Question about Uniden Cordless Phone
Cannot pull up caller ID, phone book and intercom
  • chiefhaney Mar 25, 2011
    My problem phone is a decct 1480-4 si, I think. I have misplace my instruction book and can't find it. the cordless problems seems to be with the handset. when I try to retreive the caller ID, I get unavailable and when I try to scroll for other numbers, I get a ringer and volumn screen. the same happens when I try to get phone book. thanks. jgh
  • 17,130 Answers
Remove the battery from the phone and allow the phone to reset, press and hold all the buttons to clear off the residue voltage on the board.
If you notice any moisture or clogging in the board , then remove and clean the PCB. use some methylated spirit to clean , use a hair dyer to heat off the moisture.
Now make sure that the buttons contact on the board as the non functioning can result in non active program or menu contact. So check the customer pads , clean and reset.
This must solve the issue or else there are errors on the board or the pads.
Posted on Mar 26, 2011
    President:
  • 1,738 Answers
Thanks for visiting FixYa!
Please reply (by clicking on 'Comment') and include your phone's make and model number. Also, please include (if this is a cordless phone) whether the problem is with the base or the handset. And supply as much information as you can about the specific problem.
Posted on Mar 25, 2011
I have charged the base and the two hand sets for 48 hrs. This is a new unit. No dial tone/communication to any unit.
1st-check the intercom function of the units. No intercom recheck the battery connections ,look for a clear tape on them & remove. Recharge batteries.2nd- Intercom OK. Check base connection to wall phone jack. Interconnect phone cable may be bad. Good luck. Have a nice day.
Jan 11, 2016 | Uniden DECT 1480-3 Black Cordless Phone w/...
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
I have no idea what standby looks like; but I can't access the phonebook; I see the symbol, but nothing happens when i press it; I have successfully linked my cell and downloaded the phonebook from cell;...
A qualified person will have to remove the back (and circuit boards if necessary) to get to push buttons. Check for bits of plastic or something stuck between push button and circuit board. Check for corrosion on circuit board or missing /misaligned switch pieces.
Oct 29, 2013 | Uniden D3588-2 Corded / Cordless DECT 6.0...
My panasonic KX-TG5000 phone headsets cannot make or recieve outgoing calls and the intercom function is gargly.
You need to reset the menu once again as it is possible that the phone had hung up as there was LINE PROBLEMS . Once this was reset the CLIP facility came back. So if you can once again remove power battery and keep aside to reset , then start all over to set up the base and slave units to MESH , the intercom and line facility must work.
You can remove the battery from the slave remote units to reset.
Oct 20, 2011 | Panasonic KX-TG4500 Phone
Want to know if cs6319-4 VTech cordless phone has bluetooth capabilities?
No........
CS6319-4 Features:
  • New DECT 6.0 Technology
    - Interference Free Communication
    - Increased Clarity / Enhanced Security
    - Wider Range / Network Friendly
  • 1.9GHz Cordless Phone
    - Dedicated for Cordless Phones by the FCC
    - 30% Battery Life Increase Over 5.8GHz
  • Caller ID / Call Waiting
  • Expandable Up To 5 Handsets
  • Wall Mountable
  • Handset Speakerphone
  • Backlit LCD Display
  • Backlit Keypad
  • Name / Number Caller ID Memory
  • 100 Station Phone Directory / Dialer
  • Conferencing
  • Selectable Ringtones
  • Handset Volume Control
  • Handset to Handset Intercom
  • Call Transfer
  • Last Number Redial
Jun 03, 2011 | Vtech Lands Phones
How can i transfer calls from one phone to another?
First make sure you give each phone an ID on your system. You do this by going into the menu and go to phone options then scroll down to phone ID then press the intercom station button you want assigned for this phone. To transfer call: With caller on the line just press transfer then the intercom station button of the room (intercom station) you want it transferred to. If it is not answered in 45 seconds the extension stops ringing and call is placed on hold
Dec 06, 2010 | RCA 25414RE3A - - Phone
Caller id not working on only 1 phone
It's a good bet that that telephone doesn't ring therefore the system won't pass on the caller id information.
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
May 26, 2010 | Avaya 700340193 Corded Phone
Caller i d
Hello matsikw,
It is either calls through your intercom as you suspected, or AT&T might have enabled the feature then realized it should not be on. It is one or the other.
Kay
Jackson Communications
Aug 02, 2008 | Uniden TRU 448 Cordless Phone (TRU448)
Nortel norstar m7310 phone caller id problems
@relax536
to find out your phone's extension dial
Feature *0 Intercom
May 08, 2008 | NorStar Meridian M7310 Phone
Phone does not ring or show caller ID
From extension 10 or 11.
Press feature 00
Press left intercom twice
Then right intercom once.
enter your extension number
You will see the lights blinking green on the phone, where your lines are. Touch them until they are solid green. If you want to program another extension, press the right intercom button again and enter the new extension number.
Once done, press feature 00 to exit programming.
As far as the caller ID, there is no way to turn it off on the Partner system. My guess is the provider isn't sending caller ID.
Jan 04, 2008 | Lucent PARTNER18 Corded Phone
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
