Question about Samsung SyncMaster 740N 17" LCD Monitor
Defective monitor samsung 740n no display how to fix it?
  • 11,361 Answers
Common failures are due to bad DC filter caps, look for caps with domed tops first.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 25, 2011
Samsung LCD monitor Model 740N no display.
pls chek 1000/25cap ,and inverter fuse, and 5402 ics
Jan 11, 2013 | Samsung SyncMaster 740N 17" LCD Monitor
My monitor samsung 740n is displaying a message "not optimum mode"
You must set it's performace from display properties( appearance and settings), so video card should work fine.
Mar 30, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung's LCD monitor SyncMaster 740N; backlight failed, I replaced bulging capacitors on PSU and burnt fuse but backlight is still not coming on
There is a inverter transformer on the board that may be defective that generates the high voltage that drives the lamp, you may end up having to replace the whole inverter board to get it working again.
Jan 26, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung sync master 740N no display. Flickered started then the display goes after its been on for a short wile. Could this be a problem with the capacitors?
Yes, look for two 1000uf capacitors on the power supply PCB near the output cable to the main PCB. They will have swelling and discolouration. Replace those and should fix your problem.
Oct 06, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
May samsung lcd monitor have no power
Power supply unit might be bad.
Check for popped capacitor.
Mar 28, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
LED POWER ONLY LIFE, SCREEN DISPLAY DARKNESS
theres only one solution to the problem you have to replace the whole power supply board .its easier to replace them than finding and soldiering the defective parts like the capacitor on the board .u can just replace the power supply board if u think the power has a problem. if it doesnt work then u have to replace also the main board or the board connecting the rgb cable.its more expensive to replace the board but its worth it. ur lcd will work better and its easy to put them on the lcd casing .
Mar 01, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung syncmaster 740N 17 inch no display
manual and drivers
http://www.samsung.com/it/function/search/resultList.do?searchWord=913v&ct=0&sort=0
Oct 04, 2008 | Samsung SyncMaster 710N 17" LCD Monitor
Samsung monitor problem
update the driver of your video card or download the Everest Ultimate Edition
May 21, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung SyncMaster 740N 17" auto adjustment locked
I just had my Samsung 740N LCD monitor auto adjustment lock 2hours ago.
But i found this cool solution at
www.fixya.com
"Press down
the menu button(1st button on the left) for 5sec or until the menu display gone?"
and it works for me. Hope it will work on you
Thanks
Apr 28, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung SyncMaster 740N 17" LCD Monitor Logo
144 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
