Question about Sony Playstation 3 (PS3) Console
Red colored back ground - Sony Playstation 3 (PS3) Console
    Scholar:
  • 34 Answers
This is similar to the red light problem but the reason you get a screen is because the GPU has overheated.
You just need to stop the heat build up getting to the main chips and you will be able to play your games again.
To do this you have 2 choices:
Send it in and they will fix it for you although something to bear in mind that it will take 4 weeks and cost you $150 for the fix.
Or you can use a good PS3 Repair guide and fix it yourself.
A word of warning before attempting any home repair solution:
CLICK HERE TO CHECK OUT A FULL REVIEW OF ALL THE PS3 REPAIR GUIDES FIRST
I hope this helps.
Posted on Apr 03, 2011
Maytag neptune dryer
Hey white to white, black to black red to the multi colored pole, and the green one is the ground wire,, . I done that before,, lol,, good luck ,, thanks
Oct 05, 2008 | Maytag Neptune MDE6700A Electric Dryer
I disconnected the pump and need to know where the red black aND WHITE wires go
Hi, this is John the Hayward tech. You say the wire colors are Red, Black and White. Does not seem that the wires colors were correct from the start. Not knowing your voltage let me clarify some things. Normally if you have 115volts coming into the pump you wire colors should be Red or Black to L1 White to L2 and a green ground to the green ground screw. If you have 230volts coming into the pump the two hot leads are normally red and black with a green ground. The red and black wires go to L1 and L2 does not matter red or black. The green goes to the green ground screw.
Sep 03, 2014 | Pool & Spa
What color is the positive wire on the back-up light
there should be a red, brown, green, and white wire... green is for ground, make sure ground is clear of any dust or dirt, red is your power from the back light, red is the power to your back light, white is usually for the blinker. hope this helps
Jun 28, 2014 | 2008 Ford Explorer Sport Trac
Don't know radio connector color code
This should help.
1987-88 Plymouth Voyager Stereo Wiring
Constant 12V+
Red
Switched 12V+
Red/White
Ground
Ground/Back Strap
Illumination
n/a
Dimmer
Orange/White
Antenna Trigger
Yellow
Antenna
Right Front
Front Speakers
5 1/4" Dash
Left Front (+)
Green
Left Front (-)
Green/Yellow
Right Front (+)
Purple
Right Front (-)
Purple/Yellow
Rear Speakers
6" x 9" Tail Gate
Left Rear (+)
Brown
Left Rear (-)
Brown/Yellow
Right Rear (+)
Blue/Red
Right Rear (-)
Blue/White
Sep 20, 2011 | 1987 Plymouth Voyager
My cb has red and black wires coming out the
The Red is the Hot (+12v) and should be fused to the battery.
The Black is the ground, this should be ran directly to the battery, if not you may get engine noise.
Nov 12, 2009 | Uniden Radio Communications
I had to change the three prong wire and replace with four prong
If you are converting from 3 to 4 prong service, that is fairly simple and should be done as follows:
If you purchased a pre-terminated cord that has a molded plug on one end and four wires with lugs on the other then that is what you have to attach to your dryer. Start by pulling the dryer out far enough to gain easy access to the back panel. Depending on the model, you will need to find the place where the cord feeds through the back and feed the new wire through that opening ( there should be some kind of cable clamp that guides and clamps that cable through the back panel). Once fed through, look for the terminal block on the back of your dryer. You will have at least 3 terminals that should be color coded red, black white or green) Start by installing the red to red, black to black and white to white ( or green) and then take the green wire end of the cord and look for a ground stud on the back of the dryer. There should be a terminal or sheet metal screw that you can attach that green wire to the dryer. The green wire is a safety ground that bonds the dryer to earth ground and provides a path to ground through the dryer chassis should you develop a short top ground. That path is provided to protect you so that you don't become the path from power to ground. Hope that helps...
Just remember to do all this wiring with the cord unplugged from the power source...
Regards,
Rick
Nov 23, 2008 | Maytag Dryers
GE Profile power cord
White is the neutral circuit and it goes to the center connection of the terminal block on the dryer. Red and Black are "hot" wires and they go to the connectors on the ends of the block, doesn't matter which color is on which side. Green is the ground and it goes to the cabinet ground.
Post back if you have any questions.
Mike
Jan 06, 2008 | GE Profile Harmony DPGT750EC Electric...
Sonny tv triniton
Buddy, Not a problem for the average Home Technician. Unless you are good at Solid state Electronics service. Problem is faulty Red Outpuit Transistor or associated components. Best to seek professional hellp.
Mar 31, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Playstation 3 (PS3) Console Logo
48 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
