Question about RELIANCE ELECTRIC WATER HEATER
What is the 120 degree setting on the dial for heat? it is not marked 120 degrees.
  • Reliance Master
  • 43,501 Answers
For 120F water you will need to turn it all the way to hot...or at least close...the new hot water heaters do not get nearly as hot as they used to...
The best way is to check it with a thermometer and adjust as needed...the settings are rarely accurate anyway...
heatman101
Posted on Mar 25, 2011
The water never gets hot when on normal settings
This time of year the water comming in the house is much colder and heater has to work a lot harder to heat 40deg. water than ot does to heat 70deg water in the summer time. its normal.
Jan 09, 2013 | Water Heaters
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
Need to up water temp in a 50 gal rheem 82v52 electric no dial obvious
The two blue rectangular cover plates, held on by two scews, cand be removed by taking out screws. There might be a little piece of insulation present when you pull off the panel, pull that out. You will see a pointer that is shaped kind of like an egg, pointing at numbers which represent temp in degrees. Start with the lower dial, this is your thermostat, Raise temp setting by 10 deg. Hypothetically, depending on what your present setting is, try setting lower thermostat at 130 and upper at 120. Your lower thermostat should be higher than the upper because of heat rising, it is more effecient and both thermostats don't have to be at the same temp. This will save you money in the long run.
May 25, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
How do you set the thermostat above 120 degrees? My dishwasher requires 135 degrees. Thank you.
you shouldn't have to set your heater to 135. dishwashers have a built in heating element for just this purpose.
once you start going over 120 degrees on your water heater, you start creating scalding problems.
130 degree water can cause second degree burns in 30 seconds
140 degree water can cause second degree and even third degree burns in 6 seconds
150 degree water can cause third degree burns in 2 seconds.
be very careful !
Aug 05, 2010 | Rheem Tankless Hot Water Heater...
The heat control valve appears to have stuck, the water is only luke warm
I do not know what heat control valve you are referring to on an electric water heater. On an electric water heater it has two heating elements in most cases. One at the top and one on the bottom. One of these is more than likely defective. Turn the power to the water heater off at the service panel or at a disconnect switch. Now take the covers off both heating elements. Check each one with a ohm meter to see if you have continuity. If your meter reads nothing that heating element is bad and needs replacing. On each heating element is a thermostat to set the temperature. Set the upper element to 120 degrees and the lower element to 130 degrees.
Jan 05, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
My rheem water heater doesn't seem to be heating the water. I have a Rheem model 81SV40D and the water is not hot and doesn't seem to get hot. I have checked the dials on the water heater and they are set...
try setting the bottom 10 degrees hoter than the top could be in short cycle (thatis the bottom calls for heat on the bottom element and set too close so goes back to top and cycles off
Jan 04, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Our 606 reliance electric hot water heater has the letters a b c for the temp control not 120-160 degrees. On what letter a-b or c should the temp be set on to get 120 degrees
We will just assume that "a" is the lowest temperature
to correspond to 120 degrees, while "c" for 160 degrees.
So try setting it at "a" and feel the hot water that flow.
Or it could be the other way. Just feel the hot water that
flow. It will be done in a few minutes. I hope this will help
you.
Nov 26, 2009 | RELIANCE ELECTRIC WATER HEATER
RELIANCE ELECTRIC WATER HEATER Logo
171 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
Paul Nielson
Paul Nielson
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
