Question about Ryobi 30cc 17" String Trimmer Zrry30530 Wcurve Shaft
Where do I buy a spool and cap for this model Barry New Zealand
    Guru:
  • 479 Answers
Hi Barry,
Don't know which part of New Zealand you are in but have a look at this webpage and enter your region to get a list of service centres:
http://www.ryobi.co.nz/Service-Centre-Locator.aspx
Hope this helps!
Posted on Mar 25, 2011
Testimonial: "Appreciate the prompt reply and the information you provided - much obliged"
Replace line
Two possibilities:
1. Buy a new spool. Make sure you bring your make and model/size to the store to get the correct replacement spool, or
2. Buy new line and manually wind it into the existing spool. Smaller lawn trimmers and edgers use smaller diameter line than larger lawn trimmers and edgers.
Good luck.
Paul
May 31, 2015 | Garden
I NEED A SPOOL COVER WHERE CAN I GET IT ?
How to make a spool cap cover for an American Gardener YS24 (Weedeater XLT24) Trimmer
If you've tried to buy parts lately for your trimmer, you've noticed they are harder and harder to find. In fact, I was unable to find a spool cap cover, so I came up with this work-around.
Before you start this project, it's important to save any parts from the old spool cover-especially the top, if you can. The top is needed to make a spacer for the new cover that will still allow you to "bump" out the string.
I used a Craftsman 71-64215 replacement spool retainer to make my new spool cover cap. It fits the Craftsman C3 19.2 volt 74381 String Trimmer (CRAC06540 spool cap). I found this cap at a local Ace Hardware, but apparently it is also getting hard to find-I googled the Ace Hardware number to find it on the web-"7314644 cap." I bought a couple extra from HardwareDistributors.com. Note that the diameter of the cover at the tabs is the same diameter of the old cover-although the diameter of the cap is slightly larger.
Take the old cover, and using the tab from the old cover, mark a line on the new tabs the same width as the old. Make sure you center the old tab on the new tab so you will remove the same amount of plastic from each side of the new tab. I used a dremel tool with the cutoff wheels to cut the tabs on the new cap to the same size as the old cap.
If you look at the new cap, there is a round plastic circle ridge on the bottom of the cap. If you look closely you can see a slight indention, or discoloration on the top of the new cap matching the circle on the bottom. You need to cut the plastic out of the new cap matching the plastic circle. I used a dremel tool with a metal cylindrical grinder to do that.
Once you get everything cut, put the old cap into the new cap so that the spokes face down toward the similar spokes on the top of the spool. You may have to trim the old cap so it fits into the new cap.
Finally, snap everything together into your trimmer-don't forget the spring. Note that the new cap has about a 1/8 inch gap above the spool. However, this doesn't seem to affect the trimmer-and you can still "bump" the head to eject the string.
Apr 27, 2015 | American Gardener Get the lower price on...
Need to buy a new bugaboo cameleon front wheel circlip and dome
Hi Barry
We'd recommend you contact Bugaboo for assistance.
Bugaboo Official Site
Mar 20, 2014 | Bugaboo Baby Gear
Need parts for American Gardner Yardstick model YS24. Specificly the line head assembly.
Sep 01, 2013 | Weedeater Garden
I have a craftsman weedwacker model 257 799750 and need to know if I am putting the spool on correctly. Is it the spring then the spool then the cap or the spool then the spring then the cap. when I put...
Spring, spool then cap....if that way doesn't let the line out correctly, then it is possible you have wound the line on the spool in the wrong direction. Try taking the line off and winding it on the other way.
Aug 07, 2010 | Craftsman Garden
How do you add trimmer line to Troy Bilt TB539E Weed Eater?
This model trimmer uses .095" diameter line, your local home improvement store will carry replacement line and it will also carry a replacement spool with the line already spooled on it.
This trimmer is a "bump advance" trimmer meaning you bump the head on the ground while it is spinning to advance line out.
What to do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head if the trimmer and unscrew the cap and CAREFULLY remove the spool...you do not want to lose the spring! Take a look at the spool, it will show the direction to spool the line, spool the line then replace the spool by first putting the spring back on the shaft, then put the end of the line through the hole(s) on the side of the outer head, press the spool in place and screw the cap back on.
Of course you can eliminate about 90% of the headaches by buying a pre-spooled head at your local home improvement store...then you follow the directions above and can skip the spooling part. Cheers!
Sep 07, 2009 | Garden
Broken spool cap
I would say yes, here is a site for parts, if this is not helpful please specify your model number
http://www.toolpartsdirect.com/blackdecker/blackdecker-41.html
also here is the actual black and decker parts site.
http://www.blackanddecker.com/CustomerCenter/Parts.aspx
Jun 01, 2009 | Black & Decker String Trimmer Cordless 12"...
Lost Spool pin and cap for QuikStitch SP-402
Welcome to FixYa. If you have a spool stand, that might work as long as you can thread the machine properly (give it a try!). When the thread is placed on the machine's spool pin, the spool cap keeps the thread in place and helps the thread unwind evenly - so if you are using a spool pin, you really do need a spool cap.
If the spool stand works, you are good to go. If you need to order replacement parts, I've provided a link the manufacturer's website. From there, you can contact customer support and find out if parts are available. If you can't order replacement parts, ask customer service if the machine is compatible with another brand. Another option would be to buy a spool pin and cap at a sewing machine dealer. Take the machine with you and and make sure the parts fit before you buy them.
Here's the link to the site I mentioned:
http://www.topinnovations.com/products/sew/SP-402/SP-402.html
Thanks for stopping by. If you have an extra minute, feel free to rate my solution. I'm eager to improve my solutions if they are not helpful. If you have further questions or would like to consult with another FixYa expert, just leave a comment and I'll do what I can to resolve your problem.
Oct 25, 2008 | Sew Pro QuickStitch SP-402 Mechanical...
Blackberry Curve use abroad
You can take it anywhere b/c you can buy a phone in a different country theres no boundries to a cell phone.
May 16, 2008 | RIM BlackBerry Curve 8310 Smartphone
Ryobi 30cc 17" String Trimmer Zrry30530 Wcurve Shaft Logo
258 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
