoses) then may need to disassemble solenoids and clean those too.
Oct 19, 2007 | Washing Machines
Washing Machines Logo
35 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
