Question about Intermatic ET70215CR Electronic Energy Control Timer Double Circuit SPDT 12
How do u set the timer to turn on at a certain time and turn off at a set time.
  • 436 Answers
You can download instruction manual here:
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
Please dont forget to rate FIXYA
Thanks
Posted on Mar 25, 2011
Is the timer button for lengh of usage or to set to come on at a certain time
Timer is normally for Length of use. Generally a run down clock.
and Alarm is when it comes on at a certain time using the present clock.
Try it out with a small number for example 1 or 2 minutes
Sep 22, 2016 | Hardware & Accessories
Can the timer be turned off for periods of time without losing the settings and how to ?
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/UPM-timers-and-manuals.html
2) Unsure which timer you have.
Digital wall timers usually have back-up that holds memory for certain length of time before current time disappears.
Usually the programs remain indefinitely until timer is manually reset.
3) Why do you want to turn timer off?
Usually in-wall timers consume 3 watts of power per year.
Contrast big screen TV consumes 3 watts per hour standby loss when TV is turned OFF.
Feb 12, 2013 | UPM Programmable Wall Switch Timer
Brinks 42-1009 ez vacation timer instructions
The Brinks 42-1009 EZ Vacation Timer is preset with 7 full days. You cannot choose when it goes on and off.
To set, spin the dial (clockwise only) until the arrow in the upper right of the center face is near the current day and time. Plug everything in and switch the upper tab to the right. On certain days, it will turn on in the early morning as well as evening or late night.
You cannot choose when to turn the light off. However, if you are home, you can turn the light on by switching the upper tab to the left. Remember to switch it back to the right in order to activate the timed on/off periods.
Jun 10, 2012 | Hampton Technologies Brinks Timer
Why does my tv turn off automaticly
Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. Malena!!
May 10, 2012 | Vizio Televison & Video
Turns itself on at night on standby
that is could the timer setting in your menu check if is not set to start at a certain time....if yes turn it off
if not that could be a bad ground in the timer circuit
but normally its the timer setting in your menu.
hope that will help regards
Alan
May 09, 2010 | Toshiba REGZA 47HL167 TV
Does the TEAC CD x60i with ipod capabilities include an alarm system that wake u up with music from the the ipod that u have pre select?
The unit doesn't have an alarm, but it does have a timer that allows you to set it turn on at a certain time and off at a certain time. Not exactly the same as an alarm clock.
Press the timer button until "timer" indicator and "on" appear in the display. Hour will flash. Press the skip button to change the hour then press the time button. Press skip to change the minutes, then timer button. You now change the off time the same way. The next push of the timer button has set the time. But, now use the skip button to select the source. Pressing the timer button this time will advance to the volume setting and again advance by the skip button. Timer is now set. Make sure your source is ready to play (station on tuner, CD has a disc or iPod is connected).
May 06, 2010 | Teac CD-X6 CD Player
..not able to set timer to come on and go off a certain time
the pin for the timer and be any color.
if you have the pin in the right place, and turn the timer dial to the time you plug into the wall and turn on the black switch on the side. it shoud work.
check the timer after couple of hours. and make sure the timer is running correctly.
chances are there is a flat spot on the timer. it stops at a certain spot.
hope that helps
Apr 09, 2009 | Intermatic & Lighted Dial Timer
Intermatic ET70215CR Electronic Energy Control Timer Double Circuit SPDT 12 Logo
107 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
