How do i fix an F35 problem on a maytag washer. I already changed the pressure switch and checked the pressure hose
    Sergeant:
    Champion:
  • 202 Answers
Hi.... you also have a bad control board
Posted on Mar 25, 2011
F35 ERROR IN DIAGNOSTIC TEST C:00 I have been getting the same F35/Suds error as previous posters. When I enter the diagnostic test only, I can successfully get through all diagnostics. The first time. ...
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Oct 15, 2011 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
F 35 comes up how do i fix it. then suds
Kevin
Jul 22, 2011 | Maytag Performance MHWE500V Front Load...
My washer keeps getting and F35 error code and stopping
Hope this helps.. The "F35" error code is indicating a problem with the analog pressure sensorswitch operation (key#20). There could be a blockage in the air dome or pressure switch hose. The pressure switch is located underneath the main top on the right hand side. The air dome is located on the back of the tub on theleft hand side. If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch (key#20) part# W10156252. Replacing the pressure switch will likely resolve the "F35" issue.
Jun 20, 2011 | Maytag Washing Machines
My HE3 washer is displaying F35 error
The F35 failure is displayed if the analog pressure switch has a calibration error.
There are two things you can check for this problem if you're comfortable with do-it-yourself.
Remove the washer top to access the pressure switch on the right hand side of the cabinet near the top. See the image below. You'll want to check if the pressure hose is fixed correctly and not loose. Check if the Air trap is not blocked. You can do this by removing the hose and blowing in it towards the tub. It should blow freely and you might even hear bubles. If you can't blow or it's hard to blow then most likely the hose is kinked or blocked.
If the hose is not blocked or kinked then the pressure switch W10156252 is most likely the problem and will need to be replaced.
Jan 01, 2011 | Kenmore HE3T Washer
Getting an F35 failure code on my series 5000 washer
Hi
Thanks for using FixYa. Error F 35 means Analog Pressure Sensor Failure- which means that there is a malfunction of the component detected by the Steamer Electronic Board.
1. Check that the pressure hose is fixed correctly.
2. Check that the air trap is not blocked.
3. Check that the hose is not blocked
If still the issue is not resolved then it is an issue with the water level pressure switch operation and there is a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch. Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Maytag Washing Machines
What does F35 mean on a maytrag washer 5000?
F35
If this failure is displayed, the Central Control Unit has detected
a malfunction of the analog pressure sensor
Possible Causes/Procedure
Check if pressure hose is fixed correctly and without holes
or damage.
Check if the airtrap is not blocked.
Check if the hose is not blocked
Damaged or faulty sensor.
Aug 18, 2010 | Maytag Washing Machines
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Sud error then f35 error on Whirlpool duet washer.....I disconnected already for 5 minutes and also checked the drain and its patent...what can I do?
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 17, 2009 | Kenmore Elite 45986 Front Load Washer
F35 and suds it turns off after 5 mins and whenever I put it on rince only it still cuts off.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
May 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Open Questions:
Washing Machines Logo
186 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
