Question about Acer Aspire One Netbook 8.9" Notebook
I power up my netbook, i see the start up screen, then start windows normally to check disc and restart.
    Problem Solver:
  • 19 Answers
Start the machine in SAFE MODE by clicking F8, and some machines are F10, during the bootup. Run a virus scan in the safe mode, I use Malwarebytes which is a free program.
Posted on Mar 25, 2011
Acer inspire one d260 cannot start system recovery
You should start windows in safe mode. By pressing the F8 key right when Windows starts, usually right after you hear your computer beep when you reboot it, you will be brought to a menu where you can choose to boot into safe mode. If it does not work on the first try, reboot and try again as you have to be quick when you press it. when it starts in safe mode, run system restore and when prompted for a restore date, choose an older restore date, probably one you a sure was perfect 2 days before the blue screen issue. This should get your system running in good shape.
Mar 25, 2013 | Acer Aspire One Netbook 8.9" Notebook
How to repair red screen on asus eee pc sea shell
Remove any discs in the computer.
Hold the power button down until the computer turns off.
Press the power button to turn the computer on. If this doesn't work, proceed to step four.
Remove the battery and unplug the netbook. Wait 30 seconds.
Reinstall the battery and plug in the netbook.
Press the power button for ten seconds. If this doesn't work, proceed to step 7.
Insert the end of a paperclip into the reset button to reset the netbook.
The reset button is a small hole that usually appears next to the USB and other ports.
Windows 7
Create a new Notepad file.
Type this code:
taskkill /F /IM dwm.exe
Save the file as displayfix.bat in the following location:
C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
Restart your computer.
hope this helps
Sep 25, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
Windows will not start up or launch start up repair
hi,
please insert your operating system disc in the drive and restart the computer .
Select the boot device as cd/dvd drive and save the settings in BIOS .
restart the system and boot it using the CD.
also, you can insert the disc restart the system in safe mode.
try to restore the computer using system restore.
May 21, 2012 | Dell Inspiron Mini 10v Netbook
WONT BOOT UP
What kind of reset? Explain the Reset that you did?
Is it just freezing or does it restart at the drivers or does it automatically restart?
Sounds like you need to run the Check Disk Utility..
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If Check Disk does not remedy the problem, you will probably need to reinstall the operating system.
Apr 12, 2012 | Computers & Internet
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
My netbook wont bootup actned is saying file or dirory\winclon\logs\2011-03-28. is corrupt and not readable
Try booting it into safe mode
sart the machine with the power button and then start tapping the f8 key once you get a menu choose safe mode let every thing load then go into administrator account if it has one . if it will let you in here then navigate to my computer - double click on the computer icon and then right click on c drive - then click on properties then click on tools this will bring up error checking and disc defragmentor .
Click the check now box and also the automaticaly fix erros box and also the scan for and atemt to fix bad sectors box then click ok -you will get a mesage aying it cant be done now but would you like to check after a restart - click yes then restart your computer -- a message will appear at start up saying windows is checking the drive do not touch any keys just let it start scanning this may take from one hour to several hours to finish -- hopefully once its finished you can start windows normally
I hope this helps
Andrew A
Mar 28, 2011 | Samsung Go N315 101Inch Midnight Blue...
When i switch my sons netbook on it doesnt load and says check cable connection no bootable device
one of his start up drivers is eather missing or failing to start up restart your computer push f2 then go to the boot log with your arrow keys change the off of f2 to f12 then f10 to save then restart push f12 then run windows under your first option then push enter a sec page will come up do you want to run windows go there then push enter so ok if windows want comeup this way you will have to get windows disc because his start up driver is missing.
Feb 04, 2011 | eMachines eM250-1915 Netbook
I had accidently turned of the power as my PC was loading up , so then when i turned it back up it has come up in a black screen saying:- We apologize for the inconvenience , but windows did not start...
Now that PC works in Safe mode i suggest you to run the Disk Check.
Step1: Double click on My computer and then right click on C drive.
Step2: Choose properties and then click on tools option.
Step3: Click on the Check Now tab listed under Error Checking.
Step4: Select both the options under "Check Disk Option" then click on start.
Step5: It will prompt you to restart your computer.
Step6: The Disk Check gets initiated as soon as you your computer starts rebooting.
Step7: Allow it to finish.
Hope this helps.
Jan 15, 2011 | ASUS Eee PC 1000HE Netbook
Random Blank screen at startup. All lights runed on.
shut it down properly from the command line or/and keep power button pressed for 5 sec's or so
Jun 23, 2009 | ASUS Eee PC 901 XP Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
