Question about Garden
I have a newer craftsman 4 cycle mini tiller that is not getting gas to the carb. The primer bulb pushes air into the gas tank thru the return line. the fuel lines are clear. It starts if starter fluid is shot into the carb.
  • gjenshome Mar 26, 2011
    Paul, thanks for your suggestions, I will disassemble and clean the carb. But, it seems strange that the primer just pushes air back into the tank, while not pulling any gas. ( the fuel filter is clean and in the gas) Keep up the good work.
  • 592 Answers
Hi.
I can think of a couple of things that can cause this problem.
First, it might not be that the fuel isn't getting to the carb, it could be that the float is stuck in the little bowl under the carb.
Another thing could be dirt has clogged the needle valve's pathway, not allowing it to operate properly.
If this is the first time you are trying to use it this year, then that could be your problem.
Another thing, if the tiller has sat for awhile, sometimes the fuel will turn into a gummy like substance in the carb, this can happen if the carb bowl was full of fuel when it was put away last time.
The needle valve has a small spring assembly associated with it, it could be the spring has dirt in it, not allowing it to travel like it should.
A complete disassemble and cleaning of each and every passage, opening, valve, jet, and pathway might just get you going again, just remember to write out the order that you take it apart, that way all you have to do is go backwards on the steps to put it back together again.
I hope this helps you out, and good luck !
Posted on Mar 25, 2011
Craftsman weedwacker 358.791070 stopped running; found broken fuel line in tank; changed same;when pumping primer bulb,the line between tank and carb fills up but line between bulb and into return line to...
the filter on the end of the line in the tank may be clogged or the gas cap may be bad they are designed to hold pressure and help push fuel in to the carb
Feb 28, 2012 | Craftsman Garden
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
I am replacing all the fuel line including primer bulb on a craftsman mini tiller/cultivator. is there a drawing or diagram to show which line goes where?
I see that this machine has a 2 stroke engine. These directions work on the 2-stroke engines of Sears trimmers. I've never seen a diagram but many explanations are out there.
The small diameter line out of fuel tank (has fuel filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. The shorter nipple on the bub has a line from it going to the metering chamber side of the carburetor. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Oct 21, 2010 | Craftsman Gas Mini - Tiller/Edger
Craftsman weed trimmer primer bulb is working in reverse
Make sure the line is near the botto ofthe tank.Thanks you for asking and I hope it helps.Please leave me a 4 thumbs up.
Jul 19, 2010 | Craftsman 25cc Gas Line Trimmer
Troy bilt gas trimmer gas lines broke and now I'm not sure which lines go where.
The gas lines probably broke because of the ethanol-laced gasoline we have to use nowadays. It deteriorates them. If the unit has the external purge/primer bulb, the way mine did, it is not that hard. Just remember...the primer bulb "pulls" fresh fuel from the fuel tank to and thru the carb, thus pushing out any air/old fuel in the metering chamber of the carb back to the fuel tank in the return line...that said..
Fuel tank...2 lines...smaller diameter line goes directly to the carb body. There are probably 2 brass nipples on the carb. This line goes to the one on the body opposite the end of the carb with the vent-hole in the cover. This is the fuel pump end...where fresh gas enters the carb.
The larger line out of the fuel tank connects to the longer nipple on the purge/primer bulb. This is the fuel return line.
The remaining fuel line (larger diameter) goes from the vented-cover (has writing on it) end of the carb to the shorter nipple on the purge/primer bulb. This line carrys air and old fuel OUT of the carb to the bulb where it is then PUSHED back to the fuel tank via the return line...so you have a small diameter supply line to carb...an intermediate larger diameter line from the carb to the bulb and finally the larger diameter return line from the bulb BACK to the fuel tank.
Go to a small engine shop and purchase about a foot each of the 2 different diameter fuel lines needed and install those new "Tygon" fuel lines as your fuel line replacement.
Jul 09, 2010 | Troy Garden
Honda FG100 tiller will not prime, filter replaced
Well if the unit has fuel than it should prime unless the primer bulb is damaged and unable to force air/gas through the line. This is definetly a fuel issue, I would remove both the line from the tank to the carb and carb to engine and clean them thoroughly.
When you press the bulb the carb should shoot gas from the unit when disconnected. If this isn't happening your clog is here. If it does eject gasoline than your clog is the clear line which sometimes collects sediment if the gas is poluted.
Mar 18, 2010 | Honda 25cc 4-cycle Mini Tiller
Replacing broken gaslines... were do they go?
the primer bulb draws gas through the carb 'C' and back to the tank'T' leaving a small amount of fresh gas in the carb.to replace the lines from filter to carb & bulb to tank,you may have to remove handle & split the housing halves to find where lines enter tank.look in tank W/ a flashlight.to replace lines cut new line on an angle,feed a piece of # 14 copper wire through hole from inside tank.slide new line over wire,the wire will help align fuel line with hole.use needle-nose pliers to push line into tank,& to pull it through once you can see it.cut off end of hose you beat up with pliers.push filter on hose to carb.drop it back in tank."T' line is the return.dosn't matter which line is through top or bottom hole.
Sep 21, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Roto tiller won't start - primer bulb
Carburetor needs to be rebuilt or replaced. Replaced would be my choice.
May 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
