Question about Dell Dimension 2400 PC Desktop
Help me, my Dell 2400 desktop worked fine yesterday, but today it will power on to boot start up but then i get nothing else on the screen, one green light only and no fan noise. i tried unplugging and replugging but nothing different happens. same thing. i hope i don't have to buy another computer... :(
    President:
  • Dell Master
  • 2,246 Answers
From your explanation it like the problem come from your motherboard, your motherboard was damaged, and you need to change the motherboard with new one
Posted on Mar 25, 2011
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
After automatic updates and a restart, diagonstic lights A & C were yellow and D & B green, nothing comes up on screen, this happen before after an update but i got it to start after several a
If all diagnostic lights are on, then that means that it has something with the software of your computer. The update has affected some of the programs inside your computer thus it's booting up fine.
I suggest that you access safe mode and do a system restore from there. If you don't know how to access safe mode, then follow these:
1. Turn off your computer.
2. turn it on and keep tapping F8 until you see the options. You should see safe mode.
3. Use the arrow keys to select safe mode, then press enter.
4. Your computer should boot up to safe mode.
5. Access the system restore. You can find it in accessories, system tools, system restore. or you can search.
6. restore your computer to the known good date where your computer was still working fine.
7. After completing the on screen procedures, let your computer restart by itself (it may take minutes or more). It will restart and it should boot to the normal windows.
Good Luck!
I hope this helps.
Carlo
Nov 16, 2012 | Dell Dimension 2400 PC Desktop
I have a Dell Dimension 2400 and it had been working fine until recently. When powering on, it goes to the Dell screen, then there is 2 beeps and won't boot up. I checked the lights in the back for...
I've had a look at the Dell website, at
http://support.dell.com/support/edocs/SYSTEMS/dim2400/en/sm_en/advtshoo.htm
Which basically tells you to do what you've already done.
All I can suggest is you check again, but both ends of the ide connections to mother board and HDD / Disk drives.
If its dusty in there, I'd remove clean and reseat the ram and any PCI cards as well.
Jun 28, 2010 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2400. My starts up fine
Most likely a motherboard issue.
Also ensure the CPU Heatsink is firmly attached. If the heatsink is loose, replace the plastic heatsink retainer
If it is secure, then the motherboard is the most likely failure point
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
May 19, 2010 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 that has had a power surge
Um, unless you are happy soldering VERY finely and under pressure then go for it, but to be honest, you can pick one up for £30-£50 that will have everything you need and more!
Oct 14, 2009 | Dell Dimension 2400 PC Desktop
Dell monitor not working
just try running the Test on the monitor(monitor self test) ie disconnecting the video cable of the monitor & leaving the power cable connected & then see if u r getting the red,blue,green multicoloured bard moving on the screen or not,if yes then the monitor is fine otherwise the monitor is bad.
Apr 02, 2009 | Dell Dimension 8400 PC Desktop
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Can't get pass the background screen when pc load
The sequence is:
a) The Dell bios splash screen is displayed,
b) the screen will go black,
c) the disk activity light will flash for about 5 - 7 seconds, then will remain off.
d) you force a power off,
e) wait a few seconds,
f) then turn the machine back on.
g) The bios splash screen is displayed,
h) then a black screen with white text is displayed, reporting that Windows was not shut down nicely and would I like to boot into safe mode or safe mode with networking, or others.
g1) If you choose Safe Mode, Windows will boot up successfully. If I restart, the computer will usually (probably) boot into Windows fine.
g2) If you choose Boot Normally, the computer will usually (probably) enter the black and hung state.
see if that helps and the if possible do a do a system restore to when the system was working correctly.
Aug 03, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
35 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
