Question about Terminator 2: The Arcade Game
My willimas terminator 2 pinball machine shuts down during play
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 40 Answers
Resetting can happen from broken/missing diodes on the flipper coils or bridge rectifier BR2 on the power driver board is going bad.
Posted on Apr 11, 2012
My whitewater pin keeps on blowing fuse F114. display read check fuses F114/F115. Changed 114 but keeps on blowing.
Pinball problems are commonly discussed on pinball forums. For your case go to http://pinballbash.com/forum/index.php?topic=2526.msg23570#msg23570 and look for a very long append from VisitorQ. He gives a nice detailed description of the possible causes.
Aug 22, 2016 | Game Room Guys Flipper Opto Board Williams...
Tip
Flipping pinball flippers like a pro
Growing up my dad was a pinball machine collector, so we always had machines in the house and at a young age playing pinball was one of my favorite pass times. After spending many long hours playing and flipping those little flippers like a manic I realized that there was an art to using the flippers.
When it seems that the ball was going to go straight down the center of the playfield I would use both flippers to try and stop the ball from draining, but it was an action that never worked. I discovered that using only one flipper helped me to catch the ball more often. And this also helped me to discover that you don't need to flip the flippers as often as you might think.
The game of pinball is all about timing and aim, there was one time that I discovered that if I raised the flipper at just the right moment I could bring the ball to a dead stop. This gives you the ability to better control the ball or even take a short break so long as you don't take your finger off that button. You will learn after the first few times playing pinball that it is not a game of random chance that the ball hits places on the playfield and win points but that there is an element of aim involved. With practice you learn the playfield well and the power that you need to hit the ball with to hit the targets. You will find that using a certain part of the flipper will cause the ball to go exactly where you need it to.
Pinball is a very fast paced game, in some instances the ball can be moving at speeds of 20mph! With this in mind when you successfully hit the ball you should immediately let the flipper fall. Holding the flippers up when you don't need them leaves a gaping hole in the center of the playfield and makes it harder to hit the ball if it comes down fast.
With time and practice you too can master the art of being a pinball wiz and amaze your friends with your unbelievable high scores.
on Oct 13, 2013 | Video Game Consoles & Games
Pinball machine won't start game, says looking for pinball and won't start game
This means the game does not find the balls in the machine. First look all over the play field and see if a ball is caught someplace. If so, remove the glass and get it out so it will drain. If you cannot find it, see how many balls are in the ball return trough and if it the correct number. If it is the right number, then one of the switched is probably going bad in the trough. Without the name of the game, I cannot tell you if it is a micro switch or an opto switch in the trough.
Dec 30, 2013 | Video Game Consoles & Games
Pinball stops moving while in play. Always in same spot at top dead center of playfield.
You might want to pull out a level and make sure that the game is at the right angle. It is possible that the game is too level and so the ball doesn't have enough pull to come down the play field. Take off the glass and place the ball in the top center of the playfield if it is properly leveled the ball should roll straight down the center of the playfeild.
Oct 03, 2013 | Video Game Consoles & Games
Pinball keeps bouncing up and hitting the glass, is this going ot scratch or break the glass?
Pinball machine glass tops are made out of tempered glass, they would have to take a direct hard hit to break. I've been playing for years and nothing has scratched or cracked yet so you shouldn't worry about it.
My pinball machine has lights but no sound. What should i do?
I would start by pulling the cord out of the socket for a few seconds before replacing it. Sometimes pinball machines need a little reset and that should do the trick.
Jan 30, 2013 | Video Game Consoles & Games
I dont know how to use a cheat engine 6.0
below is the tutorial for using cheat engine.
Ok....first all you need is:
Cheat Engine
and
Pinball 3D which comes with Windows XP
Ready?
First:
Open pinball 3d in your games directory.
Open cheat engine, dont start playing pinball yet.
Now we are going to try to find the address, that changes the scores of pinball 3D.
So... right now your score should be zero.
Go to cheat engine and clcik "Open Process" which is top-left computer icon.
Open the process named "pinball.exe"
Now since the score is still 0 we are going to find the adress by searching for an address with 0. So go to CE (Cheat Engine), and on value type 0, and leave the scan type to: Exact Value, and value type to:4 Bytes
Now click: First Scan, now... I got 1,995,549 addresses, you should get something similar. Don't worry we'll fix that.
Now go to Pinball 3D and start playing... once you hit something and you get points, immeadiatly click F3 or Pause the game.
Ok for me first thing I got was 30,000 points, so pause, write down what you got.
Now go to CE, and in value type your current score, for me 30,000
and click "Next Scan"
If you got more than 2 addresses, go back, get some more score, come back and re-next scan with your current score
*REMEMBER YOU NEED TO PAUSE YOUR GAME IN ORDER TO WORK*
Once you get 2 addresses on the left
double click on either one, becuase they are botk linked to each other, so if you change something to one the other one will change too.
Well now that you have it on the bottom sqaure, click once on it, and press enter, now type in your new value (or your new score icon_biggrin.gif) Max Score: is 999,999,999
After you put your score, go back to Pinball 3D, un-pause and, you'll notice that your score didn't change, well just make it hit something that gives you points, and VOILA!!!
*I suggest you dont put 999,999,999 for 2 reasons:
1 to get Game Over so you can sumbit your score you need to lose, to lose you have to play... and alwyas.. always you will get some points and it will reset to some low score. i suggest you put something like 999,900,000 believe me you can get 100,000 easily in pinball 3D
2nd: if you wanna impress someone but they dont you know your hacking the program, put something like 5million something like for example:
5,458,225 thats more believable than 999,999,999 they'll know you hacked it.
enjoy.
Apr 27, 2011 | Computers & Internet
We have a Mattel Las Vegas 1977 pinball machine. After playing a little while the lights will shut off and the score will light up as all nines and then fade off. It's not registering lost balls all the...
I have the same pinball machine. Mine also has the same symptoms. There are two red circuit breaker/fuses underneath next to the power switch. If I reset one or both of those it usually starts back up..
Sep 24, 2010 | Mattel Video Game Consoles & Games
Terminator 2: The Arcade Game Logo
407 people viewed this question
Top Terminator Video Game Consoles & Games Experts
James Wishart
Are you a Terminator Video Game Console and Game Expert? Answer questions, earn points and help others
