I need frequencies for a realistic pro-41 handheld scanner
SOURCE: realistic pro 2010 scanner
to program
turn on unit, press program button, key in frequency ###.### press enter. keep advancing thru the channels with the program button until finished
Posted on Aug 03, 2008
One Wire
  • 126 Answers
SOURCE: scanner frequencies
Here is an excellent site for this. Click on your state, then click on your county. It will give you what you are looking for.
http://www.radioreference.com/apps/db/
Rollin CBs
Dean
Posted on Dec 18, 2008
SOURCE: realistic pro 2020 scanner
The Realistic PRO-2052 is an old (vintage) scanner receiver with fixed AM and FM modes on the bands it cover, as specified by the U.S. band allocation. The PRO-2020 covers only the VHF and UHF frequencies and modes AM and FM is not user selectable. Frequencies can be programmed into any of the 20 memory channels
U.S. Coverage: (varies from state to state and other countries. We don't use 30-50 Mhz here in the Philippines for 2 way mobile communications, except for cordless phones)
30-50 Mhz Lower VHF at FM narrowband only (covers mobile, emergencies, businesses, etc. and
cordless phones)
108-136 Mhz Aircraft band at AM narrowband only
138-174 Mhz Amateur and Commercial band at FM narrowband only (2 meter band)
410-512 MHz Amateur and Commercial band at FM narrowband only (70 cm band)
If you're trying to select AM or FM for a specified frequency, I'm afraid you can't do that as it is not selectable.
If you are trying to program AM Broadcast frequencies (mediumwave (MW) or FM Broadcast frequencies (FM radio stations), those were not covered by your PRO-2020's microprocessor. Even if you modify your scanner to receive those bands, you will not hear radio transmission properly since the receiver do not decode FM wideband, which is the standard mode for FM broadcast and Television band.
MANNY DE GUZMAN, JR.
SoundMagik Home Studio
Manila, Philippines
Visit my website at http://mannydeguzmanartist.wetpaint.com
My talents and modeling site at http://teenmodels2007.wetpaint.com
  • 17 Answers
SOURCE: wanted manual realistic 2010scanner
The realistic 2000 series scanners do not have a "VFO" (variable frequency occilator) in the true meaning of the sence. This basicly means that they can only scan the channels or memories that you have programmed.
You can however set a low frequency (like 144 Mhz) and a high frequency (like 145 Mhz) and the scanner will "bounce" between the two, picking up anything in between.
Do you have the operating manual? If not, here is a copy
Turn on your Pro-2010 by rotating [VOLUME] clockwise. (When first turned on, your Pro-2010 may start scanning).
Rotate [SQUELCH] fully counterclockwise. You'll hear a rushing noise from the speaker. Slowly rotate [SQUELCH] clockwise until the noise just stops.
You're now ready to start entering frequencies.
Programming Frequencies
Before programming frequencies, make sure your Pro-2010 is turned on and the SQUELCH is adjusted.
Suppose you want to program Channel 1 to receive 162.55 MHz. Here's how you would do it:
1. Press [MANUAL] and select channel 1. You can do this in two ways:
press [MANUAL] continuously until the Display indicates Channel 1 or
by pressing [1] [MANUAL].
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency. In this case, press the [1] [6] [2] [.]
[5] [5] keys. Check the display to make sure the frequency it shows
is the one you meant to program. If it is, press the [ENTER] key.
4. To add more frequencies, just press [PROGRAM] to advance to the next
channel and follow the steps above.
5. If you ever want to change the frequency entered for a specific
channel, just enter the new frequency "over" the old frequency using
steps 1, 2, and 3.
Make a mistake while entering the frequency? Just press [CLEAR], enter the correct frequency and press [ENTER]. If you're entering a new frequency in place of an old one, the old frequency won't be "erased" when you press [CLEAR]. It will remain stored on that channel until you correctly enter a
new frequency and press [ENTER].
You'll hear a "peep" sound as you press the various keys. This lets you know the key has been properly "entered" into your Pro-2010.
Using the Scanning Function
Your Pro-2010 will automatically scan all the channels you've programmed and stop whenever it finds a signal. To scan channels, just press the [SCAN] key.
To stop scanning, just press [MANUAL] and you can select specific channels
you want to listen to.
IMPORTANT! Your Pro-2010 won't scan unless SQUELCH is set to the point where no sound is heard if a signal isn't being received.
Delay Function
When your Pro-2010 is scanning, it will stop whenever it finds a signal on a channel. As soon as the signal ends, the scanning function will resume. Most communications heard will be two-way. To make sure you don't miss any replies, press [DELAY]. This will cause your Pro-2010 to stay on a channel for two seconds after the end of a transmission, giving you time to hear any reply. To release the Delay function, just press [DELAY] again. The Delay indicator will show on the display when the Delay function is used.
Lockout Function
You may want your Pro-2010 to "skip over" certain frequencies while it's scanning (such as continuously transmitted weather broadcasts). To "lock out" such channels, follow these steps:
1. Press [MANUAL] to stop scanning. Continue to press [MANUAL] to
advance to the channel you want to lock out.
2. When you reach the channel, press [LOCK OUT]. The display will show
[o] to indicate this channel will be skipped over during scanning.
3. To release the lockout, press [MANUAL] to stop scanning. Advance to
the channel that is locked out and press [LOCK OUT] once again. [o]
will disappear from the display.
If you use the lockout function on all channels, scanning will be impossible - you'll only be able to change channels using [MANUAL].
Speed Selection
Your Pro-2010 will normally scan channels at a rate of four channels per second. If you press [SPEED], channels will be scanned at a rate of nine per second. Press [SPEED] again to return to a rate of four channels per second.
Priority Function
You might want to scan other channels yet not miss a call on a channel of particular interest to you (police, fire, ambulance, etc.). The Priority function will let you scan other channels - but if a call is received on the Priority channel, your Pro-2010 will automatically switch to the
Priority channel!
1. Only Channel 1 can be used as Priority Channel: Key in the desired
Priority frequency into Channel 1.
2. Priority function works only when the unit is in Scan or Manual mode.
3. Press [PRIORITY] to start Priority function. A [P] will appear on the
display.
4. Press [MANUAL] or [SCAN] to listen to other channels. Your Pro-2020
will check the Priority channel and switch to it if a signal is
received on it.
5. To cancel Priority function, press [PRIORITY] again. the [P] will
SEARCHING WITH YOUR PRO-2010
One great feature of your Pro-2010 is its ability to "search" for frequencies being used. This means you can hear all the action on the airwaves in your area! To use this great feature, just follow these steps:
1. Press [PROGRAM] key.
2. Press [LIMIT] key. Enter the lower limit of frequency range to be
searched (such as 45.00 MHz). Press [ENTER].
3. Press [LIMIT] key again. Enter the upper limit of frequency range to
be searched (such as 46.00 MHz). Press [ENTER].
4. Press either [up arrow] or [down arrow] to start Search. [Down arrow]
will start search from the highest frequency and go down. [Up arrow]
will start from the lowest frequency and go up.
5. You can control the speed of the search by using the [SPEED] key to
accelerate or to slow down the search.
6. Search will stop when a frequency is found with a signal. To restart search, press [up arrow] or [down arrow]. In Program Mode, search range will be displayed each time [LIMIT] is pressed. It is impossible to change the lower frequency only: to change lower frequency you must change higher frequency first. The higher frequency can be changed any time.
Storing Frequencies
If you want to enter some of the frequencies found during search, do this:
1. Press [MONITOR] when your Pro-2010 finds a frequency you want to store.
2. Use [MANUAL] key to select a channel to enter the frequency your Pro-
2010 found. The display will show the frequency currently stored on
the channel, but don't worry - the old frequency will be erased when
you start to enter the new one.
3. Press [PROGRAM].
4. Press [MONITOR] again. The new frequency found during the search will
be displayed.
5. Press [ENTER] to put the new frequency into the channel in place of
the old frequency.
6. Press either [up arrow] or [down arrow] to resume the search. To
return to manual or program operation, press [MANUAL] or [PROGRAM].
To resume the search from one of the limit frequencies, press [LIMIT]
and then [up arrow] or [down arrow].
Error Indications
Sometimes when you try to enter a frequency for a channel or as a search range limit, you may find an ------ on the display. This means the frequency is in error and you won't be able to enter it into your Pro-2010. Such frequency errors usually mean you've entered a frequency outside the ranges your Pro-2010 operates on (such as 225.00 MHz) or you've put the decimal point in the wrong place (14.682 MHz instead of 146.82 MHz). Check carefully to find your mistake and then press [CLEAR]. You can now enter the correct frequency.
Hope this helps,
M3ODQ
Posted on Feb 02, 2009
regal_anthon
  • 23 Answers
SOURCE: I have misplaced my user guide for my Realistic Pro-36
http://safemanuals.com/brand-user-guide-instructions-owner-manual/RADIOSHACK see if this helps
please rate Thanx
Posted on Mar 08, 2009
How do i program realistic pro-59 scanner
http://support.radioshack.com/support_electronics/8567.htm
don't know what you will pickup. Nearly all law enforcement, ems, fire have gone to digital trunked systems that are encoded. The above link has a link to the operating manual. You will need to know the frequency of whatever you are wanting to listen to.
Aug 28, 2016 | Radio Communications
Can a realistic pro 55 model 20 124 be programmed to different frequencies?
Hello, your scanner appears to be a 10 channel crystal controlled scanner. I'm estimating it to be around 30-40 years old. I think there is a couple companies still making custom crystals but you have to find the freq's #'s to give them. Here is the freq. range it will pick up. Frequency range RX 30-50 / 144-174 / 450-512 MHz I personally would take the money spent for crystals and apply it towards a newer scanner that is programmable so no crystals needed. Here's a link to some more info;
RadioShack Realistic Pro 55
Sep 07, 2015 | Radio Communications
I need to know how to reset my Realistic pro-41
PRO 41 10 Channel Programmable Scanner 200 0301 Operation here is a link to instructions on how to unlock the channels or reset your device, hope this helps
Sep 02, 2014 | Radio Communications
Help programing a realistic pro 2010 scanner
  • Hi, here is the users manual http://www.racingelectronics.com/files/bc80manual.pdf Page 14 tells you how to program your scanner. You have to throw at least one frequency in the scanner before it will receive anything. I can get you some for your area with a state and city.
  • As for programming follow these steps.
  1. Press the manual button.
  2. Now pick what channel you will enter a frequency on by pressing on the number key pad.
  3. Now press the manual button again
  4. Now enter the frequency you want to program.
  5. Now press the "E" button to enter it.
  6. That's it, do it again until your scanner is full.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thanks for using FixYa.
Regards, Tony
Sep 19, 2011 | Uniden BC80XLT Handheld Scanner
How do i remove all codes from my radioshack pro-76 scanner
For a full reset, turn the scanner off and then power it back on while holding the 2 and 9 keys. CLEAr will appear on the display. NOTE: this will clear all frequencies and any other information that you have programmed into the scanner.
To clear/erase a single channel just enter frequency 0.0
Need the manual? You can download/print it here:
http://www.rigpix.com/rs-realistic/radioshack_pro76_manual.pdf
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Dec 03, 2009 | Radio Shack Pro-95 Handheld Scanner
UNIDEN BEARCAT UBC 60XLT
The "e" represents Error, which means you made an error in your entry. Unfortunately, your scanner may be confused, meaning the computer is "stuck" on lockout and cannot get unstuck. I have the same scanner with the same problem... now. I had it looked at by Uniden's engineers, it cannot be fixed unless you replace the computer. They told me it would be best to buy a whole new scanner, probably a new model. So I did. I'm sorry I couldn't fix it for you. But Uniden said you'd be better off getting a new one. In my opinion, don't get a Uniden, get a Radio Shack/Realistic scanner, they're ten times better and are easy to use. For the best Realistic scanner, get a Realistic PRO-2006.
That's the one I have now, it's a gapless frequency scanner which means it can scann everything all the way up to the 1300 MHz band.
Sorry about your scanner though.
Best regards,
Gavin93
Jul 28, 2008 | Uniden BC60XLT-1 Handheld Scanner
Realistic pro 2010 scanner
to program
Jun 24, 2008 | Audio Players & Recorders
255 people viewed this question
k24674
jasbo
jasbo
