How do I get the pilot to light on my Rinnai 2000T heater? It was disconnected over summer.
  • 2 more comments
  • redballoonin Mar 25, 2011
    Yes the gas line was turned off.
    Hmmm...there isn't a data plate that I can see anywhere.
    Thanks for your help. Muchly appreciated. I won't take up any more of your time. I'll just call someone out to look at it.
    Very much appreciate your help and prompt responses. THANKYOU muchly!
    Brigadier General:
  • 4,736 Answers
The gas line to the heater was disconnected? Or the Pilot and Pilot Tubing were disconnected?
Posted on Mar 25, 2011
Testimonial: "Fantastic and prompt!"
  • 3 more comments
    No....it was just unplugged from the power point so the pilot went out. The gas connections weren't touched.
  • Rich Landrum Mar 25, 2011
    Ok, that's a relief. Other than unplugged was he gas line turned off?
    Model # 2000T is not an accurate model number. Look on the side of the heater (usually the Left side) for the manufacturer's data plate.
    Turn the gas line back On (Counter clock wise). Ope the control panel door of the heater and turn the Control Knob to the Pilot position. Since there will be air in the line, because the gas line was turned off. You will have to purge the air out of the line. Once the control knob is in the pilot position, push in on it and hold it, until you smell gas. This may take 3 to 5 minutes. In the meantime plug the heater in. Once you smell gas, release the Control Knob and wait 5 minutes for the gas to clear. Then push the Control Knob in again and while holding it in, press the Ignitor Button. I doubt the pilot will light on the first try, so continue to hit the Ignitor Button. Once the pilot lights, hold the Control Knob in for at least one minute, then release it and if the pilot stays lit, turn the knob to the ON position. After that, you can set the heater controls as you usually do.
    That should take care of lighting the heater. Please be kind enough to rate my reply to you. Thanks!
    Not a problem. Glad I could help you and thanks for the 4 - thumbs up rating.
I have a rinnai 30000 btu floor heater. The pilot will not stay lit. I have installed a new thermocouple please help
Contact rinnai support ,make sure the pilot sensor is sitting in the flame,& i hope you did not over tighten it when installing it also lightly sand the end that screws in.
Feb 21, 2015 | Rinnai Heating & Cooling
I have a 30000 btu rinnai floor heater mod 630530. The pilot wont stay lit . I have installed a new thermo couple . please help
be sure the thermocouple is in the pilot's flame and hold down the pilot lighting button long enough to heat it before trying to operate the heater...20 to 30 seconds should be enough. If this doesn't work, you may have a bad gas valve
Need pilot light assembly for Rinnai gas heater model #REH-25-P
Unfortunately, Rinnai only sells repair parts through their authorized dealers. Contact the dealer you purchased it from. If you are not the original owner of the home/heater, you can go to Rinnai's website and search for a dealer near you. http://www.rinnai.us/direct-vent-wall-furnaces/
Feb 28, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a Rinnai Tropic ventless propane heater. I can light the pilot and turn on the burners. However, when thermostat kicks off the burners...then my pilot goes out and I have to start all over. I...
The thing with these is over the summer months when they are not in use they get dust inside the ODS safety pilot. When that dust gets in there it cuts down on the oxygen inside and the safety simply shuts down because it was designed to do that. What you need to do is flush the pilot and allow it to dry. I use a product caller but you could use shop air or even a soda straw to blow out the pilot. I used to sell these thermocouples for ODS systems and they are not cheap. Most times they do not solve the problem either because the pilot is dusty. A brand new one won't solve your problem and a cheaper thermocouple don't work on these. More HERE
Here is the whole thing for $52 not a bad price
The thermacouple alone for these cost nearly as much by itself.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 24, 2010 | Rinnai Unvented Gas Zone Heater. 99% fuel...
The pilot light on the Rinnai gets blocked with
the heater needs service /cleaning along with the pilot to findout why this carbons up
May 12, 2010 | Heating & Cooling
NO HOT WATER N THE PILOT NOT LIGHTING UP
The thermocouple has gone bad.The thermocouple needs to be directly in the pilot flame.When the thermocouple goes out,the flame most of the time will have burned the thermocouple tip a way.If it was not for this devise,the gas would exscape,and fill the home up.This is a safety feature.
Oct 20, 2009 | Heating & Cooling
Where is the pilot light on Rinnai EnergySaver 1001F
If you smell gas in a Rinnai you have a big issue. This heater is what is called a direct vent heater with an electronic ignition so the combustion chamber is sealed and the smell of gas is an indication that you have a gas leak. Please call a professional today.
Oct 13, 2009 | Rinnai Heating & Cooling
Infared heater
When was the last time you cleaned the pilot? In your owners manual there is a cleaning procedure. If you can't find the manual, go to www.rinnai.us. You may be able to download one from their site.
Dec 18, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
701 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
