Question about Mmats Pro 12 Car Subwoofer
I was wondering can i put the mmats pro 12 in an dodge ram being that the space under the seat is so small and do the pro boxes help any. and is there a box that will handle a good 12 in a dodge ram
The MMATS Pro is going to be too deep for the Pro Box for that vehicle, the only other solution ,may be a custom fiberglass enclosure..
Posted on Sep 19, 2011
Where is the fuse box on a,98 Dodge RAM 1500
Leonard, interior fuse panel is open drivers door, at the end of dash driver side behind a small interior access panel, under hood fuse/relay center(box) is beside battery on inner fender.
Video links will show you fuse boxes location.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Interior Fuse Box Location 1994 2001 Dodge Ram 1500 1997 Dodge Ram 1500 5...
Dodge ram 1500 fuse box gone bad
Feb 29, 2016 | Dodge Cars & Trucks
Air space in a ported box
a sealed box will alow more, deaper base however what you are askin a ported box is port specs min. 4" dia.x12"L- MAX. 20sqx16"L (THIS IS EQUIVELNT TO .09 cu ft min. not to excied .19 cu.ft. for better sound, this will put you at 38.2Hz. or 34.7Hz
hope this helps.
Nov 24, 2013 | Mmats Pro 12 Car Subwoofer
Daytime running lights not working
under the hood on the drivers side near the brake booster theres a small box about 3x3x2 inches with 2 small screws holding it down and a flat plug going to it.change that box,just about any dodge will fit and work,i bought one from a wrecker for under $10.hope that helps you..
Sep 21, 2011 | 1999 Dodge Ram
What is the cubic feet of air space
it's a measurement used to describe the empty air inside an enclosure. When you build a speaker enclosure, such as for two subs, u build it to fit the componets air space recomendations. keep in mind anything inside the enclosure like braces or the magnet part of the speaker will deduct from the measurment.
Sep 15, 2009 | Mmats Pro 12 Car Subwoofer
How to remove rear seat in 1996 dodge ram 1500
REMOVAL & INSTALLATION
  1. Clamp the seat belts to keep them from retracting.
  2. Locate and disconnect seat wiring at the connector(s).
  3. Move front seats forward or back for access to the hold down hardware.
  4. Put the rear seats in the stowed position.
  5. On Durango 3rd row seats, lift the cushion upward and forward to floor cargo position.
  6. Remove the hardware securing the seat.
  7. On split bench models, lift the center seat upward to clear attachment stud
  8. Remove the seat from the vehicle.
NOTE Do NOT activate the track adjusters once the fastening hardware is removed.
  1. Installation is the reverse of removal.
Fig. Disconnect the wiring from under the seat
Fig. Seat track mounting hardware locations-typical
Fig. Bench seat components: seat (1), nut (2), stud (3), floor pan (4), bolt (5)-Ram
Fig. Split bench seat assembly-Ram
Fig. Bucket seat mounting components-Durango shown
Fig. Rear seat removal/installation
I hope help you with this; good luck (rated this help).
Aug 31, 2009 | 1996 Dodge Ram 1500 Club Cab
Dodge ram charger 1992 (van i think)
look under the dash on the driver side.
Apr 13, 2009 | 1989 Dodge Ramcharger
Need specs to build box for my truck
I do design sub enclosures for a living and I give free specs on basic setups, so you are in luck. As a starting point I'll start by saying that fitting them under the seat may not work that well. Each sub will need about .75 cu.ft. sealed and probably double or triple that for a good ported box. I can get more specific If you e-mail me (dynami28@charter.net) the specs on those subs. Specifically I will need the Theile Small parameters ( these numbers-VAS, QES, QMS, FS, etc,) and then I can give you a better idea of where they will fit. If they do go under the seat they will probably not produce really low bass because smaller boxes generally produce higher bass tones. This decision should be based on what you listen too and what you expect them to sound like. They most likely will be more thump than boom and some people like that, so figure that out as well and let me know. Also my father has the same truck and there is a lot of room under the back seat. You can also gain some extra space by using fiberglass to conform the enclosure to the contour of the truck.
-Dynami
Apr 02, 2009 | Rockford Fosgate Car Audio & Video
2002 Dodge Ram 1500 Quad Cab Electrical gremlins
I had this prob with my 2002 dodge..it ended up needing a new battery.
Sep 24, 2008 | 1996 Dodge Ram 1500 Club Cab
PowerAmp for Mmats 2.0 12" SubWoofer
what model speaker. i recommend matching your MMATS speaker with a MMATS amp. Match the RMS
May 19, 2008 | Mmats 12 Car Subwoofer
Mmats Pro 12 Car Subwoofer Logo
79 people viewed this question
Top Mmats Car Audio & Video Experts
xxxxxx xxx
Are you a Mmats Car Audio and Video Expert? Answer questions, earn points and help others
