Question about Toshiba (5105-S701) Graphic Card
I have a Toshiba 5105 s701 laptop. The graphics card (reportedly) is what will "fizz out" after a while, starting with some vertical lines on some or all parts of the screen, then if I continue, eventually it will go to a complete "fuzzy w/o picture" screen. If I turn it off, a few hours later, it will boot up just fine! I'm not a big "change" sort, so would be happy with a repair. What is your recommendation?
  • 591 Answers
There is probably a COLD JOINT (broken solder) on the video or mother board, I would recommend to check the warranty and see if you can claim it, if not than you could try re-flowing the board, there are companies that do this or you can do it your self (if you have skills, courage, gutts and nothing to lose...), first you need to STRIP the laptop completely so that you have just the motherboard in your hands, (remove everything that is removable) wires, connectors, batteries, etc..., than pre-heat your oven to 390 F, put the board in a cookie tray with a 1 inch elevation (you can use aluminium balls in each corners) put it in the oven for 8 minuts than turn off the oven, delicately open the oven door and DONT'T MOVE IT the time it cools down to room temperature, re-assemble the laptop and try it... if it works, serve with a nice cold beer ha! if not than you need a new laptop...
Worked for me with a DEL Latitude... it's running fine since...
Posted on Mar 25, 2011
Hello, I just bought a Toshiba laptop.Then I downloaded this game called World of Tanks, but my laptop cant handle the graphics and details and it gets an avg of 3 fps which really bugs me. But im still...
Laptops in general usually have weaker graphics cards. You don't mention the model of the Toshiba laptop you have, so I can't really tell what graphics chipset is used in your case. If it's an old laptop (i.e. you bought it second-hand) then it's possible that there's not much you can do about it. On the other hand, if it's a relatively modern model (released in the last 2-3 years) it should have enough horse-power to play games, albeit in lower resolutions/details than a desktop graphics card.
Make sure you have the latest graphics driver installed for your model (and Windows version). Again, since you don't mention which model that is, I cannot give you a specific link to get it from. Try Toshiba's website and go from there.
You can find the model name underneath the laptop, usually on a silver sticker near a corner.
Hope that helps!
Mar 13, 2011 | Toshiba (5105-S701) Graphic Card
My screen turns red and splotchy when it fixes up say graphic card had an error
Hi, Thanks for using fixya.
The motherboard needs to be replaced.
Sorry for bad news.
Terry
Feb 13, 2011 | Toshiba (5105-S701) Graphic Card
My laptop shows lines and cant play any 3D games
Check the minimum specs for the game (on the game box) - your laptop is probably far below the minimum hardware requirement.
Jun 17, 2010 | Toshiba (5105-S701) Graphic Card
Graphics card issue.
There are 2 solutions for this problem.
  1. You Restore your windows.
  2. You Reinstall your Graphic Card
Restore Step
  • 1st Click on Start.
  • Click on All Programs
  • Then click on Accessories
  • Click on System tools Then
  • Click on System Restore.
  • System Restore window appears
  • Then check this option
  • Restore my computer to an earlier time.
  • Click on next
  • Click on date where you want to restore your system then click on next.
  • And the Restore wizard will start.
  • After sometime the computer will restart.
  • After this hope your problem will solve.
Graphic Card Drivers
Mar 19, 2010 | Toshiba (5105-S701) Graphic Card
Hi, im not very good with computers so i'l describe problem as best as i can. my graphics card is running slow and causing problems. it says i need to upgrade but dont no how. please could you help me...
Go to device manager >> display card properties and select upgrade driver tab to upgrade the latest drivers for the display card.
Revert back for more assistance.
Jan 26, 2010 | Toshiba (5105-S701) Graphic Card
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
I suspect my graphics card has been swapped by my comp. guy.
Your graphics are integrated into the motherbaord, so he couldn't have changed it out on you. Your Satellite has a ATI MOBILITY RADEON 9000 IGP with 64MB shared memory.
You can try to update or rollback the driver to see if that solves the problem, or contact the guy who serviced your laptop and see if he has any ideas.
Feb 09, 2009 | Toshiba (5105-S701) Graphic Card
NVIDIA GE FORCE 4 40 GO
that might actually be a bad LCD..
or bad graphics chip..
either way probly cheaper to buy a new laptop.
alternatively you can just connect a CRT monitor to the monitor out port.
Jan 09, 2009 | Toshiba (5105-S701) Graphic Card
Graphics cards
I believe that this is intergrated onto the mainboard and cannot be changed usually they were fitted with the Geoforce 440
http://www.intel.com/products/chipsets/GM965/index.htm
Mar 02, 2008 | Toshiba (5105-S701) Graphic Card
Computers & Internet Logo
233 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
