Question about IBM ThinkPad T42 Notebook
I have a t42 it wont boot up it says operating system not found can this be fixed?
  • 1,272 Answers
Definitely!! Please ensure that you have not connected a USB drive or external hard drive before booting up the laptop.
Also, it seems that you will have to run the recovery CD on the laptop to get the OS back up and running.
Regards
Anand Gupta
Posted on Mar 25, 2011
Not booting up
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Apr 03, 2012 | IBM ThinkPad T42 Notebook
T42 gets message"NTLDR" not available. Tried to
Don't try loading windows with out fixing the NTLDR...Try this simple steps in recovery console,
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
  • Then rebuild the boot configuration boot.ini file by
    Attrib -H -R -S C:\boot.ini (if not found skip the next line)
    DEL C:\boot.ini
    BootCfg /Rebuild
    Note:
    Do not use the repair option in the recovery console.
    Or, if you can get into XP, even safe mode, you can arrange to bypass the
    password by the following registry change:
    Click on Start then click run and type Regedit. Navigate to the key mentioned below,
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Setup\RecoveryConsole
    Set the DWORD Security Level value to 1
Hope this helps
Dec 27, 2010 | IBM ThinkPad T42 Notebook
My ibm thinkpad T42 keeps restarting after opening
try to boot your PC first on safe mode and restore the computer back to the date where it is working fine by using system restore. if same issue occur. you have to reinstall your operating system by using the recovery disk. your windows is already corrupted.
Apr 02, 2010 | IBM ThinkPad T42 Notebook
IBM ThinkPad T42 BOOTMGR is missing
Go in to the setup and change the boot order, to CD then Hard drive. When you boot it will at the bottom of the screen show you press .... for setup. The restart Ensure that your operating or recovery disc is in the dvd rom, when it promps press any key to boot form cd, do so, wait for the system to run setup when it prompts press... to run ASR (automatic system repair) do so. This shoul sort it out, if not, it might be harware failure. Good luck
Mar 03, 2010 | IBM ThinkPad T42 Notebook
My laptop will not boot - Operating System Not Found, cannot enter BIOS system - nothing at all. When I try to access the BIOS, the key keeps beeping. It is a Type 2373. Thank You -- IMCND
How are you attempting to enter the setup (BIOS)? Here are the steps:
Press the blue Access IBM button when the message "To interrupt normal startup, press the blue Access IBM button" is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
Feb 18, 2010 | IBM ThinkPad T42 Notebook
I keep getting codes pxe-e61 media test failure,
Something went wrong with your last installation. try reinstalling windows. But, before that go to BIOS and check the BOOTING devices
Nov 18, 2009 | IBM ThinkPad T42 Notebook
I cannot get my pc to load up. i keep getting codes pxe-e61 media test failure, check cable. the other code pxe-m0f: exiting intel boot agent operating system not found.
I need a small clarification are you calling for a desktop computer or a laptop.
if its a desktop computer, reseat the video card on the computer and then try restarting the system. The problem can be casued because of loose video card.
Thanks for using Fixya
Proton
Jul 12, 2009 | IBM ThinkPad T42 Notebook
Operating System not found PXE-E61 Media Test Failure IBM T42
Some BIOS allows for a hard drive diags. try it to test the hard drive, if ther is no such utility you need to test the hard drive anoter way.
Basically either the hard disk controller has failed or the hard drive is faulty. In most cases the hard drive is dead.
To check if the hard drive is OK, remove the hard drive and attach it to a USB hard drive adapter then plug it into a working computer's USB port. If the computer sees it as an external drive and you can view the contents of the external drive then the hard drive is OK.
Mar 21, 2009 | IBM ThinkPad T30 2366 Notebook
Turns off autometically
How far does it get on the boot process? Does it open the operating system completely before shutting down? Do you get any error messages, and does it go to a black screen stating Windos wasn't shut down properly? Answer these and I'll have a better idea of what's going on.
Aug 26, 2008 | IBM ThinkPad T42 Notebook
IBM ThinkPad T42 Notebook Logo
61 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
