Question about Blodgett Kitchen Ranges
No spark to ignite the burner - Blodgett Kitchen Ranges
  • Blodgett Master
  • 43,501 Answers
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Mar 25, 2011
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
How do I replace spark ignitor on GE JGP963SEF1SS gas cooktop?
If none of your burners are igniting, you need a new Spark Module. If only 1 or 2 of your burners are not igniting, you may need a Spark Igniter. Click on the pictures below for a larger image.
The Spark Module is number 318 in the following diagram (underneath the burners):
The Spark Igniter is number 154 in the following diagram:
Jun 02, 2011 | GE Cooktops
I have just replaced all the ignitors and the spark control module on the cook top burners. Prior to this the back burners would cause ignition spark continually when lit. the front 2 burners could be...
first check to make sure all the burner tops are setting correctly on the burner base, if not it will make the flame uneven. the way the igniter works is once they feel the flames on them they will stop sparking. make sure the flames are not too low and they are touching the igniter. check them one at a time. if you have any questions message me back thanks
Apr 08, 2011 | Viking Kitchen Ranges
One of my gas burners does not ignite, I have to ignite it with a match. When I turn on any one of the other three burners, I see sparking at the all of the three other burners (is the sparking at all of...
Yes,all burners spark as a safety feature in the event any gas knob is turned on.
The non sparking burner could be from a bad spark electrode, poor grounding on the burner cap or a bad spark switch for that burner.
Sep 22, 2010 | KitchenAid KGRC707 Gas Kitchen Range
Trouble with front burners: Right burner sparks but does not light Left burner does not apper to spark, but lights If you turn on both bruners they some times light???
The igniters for the burners are all on one circuit so when you turn the burner to light the switch inside the burner valve will cause all burner igniters to come on. As far as the left burner not sparking it could be due to a bad igniter switch in the valve and when you turn on the right burner you are causing all(including the left one) to spark. You will need to make sure that the burner eyes are clear and not plugged. You can use a sewing needle to clear out the eyes. The small eyes at the igniter electrodes are very important because if they are clogged the burner will not light.
Jan 15, 2010 | GE 30 in. JGP328 Gas Cooktop
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
Viking 6 burner range that keeps clicking after ignition
Spark ignition sparks until the flame starts. The flame ionizes the air between the igniter plug and the burner causing the small current to flow between the igniter and the burner. This shuts off sparking. But if there is a gap such as in the spark igniter under the porcelain, technically there still is a gap that the current has to jump and thus the stove keeps sparking. In my case changing the offending igniter plug fixed the problem.
Jul 05, 2009 | Viking VGSC366-6B Gas Kitchen Range
CONSTANTLY SPARKING
ONCE BURNERS HAVE LITE TURN THE BURNER KNOB BACK THE OPPOSITE WAY A LITTLE BIT AND SEE IF THR IGNITER QUITS SPARKING, HOPE THIS HELPS.
Oct 22, 2008 | Frigidaire FGF316 Gas Kitchen Range
Igniters won't turn on & unwanted flammes
You say you have no sparks coming from your gas range, but your rear burner is lighting. That doesn't quite make sense. If some of your burners are lighting, then the problem can't be with the spark module. The spark module sends a spark to ALL the igniters at the same time. That is, EACH burner switch, when turned to ignite, will cause a spark to go to ALL the burner igniters at the same time. Just watch the next time you turn one of your burner switches on, and you'll see a spark at all the burners simultaneously. This is normal. I suspect that you have a bad igniter switch or wiring harness. For example, if you have a front burner that won't light, but WILL light when you turn on another burner, the spark is being provided by a working burner switch. This is also normal. Now, am I assuming that your back burner will not light properly, but will light if you use the front burner? If so, the burner switch for the rear burner is probably bad, or the wiring harness has a break somewhere. Now...if you have no sparks, as you say, but randomly a burner will light, then I would suspect a bad spark module. I hope I'm not confusing you here. In a nutshell: One burner doesn't work, but all others do - bad burner switch, or wiring harness. No burners light, or light randomly - spark module. I hope this helps you.
Jul 28, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas kitchen range
Most problems with gas ranges have to do with the flame--either it isn't quite right or it's nonexistent. Most new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners. If, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
Jan 18, 2006 | Crosley CE35100AA Electric Kitchen Range
Kitchen Ranges Logo
97 people viewed this question
Top Blodgett Kitchen Ranges Experts
gbob59
Gil Shultz
ray gallant
Are you a Blodgett Kitchen Range Expert? Answer questions, earn points and help others
