Question about Microwave Ovens
Refigeration line in freezer gets so hot it glows red.
  • Microwave Ovens Master
  • 43,501 Answers
What you are seeing glowing red happens to be the defrost coil, not the refrigerant lines... the coil glows red to heat the refrigerant lines and defrost them...
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 25, 2011
  • 96 Answers
Thats your defrost element :) If you are not having any problems with your freezer staying frozen, that is normal
Miele Fridge Freezer not getting cold
Power off and remove all fluff under the fridge.
Compressor can be hot but not too hot. Are the settings ok for desired level cold. Is the fridge too heavily loaded? Try now.
Aug 07, 2013 | Miele Microwave Ovens
Sunbeam chest freezer SBCF5WBX appears to operate but suddenly stopped being cold. It defrosted and thawed contents. Power is on and all electric lines and connections are in good condition. Freezer is...
Where you say that it appears to operator, do you mean that the compressor is working? If so, then your condenser grills might be dirty and causing the unit not to cool effectively. Is the sides or back of the unit getting hot? If so that could be the cause - a cleaning of the condenser coils.
But if your compressor is not kicking on or is very hot to the touch, then it might not be operating correctly. If it is not activating then it could be the contactor-relay or start capacitor.
Sep 10, 2011 | Microwave Ovens
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
Problem with the Oven of the Magic Chef Stove & Oven, the Red Glow does not turn red at all, even though the power is connected and even the lamp in the oven can be turned on and off. But still the red...
Sounds as if your element ( the thing that glows red) has burnt out. I have found a few stoves dealers who may be able to fix it or providea new replacement part.
Here is a link to the list: http://www.yellowpages.com.eg/search/c3RvdmVzXzFfMF8gXzBfIF8gXyBfIF9HcmVhdGVyIENhaXJvIChpbmNsdWRpbmcgQ2Fpcm8gJiBHaXphKV9f/search.html
I hope this helps!
May 03, 2011 | Microwave Ovens
The fridge section of my Candy CPCA270FFK frost free fridge freezer is cool but not cold whilst the freezer section is warm. The appliance is silent, the compressor is very hot to touch and the control...
IF THE COMPRESSOR IS TO HOT TO TOUCH WITH YOUR HAND MORE THEN LIKELY THE REED VALVES IN THE COMPRESSOR ARE PASSING HOT GAS BACK INTO THE COMPRESSOR AND HAS DAMAGED THE UNIT. MY ADVICE IS TO LOOK ON TOP OF THE COMPRESSOR GET THE MODEL# & SERIAL # & MAKE AND LOOK ON LINE AND GET A PRICE FOR A NEW COMPRESSOR, PENDING ON MAKE AND MODEL THEY RUN AROUND 3-4 HUNDRED DOLLARS JUST FOR COMPRESSOR INSTALL CAN COST MORE THEN THE COMPRESSOR UNLESS YOU KNOW SOME ONE WHO HAS THETOOLS TO DO IT RIGHT
Feb 05, 2011 | Microwave Ovens
My freezer side GE Profile Performance refrigerator collects water at the bottom and freezes. I have to dig out and cclean the ice every 2-3 days. I turned off the water line , but it still does it. what...
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Aug 25, 2010 | Microwave Ovens
Heating element comes on to high by it's self when no buttons have been touched. I had just finished cooking a cassorole. I closed the door and sat down to eat,when after 5 minutes had passed the exhaust...
I am sorry but the relay that controls the heating element has become faulty, if you or someone you know can change it then just follow the heater lead to the relay and replace
Feb 18, 2009 | Sharp Microwave Ovens
Microwave Ovens Logo
150 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
