Question about Mitsubishi WD-73734 73" Television
Television is making clicking noise after repalceing lamp
    Scholar:
  • 125 Answers
You need to leave a lot more information than that.What is the background of replacing the lamp? Where is the clicking noise coming from? Is the lamp light flashing, etc.? My current best guess is that your ballast may be bad, but more info is always helpful in diagnosing a problem. Good luck.
Posted on Apr 05, 2011
Why does my Panasonic 52 inch rear projection TV make a clicking noise with no picture after turning on the power? I replaced the lamp a year ago with no issues.
You might want to look at the lamp again to see it is intact and not shattered----2,000 hours or 2 years is normal life for a OEM lamp but a generic or cheaper version lasts about a year and picture is usually not as bright as with the original ones.
Jun 12, 2012 | Panasonic PT-52LCX66 Projection Television
Just repalced the lamp on still have the red light for lamp on
Make sure the door of the lamp is closed.
If the lamp is good, you may have a bad ballast or a ballast voltage is missing.
www.aaatvservice.com
Jan 26, 2012 | Akai PT46DL10 46" HDTV-Ready Television
Replaced lamp in my HD 61Z575, but when I turn on my TV, nothing happens (no fan noise). After ~10 seconds, the Light LED starts blinking rapidly. Could it possibly be the brand new lamp? Ballast?
The old lamp was in there before the fan work?U replaced the lamp u put the door back on did u make sure the safety latch is off and tightly closed with the the lamp door.The continue blinking LED light does it make alot of clicking noises too.Yes,then the Ballast board it is dead too.The Ballast board only job are to help the projection lamp to ignite to work.
Aug 27, 2011 | JVC HD-61Z575 61" Rear Projection...
Won't power on
Have you checked the power cable or the back cover of your television? Often times, customers forget to plug their television in after a repair. The back cover for most DLP or LCD projection televisions have a sensor as well that will keep the television from turning on. If there is still no power after the steps below, you may have a problem with your power supply module.Consult your owner's manual or a service technician for assistance..
If the previous advice wasn't helpful, try this: Do you hear your ballast "click?" The ballast is what powers the lamp. Initially, UHP lamps need to be jump-started with a lot of energy. The ballast will make a clicking noise as it starts up the lamp. If there is no clicking noise, there may be no power to the ballast or the lamp.
Mar 26, 2010 | Mitsubishi VS-6085 60" Rear Projection...
Soon as plug in relay clicks front stand by indication stay on
it is searching for the lamp circuit
more than likely your lamp is bad and needs to be repalced
i have 3 projectors all differenodels and this usually happens
when the lamp is burnt out or maybe just loose connection
Nov 03, 2009 | Televison & Video
TV DOES NOT COME ON AT ALL
Bad power supply. Symptoms: No display at all, no power indicator light, no sound from speakers, momentary popping or clicking noise, "burnt electronics" smell. Typically caused by failed capacitors. Can be usually be repalced and continue to have working display for a long time. Repair: Replace power supply. Super cheap when it's just a couple of bad capacitor to medium expense when repalcing whole power supply unit.
-=/ Daft Tech /=-
Oct 22, 2009 | Toshiba 23HLV85 Television
HD50LPW42 making noise near lamp
colour wheel doesnot have bearing.but if its faulty it makes some gearing noise or click click noise.check out.
Jul 13, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Keeps switching itsself off
Check the lamp first. Observe the light where the lamp door is on the back of the set. If the light is going out, its likely the lamp, especially if its 2 or more years old. If the lamp has been recently repalced, make sure the lamp door is properly aligned so the interlock switch is engaged.
michtech
Feb 15, 2009 | Samsung HLS4676S Television
I have replaced the lamp.Now the lamp wont come on and tv shutts
Did you replace the lamp cover after replacing the lamp? Make sure the cover is properly installed.
Jan 21, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Mitsubishi WD-73734 73" Television Logo
106 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
