Question about AOpen MA-691 Computer Speakers
Do I need a specific sound device for these speakers to work?
  • AOpen Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 25, 2011
I just got the Logitech Lapdesk N700. It works but the speakers sound awful. They crack and pop and sound real distorted. I am running a Windows 7 Ultimate.
click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
you might need to select stereo speakers
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jun 18, 2011 | Logitech N700
My insignia speakers want work with my hp computer i need software to download them
speakers do not need any kind of software to work, it's a problem with your computer.
You should try to update your sound drivers, and plug the speakers into the right sockets (green). make sure to set your sound card to the main sound output device.
Mar 02, 2011 | Insignia 2.0 Speaker System (2-Piece)
3 out of 4 of my satellite speakers are not working. All the speakers work through the remaining working satellite port when switched. What should I do?
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
Feb 04, 2011 | Logitech Z-560 Computer Speakers
I cant get my NEC speaker to work for my computer. Is there a specific plug in the monitor that it goes into? Or do you need a software?
click start control panel sounds and audio,volume you can adjust the volume or
advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Jan 06, 2011 | NEC Orca Jazz Speakers Assembly Kit...
My speakers wont wo
Hi Jennifer,
When did sound work fine last time ??
Did you make any specific changes ??
Check if it is set to mute... if it is unmute it..
To unmute it-- you can click the little icon at the task bar at the bottom of your screen -- clear the box and see if it works..
If everything seems ok do the following :--
Go to control panel - click on sound devices option - see if all the options are greyed out -- if it is then you need to reinstall the sound drivers ..
You can let me know your computer model number and i'll paste a link for you so that you can download the driver...
Thanks..
Sep 07, 2009 | Harman Kardon HK695 Computer Speakers
Trouble with rear speakers
This may be a software issue. If you only had two speakers before, the software will not use the rear speakers.
Go to Control Panel. Click on "Sound and Audio Devices". Under the Volume Tab, at the bottom, you will see a picture roughly representing the type of speakers.
Click on the Advanced button.
Click on the arrow in the pick box, and choose Surround Speakrs or the 5.1 Speakers.
Click Okay. Try the speakers again.
Apr 06, 2009 | Boston Acoustics (BA7800) Computer...
I cant install Computer Speakers can someone help me? I'm trying to use my Windows media Player but it won't work because it says there are no sound devices installed. What does that mean? How do I find...
What you need to do is go to start, control panel, device manager and see what sound device is installed...then you need to select update driver. Otherwise you need to see what specific hardware sound device you have, copy and paste into google for a driver search.
Jun 07, 2008 | Altec Lansing Multimedia Computer Speakers
HELP - we have no sound!!!
Ok i looked further into your problem. Let me try and explain something to you.
When i look up the specifications for your speakers, it says you can plug them into an ipod or or any audio device, (including your computer) , and then they will work. You cant install audio drivers for the ipod, but! they will still work with the ipod. Therefor you dont need a driver for these speakers. Now what the problem MAY BE is your sound card. I can possibly help you if you can give me some specifics as to which sound card you have and what Operating system are you using ( windows xp, windows 98, windows vista etc etc..) please let me know iw ould like to help!
Jan 20, 2008 | ViewSonic NeoSat SP2002 Computer Speakers
Dell WL6000 Problem
goto the sound options and make sure you have selected the right output specific to your card
you can do this from the control panel
then select sound speech and audio devices
then click sound and audio devices
then click the audio tab
cliack advanced
and select your "speaker setup"
hope this helps
Nov 10, 2007 | Dell WL6000 Computer Speakers
My Altec Lansing
Hi, I would suggest that you should check into your computer rather than your speakers. Specifically your sound card and its drivers. Try going to your Device Manager and check your Sound, Video and Game Controllers. There should not be any Yellow markings anywhere. Cheers
Jan 16, 2007 | Altec Lansing ACS 295 Computer Speakers
AOpen MA-691 Computer Speakers Logo
132 people viewed this question
Top AOpen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an AOpen Audio Player and Recorder Expert? Answer questions, earn points and help others
