Question about Philips GOGEAR SA6045 MP3 Player
My mp4 will not charge - Philips GOGEAR SA6045 MP3 Player
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Aug 14, 2008
My MP4 won't charge or turn on and the USB port isworking fine, my computer won't even recognise that the mp4 is connected
You can turn off the Mp4 for a while and re-install the system ,and then you can change if the port is fit the computer ,you can also used a transfer interface to connected the computer .
Dec 11, 2012 | Philips Gogear Vibe 8gb Mp3 Mp4 Video...
My MP4 player won't work unless it's on charge
system ic failure....battary charging circuit is not initiated due to system ic failure. i think some supporting component like capacitor is defective. better chek with good skilled tech....
Feb 04, 2018 | Apple iPod nano 3rd Generation
The mp4 player will be fully charged and when i take it off the charger and i want to listen to it. It will pause and freeze then will turn off right away. I will try to turn it back on and it wont turn...
i think in 3 possible solutions: 1- try to charge it with another charger 2- connect your mp4 to a computer and run a virus scan, after this try it. if don't, format your mp4 and try to charge it again. 3- the charge system of your mp4 is damaged, so take it to the technical support for to repair it.
Aug 05, 2011 | Mach Speed Trio V430 MP3 Player
My mp4 is not charging.
It is working but not getting charge
Feb 01, 2010 | Audio Players & Recorders
Mp4 player
You can charge either from the mains or from your PC
When charging switch the power switch of the player to on.
Jul 26, 2009 | Network Computing Devices (NSH800S/A)...
My konaki mp4 player wont charge
maybe your mp4 player is switching off... try to turn on...
Jun 01, 2009 | Konaki MP4-NS MP3 Player
Craig mp4 player
Keep your mp4 player turned OFF while charging and keep it in for an hour. Let it charge up. If that doesn't work something else will - Follow these directions carefully!
1. GENTLY hold your Craig MP4 player in hand. 2. Walk over to window and hold it near sunlight for 2 minutes. 3. Shake it gently 3 times. 4. GENTLY place it down and wait 2 minutes. 5. Grab mp4 player and smash it into trash can.
Voila! Problem solved!
Jan 08, 2008 | iLO (2 GB) MP3 Player
Mp4 not charging
sometime the microprosser locks up and sometimes by hitting the reset switch you can free it up- typically the reset is on the rear of the mp4 in a tiny hole-try using a small paperclip to press the switch inside the little hole
Dec 27, 2007 | Sony CDX-MP40 CD Player
MP4 Player won't power up after charging it.
The INova mp4 must be On to charge. This model will not charge when the On/Off switch is in the Off position. Hope this helps
Sep 27, 2007 | Audio Players & Recorders
Philips GOGEAR SA6045 MP3 Player Logo
73 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
