Question about Motorola Mobility Motorazr2 V9x Cell Phone
I have a Motorazar2 V9X. My phone will not charge, does this mean it is the contact or is it the battery?
  • 492 Answers
Try removing the battery and cleaning the battery contacts on the handset and battery with a pencil eraser and with 90% rubbing alcohol using a medium toothbrush. Also check the charger with another phone to see if it is good. If it still does not charge, replace the battery. If you know someone with the same type battery you might exchange batteries.
Posted on Mar 25, 2011
I bought this online from China. I put my sim car in and can make calls but it is charging international calls. Took it to AT&T and she says it's locked and cannot change this. What do I need to do.
Hi Lydia
It sounds like your phone is dialing internationally for all calls since your phone is intended for a region other than that which you are using it in.
To use it with AT&T you will need the subsidy unlock code from the service provider the phone was originally intended for.
Then you'd have to go through the settings to turn off international dialing so it treats dialing as local dialing. I would probably also call your service provider to block international dialing if you are not wanting any unless you specifically enable it before a trip.
Regards
Maya
Motorola Support Team
May 27, 2015 | Motorola Mobility RazR 2 RazR2 V9 V9X 3G...
Unlock at&t motorola razr v9x
Hi, You can unlock a Motorola Razr V9X safer and easier using unlock code. You can get the unlock code for a Motorola Razr V9X from www.wickedunlock.com/motorola-razr2-v9x/rs11wp9/ at affordable cost.
Sep 28, 2012 | Motorola Mobility RAZR2 v9 Cell Phone
My nokia 5320 ran out of charge the other day i tried to charge it up but it would not accept charge.
Hi
First thing to do is to charge the phone with another charger, if the phone charge it means the charger is bad, if not it means the charging port is bad.
You can also try the phone with another battery and charge the battery to know if the battery is not the problem.
The charging port is easy to fix and very cheap to buy. Go to the phone accessories shop and tell them you need your NOKIA port. Get a screw driver, unscrew the screw, open the phone and replace the charging port with the one you just bought.
Thanks for contacting FixYa.
Aug 13, 2010 | Nokia 5320 XpressMusic Cellular Phone
Batteries will not charge on phone
Try cleaning the two metal contacts o the base of the hanset and the the two spring loaded contacts on the base/charging unit. Use an alcohol based solution such as glass cleaner or surgical spirit on a cotton bud or piece of kitchen paper.
If that does not work it may mean that your batteries need replacing.
Apr 03, 2010 | Uniden Cordless Phone
My phone do not charge the new battery
Hello
First of all,get another sony ericcson charger that is compatible with your phone to test if it will charge the battery
If it does then you will have to get a new charger for your phone but if it does not put your battery in another phone and charge,
If the battery charges that means the battery terminal on your phone and the battery are not in proper contact and you should Wedge the battery below at the bottom with a piece of paper that should solve the problem.
Mar 11, 2010 | Sony Ericsson Walkman® W995 Cell Phone
The battery is not charging when I plug my phone in. I have tried different chargers as well as a new battery.
Since you tried different charges and a new battery may be the charging jack in your phone has loose contact .i mean the board of your phone.also check the charger IC.
Mar 05, 2010 | Motorola Mobility RAZR V3
V9x soaked in the rain - hoow expensive to fix?
remove all covers and battery, take out the sim card and then wrap it all in tissue paper and place in an airing copboard or very warm, dry room. Leave it for 24 hours, re-assemble and should be good to go, if not it is probably not woth fixing.
Feb 07, 2010 | Motorola Mobility Motorazr2 V9x Cell Phone
I want to know the correct price of motorazar2 in indian corrency
Hi, Well this will cost you around 18000Rs. I am giving you the link http://www.themobilestore.in/mobilestore/cellphone-buy//.html Here they are giving some discount as the MRP is somewhere around 21000Rs.
Thanks! mannu_rakesh
Aug 22, 2009 | Lands Phones
Whenever i charge my nokia 6680 it seems like its functioning as normal but after several hours of charging still the bar never stops charging. pls help
This is an indication of defective battery. Meaning that the battery could no longer hold a charge. Try charging the battery while the phone is off. If you get the same problem, try using another battery (if you could borrow).
You may also contact the manufacturer for second opinion.
Jul 20, 2009 | Nokia Cell Phones
Nokia n73
The battery is faulty or needs replacing. All rechargable batteries lose their efficiency over time meaning that they hold charge for less time. It sounds like your battery is either at the end of it's life or has a fault. If the phone is less than 12 months old, it's worth contacting the seller or manufacturer to ask for a replacement
Jun 02, 2009 | Nokia N73 Cellular Phone
Motorola Mobility Motorazr2 V9x Cell Phone Logo
71 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
